REST API reference
Update NTP symmetric authentication key details
PATCH /cluster/ntp/keys/{id}
Introduced In: 9.7
Updates the details of a specific NTP symmetric authentication key by numeric identifier or index (ID).
Required properties
  • digest_type - Shared private key cryptographic hash type.
  • value - Value of shared private key.
  • cluster time-service ntp key modify
id
integer
path
True
Key identifier
Request Body
Name Type Description
digest_type
string
The type of cryptographic hash used to create and verify the NTP's message authentication code appended to each NTP packet header.
value
string
A hexadecimal digit string that represents the cryptographic key that is shared with the remote NTP server. The current expected length is 40 characters.
Use the cryptographic key and key ID to create a unique hash value used to authenticate the rest of the NTP data.
Example request
  "digest_type": "sha1",
  "value": "da39a3ee5e6b4b0d3255bfef95601890afd80709"
Status: 200, Ok
Status: Default
ONTAP Error Response Codes
Error Code Description
2097187
An invalid SHA1 key was provided.
string
ntp_key
digest_type
string
value
string
code
string
Argument code
message
string
Message argument
returned_error
arguments
array[error_arguments]
Message arguments
code
string
Error code
message
string
Error message
target
string
