Manage S3 buckets
Overview
An S3 bucket is a container of objects. Each bucket defines an object namespace. S3 server requests specify objects using a bucket-name and object-name pair. An object consists of data, along with optional metadata and access controls, that is accessible using a name. An object resides within a bucket. There can be more than one bucket in an S3 server. Buckets that are created for the server are associated with an S3 user that is created on the S3 server.
Retrieving all fields for all S3 buckets of a cluster
# The API:
/api/protocols/s3/buckets
# The call:
curl -X GET "https://<mgmt-ip>/api/protocols/s3/buckets?fields=**&return_records=true" -H "accept: application/json"
# The response:
"records": [
"svm": {
"uuid": "12f3ba4c-7ae0-11e9-8c06-0050568ea123",
"name": "vs1"
"uuid": "527812ab-7c6d-11e9-97e8-0050568ea123",
"name": "bucket-2",
"volume": {
"name": "fg_oss_1558514455",
"uuid": "51276f5f-7c6d-11e9-97e8-0050568ea123"
"size": 209715200,
"logical_used_size": 157286400,
"encryption": {
"enabled": false
"comment": "S3 bucket.",
"qos_policy": {
"min_throughput_iops": 0,
"min_throughput_mbps": 0,
"max_throughput_iops": 1000,
"max_throughput_mbps": 0,
"uuid": "39ac471f-ff35-11e9-b0f9-005056a7ab52",
"name": "vs0_auto_gen_policy_39a9522f_ff35_11e9_b0f9_005056a7ab52"
"svm": {
"name": "vs1"
"uuid": "a8234aec-7e06-11e9-97e8-0050568ea123",
"name": "bucket-1",
"volume": {
"name": "fg_oss_1558690256",
"uuid": "a36a1ea7-7e06-11e9-97e8-0050568ea123"
"size": 1677721600,
"logical_used_size": 0,
"encryption": {
"enabled": false
"comment": "bucket2",
"qos_policy": {
"svm": {
"uuid": "ee30eb2d-7ae1-11e9-8abe-0050568ea123",
"name": "vs2"
"uuid": "19283b75-7ae2-11e9-8abe-0050568ea123",
"name": "bucket-3",
"volume": {
"name": "fg_oss_1558690257",
"uuid": "a46a1ea7-7e06-11e9-97e8-0050568ea123"
"size": 1677721600,
"logical_used_size": 1075838976,
"encryption": {
"enabled": false
"comment": "bucket3",
"qos_policy": {
"policy": {
"statements": [
"effect": "allow",
"actions": [
"principals": [
"Alice"
"resources": [
"bucket-3",
"bucket-3/*"
"sid": "fullAccessForAliceToBucket",
"conditions": [
"operator": "ip_address",
"source_ips": [
"1.1.1.1/10"
"num_records": 3
Retrieving all S3 buckets of a cluster ordered by size
# The API:
# The call:
curl -X GET "https://<mgmt-ip>/api/protocols/s3/buckets?return_records=true&order_by=size" -H "accept: application/json"
# The response:
"records": [
"svm": {
"name": "vs1"
"uuid": "754389d0-7e13-11e9-bfdc-0050568ea123",
"name": "bb1",
"size": 83886080
"svm": {
"name": "vs2"
"name": "bb2",
"size": 838860800
"svm": {
"name": "vs1"
"name": "bucket-1",
"size": 1677721600
"num_records": 3
Retrieving all S3 buckets of a cluster with name "bb2"
# The API:
# The call:
curl -X GET "https://<mgmt-ip>/api/protocols/s3/buckets?name=bb2&return_records=true" -H "accept: application/json"
# The response:
"records": [
"svm": {
"name": "vs1"
"uuid": "087d940e-7e15-11e9-bfdc-0050568ea123",
"name": "bb2"
"svm": {
"name": "vs2"
"name": "bb2"
"num_records": 2
Retrieving the specified bucket associated with an SVM
# The API:
/api/protocols/s3/buckets/{svm.uuid}/{uuid}
# The call:
curl -X GET "https://<mgmt-ip>/api/protocols/s3/buckets/12f3ba4c-7ae0-11e9-8c06-0050568ea123/527812ab-7c6d-11e9-97e8-0050568ea123" -H "accept: application/json"
# The response:
"svm": {
"name": "vs1"
"name": "bucket-2",
"volume": {
"size": 209715200,
"encryption": {
"enabled": false
"qos_policy": {
Creating an S3 bucket for an SVM
# The API:
# The call:
curl -iku admin:netapp1! -X POST "https://<mgmt-ip>/api/protocols/s3/buckets?return_timeout=0&return_records=true" -H "accept: application/json" -H "Content-Type: application/json" -d "{ \"aggregates\": [ { \"name\": \"aggr5\", \"uuid\": \"12f3ba4c-7ae0-11e9-8c06-0050568ea123\" } ], \"comment\": \"S3 bucket.\", \"constituents_per_aggregate\": 4, \"name\": \"bucket-3\", \"svm\": { \"name\": \"vs1\" } }"
# The response:
HTTP/1.1 202 Accepted
Date: Fri, 24 May 2019 11:22:14 GMT
Server: libzapid-httpd
X-Content-Type-Options: nosniff
Cache-Control: no-cache,no-store,must-revalidate
Location: /api/protocols/s3/buckets/259b4e46-2d33-11ea-9145-005056bbbec1/?name=bucket-3
Content-Length: 353
"num_records": 1,
"records": [
"name": "bucket-3",
"job": {
"uuid": "2e880171-7e16-11e9-bfdc-0050568ea123",
"href": "/api/cluster/jobs/2e880171-7e16-11e9-bfdc-0050568ea123"
Creating an S3 bucket along with QoS policy for an SVM
# The API:
# The call:
curl -iku admin:netapp1! -X POST "https://<mgmt-ip>/api/protocols/s3/buckets?return_timeout=0&return_records=true" -H "accept: application/json" -H "Content-Type: application/json" -d "{ \"comment\": \"S3 bucket.\", \"name\": \"bucket-3\", \"svm\": { \"name\": \"vs1\" }, \"qos_policy\": { \"min_throughput_iops\": 0, \"min_throughput_mbps\": 0, \"max_throughput_iops\": 1000000, \"max_throughput_mbps\": 900000, \"uuid\": \"02d07a93-6177-11ea-b241-000c293feac8\", \"name\": \"vs0_auto_gen_policy_02cfa02a_6177_11ea_b241_000c293feac8\" } }"
# The response:
Content-Length: 353
"num_records": 1,
"records": [
"name": "bucket-3",
"job": {
Creating an S3 bucket along with policies and conditions for an SVM
# The API:
# The call:
curl -iku admin:netapp1! -X POST "https://<mgmt-ip>/api/protocols/s3/buckets?return_timeout=0&return_records=true" -H "accept: application/json" -H "Content-Type: application/json" -d "{ \"aggregates\": [ { \"name\": \"aggr5\", \"uuid\": \"12f3ba4c-7ae0-11e9-8c06-0050568ea123\" } ], \"comment\": \"S3 bucket.\", \"constituents_per_aggregate\": 4, \"name\": \"bucket-3\", \"policy\": { \"statements\": [ { \"actions\": [ \"GetObject\" ], \"conditions\": [ { \"operator\": \"ip_address\", \"source_ips\": [ \"1.1.1.1/23\", \"1.2.2.2/20\" ] } ], \"effect\": \"allow\", \"resources\": [ \"bucket-3/policies/examples/*\" ], \"sid\": \"AccessToGetObjectForAllUsersofSVM\" }, { \"actions\": [ \"*Object\" ], \"effect\": \"deny\", \"principals\": [ \"mike\" ], \"resources\": [ \"bucket-3/policy-docs/*\", \"bucket-3/confidential-*\" ], \"sid\": \"DenyAccessToObjectForMike\" }, { \"actions\": [ \"GetObject\" ], \"effect\": \"allow\", \"principals\": [ \"*\" ], \"resources\": [ \"bucket-3/readme\" ], \"sid\": \"AnonnymousAccessToGetObjectForUsers\" } ] }, \"svm\": { \"uuid\": \"259b4e46-2d33-11ea-9145-005056bbbec1\" } }"
# The response:
Content-Length: 353
"num_records": 1,
"records": [
"name": "bucket-3",
"job": {
Creating an S3 bucket along with a bucket lifecycle management rule for an SVM
# The API:
# The call:
curl -iku admin:netapp1! -X POST "https://<mgmt-ip>/api/protocols/s3/buckets?return_timeout=0&return_records=true" -H "accept: application/json" -H "Content-Type: application/json" -d "{ \"aggregates\": [ { \"name\": \"aggr5\", \"uuid\": \"12f3ba4c-7ae0-11e9-8c06-0050568ea123\" } ], \"comment\": \"S3 bucket.\", \"constituents_per_aggregate\": 4, \"name\": \"bucket-4\", \"lifecycle_management\": { \"rules\": [ { \"name\": \"rule1\", \"expiration\": { \"object_age_days\" : \"1000\" }, \"abort_incomplete_multipart_upload\" : { \"after_initiation_days\" : 200 }, \"object_filter\": { \"prefix\" : \"obj1*/\" , \"size_greater_than\" : \"1000\" } }, { \"name\": \"rule2\", \"object_filter\": { \"size_greater_than\" : \"50\" }, \"expiration\": { \"object_age_days\" : \"5000\" } } ] } }"
# The response:
Date: Fri, 18 April 2022 11:22:14 GMT
Location: /api/protocols/s3/buckets/259b4e46-2d33-11ea-9145-005056bbbec1/?name=bucket-4
Content-Length: 353
"num_records": 1,
"records": [
"name": "bucket-4",
"job": {
### Updating an S3 bucket for an SVM
The API:
The call:
curl -X PATCH "https://
The response:
HTTP/1.1 202 Accepted Date: Fri, 24 May 2019 11:32:27 GMT Server: libzapid-httpd X-Content-Type-Options: nosniff Cache-Control: no-cache,no-store,must-revalidate Content-Length: 189 Content-Type: application/json { "job": { "uuid": "9beafabb-7e17-11e9-bfdc-0050568ea123", "_links": { "self": { "href": "/api/cluster/jobs/9beafabb-7e17-11e9-bfdc-0050568ea123" } } } }
### Updating an S3 bucket policy for an SVM
The API:
The call:
The response:
### Deleting an S3 bucket for a specified SVM
The API:
The call:
curl -iku admin:netapp1! -X DELETE "https://
The response:
HTTP/1.1 202 Accepted Date: Fri, 24 May 2019 11:40:17 GMT Server: libzapid-httpd X-Content-Type-Options: nosniff Cache-Control: no-cache,no-store,must-revalidate Content-Length: 189 Content-Type: application/json { "job": { "uuid": "b3af4a54-7e18-11e9-bfdc-0050568ea123", "_links": { "self": { "href": "/api/cluster/jobs/b3af4a54-7e18-11e9-bfdc-0050568ea123" } } } }
