Update NTP symmetric authentication key details
Updates the details of an NTP symmetric authentication key using its numeric identifier or index. This operation is typically performed when you need to change the cryptographic hash type or value of the shared private key.
HTTP method and endpoint
PATCH /cluster/ntp/keys/{id}
Introduced in
ONTAP 9.7
Usage notes
Updates the details of a specific NTP symmetric authentication key by numeric identifier or index (ID).
Required properties
digest_type- Shared private key cryptographic hash type. -
value- Value of shared private key.
Related ONTAP commands
cluster time-service ntp key modify
Learn more
id |
integer |
path |
True |
Key identifier |
Request Body
| Name | Type | Description |
digest_type |
string |
The type of cryptographic hash used to create and verify the NTP's message authentication code appended to each NTP packet header. |
value |
string |
A hexadecimal digit string that represents the cryptographic key that is shared with the remote NTP server. The current expected length is 40 characters. Use the cryptographic key and key ID to create a unique hash value used to authenticate the rest of the NTP data. |
Example request
"digest_type": "sha1",
"value": "da39a3ee5e6b4b0d3255bfef95601890afd80709"
Status: 200, Ok
Status: Default
ONTAP Error Response Codes
| Error Code | Description |
2097187 |
An invalid SHA1 key was provided. |
href |
string |
_links
ntp_key
digest_type |
string |
value |
string |
code |
string |
Argument code |
message |
string |
Message argument |
error
arguments |
array[error_arguments] |
Message arguments |
code |
string |
Error code |
message |
string |
Error message |
target |
string |
