Update a cluster peer instance
PATCH /cluster/peers/{uuid}
Updates a cluster peer instance.
Learn more
uuid  |
string  |
path  |
True  |
Cluster peer relationship UUID  |
Request Body
| Name | Type | Description |
_links  |
authentication  |
encryption  |
initial_allowed_svms  |
array[initial_allowed_svms]  |
The local SVMs allowed to peer with the peer cluster's SVMs. This list can be modified until the remote cluster accepts this cluster peering relationship.  |
ipspace  |
The IPspace of the local intercluster LIFs.  |
name  |
string  |
Optional name for the cluster peer relationship. By default, it is the name of the remote cluster.  |
peer_applications  |
array[string]  |
Peering applications against which allowed SVMs are configured.  |
remote  |
status  |
uuid  |
string  |
UUID of the cluster peer relationship. For anonymous cluster peer offers, the UUID will change when the remote cluster accepts the relationship.  |
version  |
This returns the cluster version information. When the cluster has more than one node, the cluster version is equivalent to the lowest of generation, major, and minor versions on all nodes.  |
Example request
    "interfaces": {
      "href": "/api/resourcelink"
  "authentication": {
    "expiry_time": "P1DT2H3M4S or '2017-01-25T11:20:13Z'",
    "in_use": "string",
    "passphrase": "string",
    "state": "string"
  "encryption": {
    "proposed": "string",
    "state": "string"
  "initial_allowed_svms": [
      "name": "svm1",
  "ipspace": {
    "name": "exchange",
  "name": "cluster2",
  "peer_applications": [
    "snapmirror",
    "flexcache"
  "remote": {
    "ip_addresses": [
      "10.10.10.7"
    "name": "cluster2",
    "serial_number": "4048820-60-9"
  "status": {
    "state": "available",
    "update_time": "2017-01-25 11:20:13 UTC"
  "uuid": "1cd8a442-86d1-11e0-ae1c-123478563412",
  "version": {
    "full": "NetApp Release 9.4.0: Sun Nov 05 18:20:57 UTC 2017",
    "generation": 9,
    "major": 4,
    "minor": 0
Status: 200, Ok
_links  |
authentication  |
ip_address  |
string  |
IPv4 or IPv6 address  |
name  |
string  |
Optional name for the cluster peer relationship. By default, it is the name of the remote cluster, or a temporary name might be autogenerated for anonymous cluster peer offers.  |
  "authentication": {
    "expiry_time": "2017-01-25 11:20:13 UTC",
  "ip_address": "10.10.10.7",
  "name": "cluster2"
Status: Default
ONTAP Error Response Codes
| Error Code | Description |
4653261  |
Error finding IPspace.  |
4655058  |
Expiration time cannot be more than 7 days in the future.  |
4656070  |
The encryption protocol is meaningful only with authenticated cluster peer relationships.  |
4656072  |
The name must conform to the same rules as a cluster name.  |
4656073  |
Changing the encryption state requires the refreshing of the authentication passphrase.  |
4656075  |
Cannot specify encryption: this operation requires an ECV of ONTAP 9.6.0 or later.  |
4656076  |
Cluster peer modify was attempted with mismatched IPv4 and IPv6 addresses.  |
4656081  |
The remote IP address list is empty.  |
4656082  |
Specify either a passphrase or "-generate-passphrase".  |
4656083  |
Cannot auto-generate a passphrase when "generate-passphrase" is false. Modifying a passphrase using an auto-generated passphrase requires "generate-passphrase" be true.  |
4656084  |
Passphrase can only be modified with an authenticated cluster peer relationship.  |
4656092  |
Cluster peer modify was attempted with a host name that did not resolve to an IPv4 or IPv6 address.  |
4656095  |
The address family of the specified peer addresses is not valid in this IPspace. Use /api/network/interfaces/ to verify that required LIFs are present and operational on each cluster node.  |
error  |
Example error
  "error": {
    "arguments": [
        "code": "string",
        "message": "string"
    "code": "4",
    "target": "uuid"
href  |
string  |
_links
interfaces  |
self  |
authentication
expiry_time  |
string  |
The time when the passphrase will expire, in ISO 8601 duration format or date and time format. The default is 1 hour.  |
generate_passphrase  |
boolean  |
Auto generate a passphrase when true.  |
in_use  |
string  |
passphrase  |
string  |
A password to authenticate the cluster peer relationship.  |
state  |
string  |
encryption
proposed  |
string  |
state  |
string  |
_links
self  |
_links  |
name  |
string  |
The name of the SVM.  |
uuid  |
string  |
The unique identifier of the SVM.  |
ipspace
_links  |
name  |
string  |
IPspace name  |
uuid  |
string  |
IPspace UUID  |
interfaces
ip_address  |
string  |
local_network
Cluster peering requires an intercluster LIF on each local node. These can be optionally created by specifying a list of IP addresses corresponding to each node.
broadcast_domain  |
string  |
Broadcast domain that is in use within the IPspace.  |
gateway  |
string  |
The IPv4 or IPv6 address of the default router.  |
interfaces  |
array[interfaces]  |
netmask  |
string  |
IPv4 mask or netmask length.  |
remote
ip_addresses  |
array[string]  |
The IPv4 addresses, IPv6 addresses, or hostnames of the peers.  |
name  |
string  |
The name of the remote cluster.  |
serial_number  |
string  |
The serial number of the remote cluster.  |
status
state  |
string  |
update_time  |
string  |
The last time the state was updated.  |
version
full  |
string  |
The full cluster version string.  |
generation  |
integer  |
The generation portion of the version.  |
major  |
integer  |
The major portion of the version.  |
minor  |
integer  |
The minor portion of the version.  |
cluster_peer
_links  |
authentication  |
encryption  |
ipspace  |
name  |
string  |
peer_applications  |
array[string]  |
remote  |
status  |
uuid  |
string  |
version  |
authentication
expiry_time  |
string  |
The date and time the passphrase will expire. The default expiry time is one hour.  |
passphrase  |
string  |
code  |
string  |
Argument code  |
message  |
string  |
Message argument  |
error
arguments  |
array[error_arguments]  |
Message arguments  |
code  |
string  |
Error code  |
message  |
string  |
Error message  |
target  |
string  |
The target parameter that caused the error.  |
