Manage S3 buckets
Manage S3 buckets to organize and control object storage within your environment efficiently. These endpoints enable you to create, update, and manage bucket configurations, policies, and access controls for optimal data management.
Overview
An S3 bucket is a container of objects. Each bucket defines an object namespace. S3 server requests specify objects using a bucket-name and object-name pair. An object consists of data, along with optional metadata and access controls, that is accessible using a name. An object resides within a bucket. There can be more than one bucket in an S3 server. Buckets that are created for the server are associated with an S3 user that is created on the S3 server.
Retrieving all fields for all S3 buckets of a cluster
# The API:
/api/protocols/s3/buckets
# The call:
curl -X GET "https://<mgmt-ip>/api/protocols/s3/buckets?fields=**&return_records=true" -H "accept: application/json"
# The response:
"records": [
"svm": {
"uuid": "12f3ba4c-7ae0-11e9-8c06-0050568ea123",
"name": "vs1"
"uuid": "527812ab-7c6d-11e9-97e8-0050568ea123",
"name": "bucket-2",
"volume": {
"name": "fg_oss_1558514455",
"uuid": "51276f5f-7c6d-11e9-97e8-0050568ea123"
"size": 209715200,
"logical_used_size": 157286400,
"encryption": {
"enabled": false
"comment": "S3 bucket.",
"qos_policy": {
"min_throughput_iops": 0,
"min_throughput_mbps": 0,
"max_throughput_iops": 1000,
"max_throughput_mbps": 0,
"uuid": "39ac471f-ff35-11e9-b0f9-005056a7ab52",
"name": "vs0_auto_gen_policy_39a9522f_ff35_11e9_b0f9_005056a7ab52"
"snapshot-policy": {
"name": "default-1weekly",
"uuid": "f9c5f090-4ac8-11ef-ba24-005056a7ceb6"
"svm": {
"name": "vs1"
"uuid": "a8234aec-7e06-11e9-97e8-0050568ea123",
"name": "bucket-1",
"volume": {
"name": "fg_oss_1558690256",
"uuid": "a36a1ea7-7e06-11e9-97e8-0050568ea123"
"size": 1677721600,
"logical_used_size": 0,
"encryption": {
"enabled": false
"comment": "bucket2",
"qos_policy": {
"svm": {
"uuid": "ee30eb2d-7ae1-11e9-8abe-0050568ea123",
"name": "vs2"
"uuid": "19283b75-7ae2-11e9-8abe-0050568ea123",
"name": "bucket-3",
"volume": {
"name": "fg_oss_1558690257",
"uuid": "a46a1ea7-7e06-11e9-97e8-0050568ea123"
"size": 1677721600,
"logical_used_size": 1075838976,
"encryption": {
"enabled": false
"comment": "bucket3",
"qos_policy": {
"policy": {
"statements": [
"effect": "allow",
"actions": [
"principals": [
"Alice"
"resources": [
"bucket-3",
"bucket-3/*"
"sid": "fullAccessForAliceToBucket",
"conditions": [
"operator": "ip_address",
"source_ips": [
"1.1.1.1/10"
"cors": {
"rules": [
"id": "string",
"allowed_origins": [
"http://www.example.com"
"allowed_methods": [
"PUT",
"DELETE"
"allowed_headers": [
"x-amz-request-id"
"expose_headers": [
"max_age_seconds": 1024
"num_records": 3
Retrieving all S3 buckets of a cluster ordered by size
# The API:
# The call:
curl -X GET "https://<mgmt-ip>/api/protocols/s3/buckets?return_records=true&order_by=size" -H "accept: application/json"
# The response:
"records": [
"svm": {
"name": "vs1"
"uuid": "754389d0-7e13-11e9-bfdc-0050568ea123",
"name": "bb1",
"size": 838860800
"svm": {
"name": "vs2"
"name": "bb2",
"size": 838860800
"svm": {
"name": "vs1"
"name": "bucket-1",
"size": 1677721600
"num_records": 3
Retrieving all S3 buckets of a cluster with name "bb2"
# The API:
# The call:
curl -X GET "https://<mgmt-ip>/api/protocols/s3/buckets?name=bb2&return_records=true" -H "accept: application/json"
# The response:
"records": [
"svm": {
"name": "vs1"
"uuid": "087d940e-7e15-11e9-bfdc-0050568ea123",
"name": "bb2"
"svm": {
"name": "vs2"
"name": "bb2"
"num_records": 2
Retrieving the specified bucket associated with an SVM
# The API:
/api/protocols/s3/buckets/{svm.uuid}/{uuid}
# The call:
curl -X GET "https://<mgmt-ip>/api/protocols/s3/buckets/12f3ba4c-7ae0-11e9-8c06-0050568ea123/527812ab-7c6d-11e9-97e8-0050568ea123" -H "accept: application/json"
# The response:
"svm": {
"name": "vs1"
"name": "bucket-2",
"volume": {
"size": 209715200,
"encryption": {
"enabled": false
"qos_policy": {
Creating an S3 bucket for an SVM
# The API:
# The call:
curl -iku admin:<password> -X POST "https://<mgmt-ip>/api/protocols/s3/buckets?return_timeout=0&return_records=true" -H "accept: application/json" -H "Content-Type: application/json" -d "{ \"aggregates\": [ { \"name\": \"aggr5\", \"uuid\": \"12f3ba4c-7ae0-11e9-8c06-0050568ea123\" } ], \"comment\": \"S3 bucket.\", \"constituents_per_aggregate\": 4, \"name\": \"bucket-3\", \"svm\": { \"name\": \"vs1\" } }"
# The response:
HTTP/1.1 202 Accepted
Date: Fri, 24 May 2019 11:22:14 GMT
Server: libzapid-httpd
X-Content-Type-Options: nosniff
Cache-Control: no-cache,no-store,must-revalidate
Location: /api/protocols/s3/buckets/259b4e46-2d33-11ea-9145-005056bbbec1/?name=bucket-3
Content-Length: 353
"num_records": 1,
"records": [
"name": "bucket-3",
"job": {
"uuid": "2e880171-7e16-11e9-bfdc-0050568ea123",
"href": "/api/cluster/jobs/2e880171-7e16-11e9-bfdc-0050568ea123"
Creating an S3 bucket along with QoS policy for an SVM
# The API:
# The call:
curl -iku admin:<password> -X POST "https://<mgmt-ip>/api/protocols/s3/buckets?return_timeout=0&return_records=true" -H "accept: application/json" -H "Content-Type: application/json" -d "{ \"comment\": \"S3 bucket.\", \"name\": \"bucket-3\", \"svm\": { \"name\": \"vs1\" }, \"qos_policy\": { \"min_throughput_iops\": 0, \"min_throughput_mbps\": 0, \"max_throughput_iops\": 1000000, \"max_throughput_mbps\": 900000, \"uuid\": \"02d07a93-6177-11ea-b241-000c293feac8\", \"name\": \"vs0_auto_gen_policy_02cfa02a_6177_11ea_b241_000c293feac8\" } }"
# The response:
Content-Length: 353
"num_records": 1,
"records": [
"name": "bucket-3",
"job": {
Creating an S3 bucket along with policies and conditions for an SVM
# The API:
# The call:
curl -iku admin:<password> -X POST "https://<mgmt-ip>/api/protocols/s3/buckets?return_timeout=0&return_records=true" -H "accept: application/json" -H "Content-Type: application/json" -d "{ \"aggregates\": [ { \"name\": \"aggr5\", \"uuid\": \"12f3ba4c-7ae0-11e9-8c06-0050568ea123\" } ], \"comment\": \"S3 bucket.\", \"constituents_per_aggregate\": 4, \"name\": \"bucket-3\", \"policy\": { \"statements\": [ { \"actions\": [ \"GetObject\" ], \"conditions\": [ { \"operator\": \"ip_address\", \"source_ips\": [ \"1.1.1.1/23\", \"1.2.2.2/20\" ] } ], \"effect\": \"allow\", \"resources\": [ \"bucket-3/policies/examples/*\" ], \"sid\": \"AccessToGetObjectForAllUsersofSVM\" }, { \"actions\": [ \"*Object\" ], \"effect\": \"deny\", \"principals\": [ \"mike\" ], \"resources\": [ \"bucket-3/policy-docs/*\", \"bucket-3/confidential-*\" ], \"sid\": \"DenyAccessToObjectForMike\" }, { \"actions\": [ \"GetObject\" ], \"effect\": \"allow\", \"principals\": [ \"*\" ], \"resources\": [ \"bucket-3/readme\" ], \"sid\": \"AnonymousAccessToGetObjectForUsers\" } ] }, \"svm\": { \"uuid\": \"259b4e46-2d33-11ea-9145-005056bbbec1\" } }"
# The response:
Content-Length: 353
"num_records": 1,
"records": [
"name": "bucket-3",
"job": {
Creating an S3 bucket and CORS rules for an SVM
# The API:
# The call:
curl -X POST "https://<mgmt-ip>/api/protocols/s3/buckets?return_timeout=0&return_records=true" -H "accept: application/json" -H "Content-Type: application/json" -d "{ \"aggregates\": [ { \"name\": \"aggr5\", \"uuid\": \"12f3ba4c-7ae0-11e9-8c06-0050568ea123\" } ], \"comment\": \"S3 bucket.\", \"constituents_per_aggregate\": 4, \"name\": \"bucket-3\", \"cors\": { \"rules\": [{ \"allowed_headers\": [ \"x-amz-request-id\" ], \"allowed_methods\": [ \"PUT\", \"DELETE\" ], \"allowed_origins\": [ \"http://www.example.com\" ], \"expose_headers\": [ \"http://www.example.com\" ], \"id\": \"id1\", \"max_age_seconds\": 1024 }]}, \"svm\": { \"uuid\": \"259b4e46-2d33-11ea-9145-005056bbbec1\" }}"
# The response:
Content-Length: 353
"num_records": 1,
"records": [
"name": "bucket-3",
"job": {
Creating an S3 bucket along with a bucket lifecycle management rule for an SVM
# The API:
# The call:
curl -iku admin:<password> -X POST "https://<mgmt-ip>/api/protocols/s3/buckets?return_timeout=0&return_records=true" -H "accept: application/json" -H "Content-Type: application/json" -d "{ \"aggregates\": [ { \"name\": \"aggr5\", \"uuid\": \"12f3ba4c-7ae0-11e9-8c06-0050568ea123\" } ], \"comment\": \"S3 bucket.\", \"constituents_per_aggregate\": 4, \"name\": \"bucket-4\", \"lifecycle_management\": { \"rules\": [ { \"name\": \"rule1\", \"expiration\": { \"object_age_days\" : \"1000\" }, \"abort_incomplete_multipart_upload\" : { \"after_initiation_days\" : 200 }, \"object_filter\": { \"prefix\" : \"obj1*/\" , \"size_greater_than\" : \"1000\" } }, { \"name\": \"rule2\", \"object_filter\": { \"size_greater_than\" : \"50\" }, \"expiration\": { \"object_age_days\" : \"5000\" } } ] } }"
# The response:
Date: Fri, 18 April 2022 11:22:14 GMT
Location: /api/protocols/s3/buckets/259b4e46-2d33-11ea-9145-005056bbbec1/?name=bucket-4
Content-Length: 353
"num_records": 1,
"records": [
"name": "bucket-4",
"job": {
Creating an S3 bucket with a snapshot-policy
# The API:
# The call:
curl -iku admin:<password> -X POST "https://<mgmt-ip>/api/protocols/s3/buckets?return_records=true" -H "accept: application/json" -H "Content-Type: application/json" -d "{ \"comment\": \"S3 snapshot policy bucket.\", \"snapshot_policy\": { \"name\": \"default-1weekly\", \"uuid\": \"f9c5f090-4ac8-11ef-ba24-005056a7ceb6\" }, \"name\": \"bucket-7\", \"svm.uuid\": \"8c38f10b-4871-11ef-aab5-005056a7ceb6\" }"
# The response:
Date: Thu, 25 Jul 2024 17:16:15 GMT
Location: /api/protocols/s3/services/8c38f10b-4871-11ef-aab5-005056a7ceb6/buckets/9f21f404-4aa4-11ef-ba24-005056a7ceb6
Content-Length: 189
"job": {
"uuid": "99978136-4aa9-11ef-ba24-005056a7ceb6",
"href": "/api/cluster/jobs/99978136-4aa9-11ef-ba24-005056a7ceb6"
Updating an S3 bucket for an SVM
# The API:
# The call:
curl -X PATCH "https://<mgmt-ip>/api/protocols/s3/buckets/259b4e46-2d33-11ea-9145-005056bbbec1/376a2efd-2d4d-11ea-9c30-005056bb883a?return_records=true" -H "accept: application/json?return_records=true" -H "Content-Type: application/json" -d "{ \"comment\": \"Bucket modified.\", \"size\": 111111111111, \"qos_policy\": { \"min_throughput_iops\": 0, \"min_throughput_mbps\": 0, \"max_throughput_iops\": 1000000, \"max_throughput_mbps\": 900000, \"uuid\": \"02d07a93-6177-11ea-b241-000c293feac8\", \"name\": \"vs0_auto_gen_policy_02cfa02a_6177_11ea_b241_000c293feac8\" }}"
# The response:
Date: Fri, 24 May 2019 11:32:27 GMT
Content-Length: 189
"job": {
"uuid": "9beafabb-7e17-11e9-bfdc-0050568ea123",
"href": "/api/cluster/jobs/9beafabb-7e17-11e9-bfdc-0050568ea123"
Updating an S3 bucket policy for an SVM
# The API:
# The call:
curl -X PATCH "https://<mgmt-ip>/api/protocols/s3/buckets/259b4e46-2d33-11ea-9145-005056bbbec1/376a2efd-2d4d-11ea-9c30-005056bb883a?return_records=true" -H "accept: application/json" -H "Content-Type: application/json" -d "{ \"policy\": { \"statements\": [ { \"actions\": [ \"*\" ], \"conditions\": [ { \"operator\": \"ip_address\", \"source_ips\": [ \"1.1.1.5/23\" ] } ], \"effect\": \"allow\", \"resources\": [ \"*\" ], \"sid\": \"fullAccessForAllPrincipalsToBucket\"} ] } }"
# The response:
Content-Length: 189
"job": {
Updating an S3 bucket CORS configuration for an SVM
# The API:
# The call:
curl -X PATCH "https://<mgmt-ip>/api/protocols/s3/buckets/259b4e46-2d33-11ea-9145-005056bbbec1/376a2efd-2d4d-11ea-9c30-005056bb883a?return_records=true" -H "accept: application/json" -H "Content-Type: application/json" -d "{ \"cors\": { \"rules\": [{ \"allowed_headers\": [ \"x-amz-request-id\" ], \"allowed_methods\": [ \"PUT\", \"DELETE\" ], \"allowed_origins\": [ \"http://www.example.com\" ], \"expose_headers\": [ \"http://www.example.com\" ], \"id\": \"id1\", \"max_age_seconds\": 1024 } ] } }"
# The response:
Content-Length: 189
"job": {
Updating the snapshot-policy for an S3 bucket for an SVM
# The API:
# The call:
curl -X PATCH "https://<mgmt-ip>/api/protocols/s3/buckets/8c38f10b-4871-11ef-aab5-005056a7ceb6/eec0d90e-4934-11ef-947d-005056a7ceb6" -H "accept: application/json" -H "Content-Type: application/json" -d "{ \"snapshot_policy\": { \"name\": \"default-1weekly\", \"uuid\": \"f9c5f090-4ac8-11ef-ba24-005056a7ceb6\" } }"
# The response:
Date: Thu, 25 Jul 2024 17:26:17 GMT
Content-Length: 189
"job": {
"uuid": "003a4cad-4aab-11ef-ba24-005056a7ceb6",
"href": "/api/cluster/jobs/003a4cad-4aab-11ef-ba24-005056a7ceb6"
Deleting an S3 bucket for a specified SVM
# The API:
# The call:
curl -iku admin:<password> -X DELETE "https://<mgmt-ip>/api/protocols/s3/buckets/259b4e46-2d33-11ea-9145-005056bbbec1/98528221-2d52-11ea-892e-005056bbbec1?return_records=true" -H "accept: application/json"
# The response:
Date: Fri, 24 May 2019 11:40:17 GMT
Content-Length: 189
"job": {
"uuid": "b3af4a54-7e18-11e9-bfdc-0050568ea123",
"href": "/api/cluster/jobs/b3af4a54-7e18-11e9-bfdc-0050568ea123"
