Update a cluster peer instance
Updates a cluster peer instance to modify its configuration or settings as needed.
HTTP method and endpoint
PATCH /cluster/peers/{uuid}
Introduced in
ONTAP 9.6
uuid |
string |
path |
True |
Cluster peer relationship UUID |
Request Body
| Name | Type | Description |
_links |
authentication |
encryption |
initial_allowed_svms |
array[initial_allowed_svms] |
The local SVMs allowed to peer with the peer cluster's SVMs. This list can be modified until the remote cluster accepts this cluster peering relationship. |
ip_address |
string |
IPv4 or IPv6 address |
ipspace |
The IPspace of the local intercluster LIFs. |
name |
string |
Optional name for the cluster peer relationship. By default, it is the name of the remote cluster, or a temporary name might be autogenerated for anonymous cluster peer offers. |
peer_applications |
array[string] |
Peering applications against which allowed SVMs are configured. |
remote |
status |
uuid |
string |
UUID of the cluster peer relationship. For anonymous cluster peer offers, the UUID will change when the remote cluster accepts the relationship. |
Example request
"authentication": {
"expiry_time": "P1DT2H3M4S or '2017-01-25T11:20:13Z'",
"in_use": "string",
"passphrase": "string",
"state": "string"
"encryption": {
"proposed": "string",
"state": "string"
"initial_allowed_svms": [
"name": "svm1",
"ip_address": "10.10.10.7",
"ipspace": {
"name": "exchange",
"name": "cluster2",
"peer_applications": [
"snapmirror",
"flexcache"
"remote": {
"ip_addresses": [
"10.10.10.7"
"name": "cluster2",
"serial_number": "4048820-60-9"
"status": {
"state": "available",
"update_time": "2017-01-25 06:20:13 -0500"
Status: 200, Ok
_links |
authentication |
encryption |
ip_address |
string |
ipspace |
name |
string |
peer_applications |
array[string] |
remote |
status |
uuid |
string |
"authentication": {
"in_use": "string",
"state": "string"
"encryption": {
"state": "string"
"name": "svm1",
"ipspace": {
"name": "exchange",
"name": "cluster2",
"snapmirror",
"flexcache"
"remote": {
"ip_addresses": [
"10.10.10.7"
"name": "cluster2",
"status": {
Status: Default
ONTAP Error Response Codes
| Error Code | Description |
2621462 |
SVM name does not exist. |
4653061 |
The specified remote cluster is invalid. |
4653218 |
An introductory RPC to the peer address failed to connect. Verify that the peer address is correct, and then try the operation again. |
4653229 |
Specified value for "-offer-expiration" is obsolete. |
4653236 |
The specified passphrase is too short. |
4653257 |
The vifmgr process is not running. |
4653261 |
Error finding IPspace. |
4653671 |
No operational intercluster LIFs of the IPv4 address family is available on this node for the specified IPspace. |
4655058 |
Expiration time cannot be more than 7 days in the future. |
4655061 |
SVM does not exist in the IPspace. |
4656070 |
The encryption protocol is meaningful only with authenticated cluster peer relationships. |
4656072 |
The name must conform to the same rules as a cluster name. |
4656073 |
Changing the encryption state requires the refreshing of the authentication passphrase. |
4656075 |
Cannot specify encryption: this operation requires an ECV of ONTAP 9.6.0 or later. |
4656076 |
Cluster peer modify was attempted with mismatched IPv4 and IPv6 addresses. |
4656080 |
Specify either a passphrase or set "generate-passphrase" to true. |
4656081 |
The remote IP address list is empty. |
4656083 |
Cannot auto-generate a passphrase when "generate-passphrase" is false. Modifying a passphrase using an auto-generated passphrase requires "generate-passphrase" be true. |
4656084 |
Passphrase can only be modified with an authenticated cluster peer relationship. |
4656092 |
Cluster peer modify was attempted with a host name that did not resolve to an IPv4 or IPv6 address. |
4656095 |
The address family of the specified peer addresses is not valid in this IPspace. Use /api/network/interfaces/ to verify that required LIFs are present and operational on each cluster node. |
href |
string |
_links
authentication
expiry_time |
string |
The time when the passphrase will expire, in ISO 8601 duration format or date and time format. The default is 1 hour. |
generate_passphrase |
boolean |
Auto generate a passphrase when true. |
in_use |
string |
passphrase |
string |
A password to authenticate the cluster peer relationship. |
state |
string |
encryption
proposed |
string |
state |
string |
name |
string |
uuid |
string |
ipspace
name |
string |
IPspace name |
uuid |
string |
IPspace UUID |
interfaces
ip_address |
string |
local_network
Cluster peering requires an intercluster LIF on each local node. These can be optionally created by specifying a list of IP addresses corresponding to each node.
broadcast_domain |
string |
Broadcast domain that is in use within the IPspace. |
gateway |
string |
The IPv4 or IPv6 address of the default router. |
interfaces |
array[interfaces] |
netmask |
string |
IPv4 mask or netmask length. |
remote
ip_addresses |
array[string] |
The IPv4 addresses, IPv6 addresses, or hostnames of the peers. |
name |
string |
The name of the remote cluster. |
serial_number |
string |
The serial number of the remote cluster. |
status
state |
string |
update_time |
string |
The last time the state was updated. |
version
This returns the cluster version information. When the cluster has more than one node, the cluster version is equivalent to the lowest of generation, major, and minor versions on all nodes.
full |
string |
The full cluster version string. |
generation |
integer |
The generation portion of the version. |
major |
integer |
The major portion of the version. |
minor |
integer |
The minor portion of the version. |
cluster_peer
_links |
authentication |
encryption |
ip_address |
string |
ipspace |
name |
string |
peer_applications |
array[string] |
remote |
status |
uuid |
string |
code |
string |
Argument code |
message |
string |
Message argument |
returned_error
arguments |
array[error_arguments] |
Message arguments |
code |
string |
Error code |
message |
string |
Error message |
target |
string |
