Manage environment sensors
Access and monitor platform environment sensors to ensure the optimal operation of your ONTAP cluster.
Overview
You can use this API to retrieve the details of all platform environment sensors
Retrieving values of a single sensor
# The API:
GET /api/cluster/sensors/{node.uuid}/{index}
# The call:
curl -X GET "https://<mgmt-ip>/api/cluster/sensors/{node.uuid}/{index}" -H "accept: application/hal+json"
# The response:
200 OK
# JSON Body
"node": {
"uuid": "19ec0b4a-4a4d-11ec-9036-d039ea4a991a",
"name": "node1",
"href": "/api/cluster/nodes/19ec0b4a-4a4d-11ec-9036-d039ea4a991a"
"index": 1,
"name": "PVCCSA CPU FD",
"type": "voltage",
"value": 831,
"value_units": "mV",
"threshold_state": "normal",
"critical_low_threshold": 297,
"warning_low_threshold": 396,
"warning_high_threshold": 1485,
"critical_high_threshold": 1683,
"href": "/api/cluster/sensors/19ec0b4a-4a4d-11ec-9036-d039ea4a991a/1"
