REST API reference
Update a cluster peer instance
Updates a cluster peer instance to modify its configuration or properties as needed to maintain connectivity and collaboration between clusters.
HTTP method and endpoint
PATCH /cluster/peers/{uuid}
Introduced in
ONTAP 9.6
uuid
string
path
True
Cluster peer relationship UUID
Request Body
Name Type Description
_links
_links
authentication
authentication
encryption
encryption
initial_allowed_svms
array[initial_allowed_svms]
The local SVMs allowed to peer with the peer cluster's SVMs. This list can be modified until the remote cluster accepts this cluster peering relationship.
ip_address
string
IPv4 or IPv6 address
ipspace
ipspace
The IPspace of the local intercluster LIFs.
name
string
Optional name for the cluster peer relationship. By default, it is the name of the remote cluster, or a temporary name might be autogenerated for anonymous cluster peer offers.
peer_applications
array[string]
Peering applications against which allowed SVMs are configured.
remote
remote
status
status
uuid
string
UUID of the cluster peer relationship. For anonymous cluster peer offers, the UUID will change when the remote cluster accepts the relationship.
Example request
  "authentication": {
    "expiry_time": "P1DT2H3M4S or '2017-01-25T11:20:13Z'",
    "in_use": "string",
    "passphrase": "string",
    "state": "string"
  "encryption": {
    "proposed": "string",
    "state": "string"
  "initial_allowed_svms": [
      "name": "svm1",
  "ip_address": "10.10.10.7",
  "ipspace": {
    "name": "exchange",
  "name": "cluster2",
  "peer_applications": [
    "snapmirror",
    "flexcache"
  "remote": {
    "ip_addresses": [
      "10.10.10.7"
    "name": "cluster2",
    "serial_number": "4048820-60-9"
  "status": {
    "state": "available",
    "update_time": "2017-01-25 11:20:13 +0000"
Status: 200, Ok
_links
_links
authentication
authentication
encryption
encryption
ip_address
string
ipspace
ipspace
name
string
peer_applications
array[string]
remote
remote
status
status
uuid
string
  "authentication": {
    "in_use": "string",
    "state": "string"
  "encryption": {
    "state": "string"
      "name": "svm1",
  "ipspace": {
    "name": "exchange",
  "name": "cluster2",
    "snapmirror",
    "flexcache"
  "remote": {
    "ip_addresses": [
      "10.10.10.7"
    "name": "cluster2",
  "status": {
Status: Default
ONTAP Error Response Codes
Error Code Description
4653261
Error finding IPspace.
4655058
Expiration time cannot be more than 7 days in the future.
4656070
The encryption protocol is meaningful only with authenticated cluster peer relationships.
4656072
The name must conform to the same rules as a cluster name.
4656073
Changing the encryption state requires the refreshing of the authentication passphrase.
4656075
Cannot specify encryption: this operation requires an ECV of ONTAP 9.6.0 or later.
4656076
Cluster peer modify was attempted with mismatched IPv4 and IPv6 addresses.
4656081
The remote IP address list is empty.
4656082
Specify either a passphrase or "-generate-passphrase".
4656083
Cannot auto-generate a passphrase when "generate-passphrase" is false. Modifying a passphrase using an auto-generated passphrase requires "generate-passphrase" be true.
4656084
Passphrase can only be modified with an authenticated cluster peer relationship.
4656092
Cluster peer modify was attempted with a host name that did not resolve to an IPv4 or IPv6 address.
4656095
The address family of the specified peer addresses is not valid in this IPspace. Use /api/network/interfaces/ to verify that required LIFs are present and operational on each cluster node.
string
authentication
expiry_time
string
The time when the passphrase will expire, in ISO 8601 duration format or date and time format. The default is 1 hour.
generate_passphrase
boolean
Auto generate a passphrase when true.
in_use
string
passphrase
string
A password to authenticate the cluster peer relationship.
state
string
encryption
proposed
string
state
string
_links
_links
name
string
The name of the SVM.
uuid
string
ipspace
_links
_links
name
string
IPspace name
uuid
string
IPspace UUID
interfaces
ip_address
string
local_network
Cluster peering requires an intercluster LIF on each local node. These can be optionally created by specifying a list of IP addresses corresponding to each node.
broadcast_domain
string
Broadcast domain that is in use within the IPspace.
gateway
string
The IPv4 or IPv6 address of the default router.
interfaces
array[interfaces]
netmask
string
IPv4 mask or netmask length.
remote
ip_addresses
array[string]
The IPv4 addresses, IPv6 addresses, or hostnames of the peers.
name
string
The name of the remote cluster.
serial_number
string
The serial number of the remote cluster.
status
state
string
update_time
string
The last time the state was updated.
version
This returns the cluster version information. When the cluster has more than one node, the cluster version is equivalent to the lowest of generation, major, and minor versions on all nodes.
full
string
The full cluster version string.
generation
integer
The generation portion of the version.
major
integer
The major portion of the version.
minor
integer
The minor portion of the version.
cluster_peer
_links
_links
authentication
authentication
encryption
encryption
ip_address
string
ipspace
ipspace
name
string
peer_applications
array[string]
remote
remote
status
status
uuid
string
code
string
Argument code
message
string
Message argument
error
arguments
array[error_arguments]
Message arguments
code
string
Error code
message
string
Error message
target
string
