Create a background task to update the GPO settings for an SVM
Creates a background task to update the Group Policy Object (GPO) settings for a specific Storage Virtual Machine (SVM). This is useful when you need to refresh or change the GPO settings without immediate disruption to the SVM operations.
HTTP method and endpoint
PATCH /protocols/cifs/group-policies/{svm.uuid}
Introduced in
ONTAP 9.12
Usage notes
Will create a background task to update the GPO settings for specified SVM.
Related ONTAP commands
vserver cifs group-policy update
apply_updates |
boolean |
query |
False |
Indicates whether to apply updates or not.
force_reapply_all_settings |
boolean |
query |
False |
Indicates whether or not a re-applying of all settings is enforced.
svm.uuid |
string |
path |
True |
UUID of the SVM to which this object belongs. |
Status: 200, Ok
Status: Default
ONTAP Error Response Codes
| Error Code | Description |
4456649 |
Unable to get Group Policy information for SVM. |
4456650 |
Group Policy is disabled for SVM. |
4456651 |
Unable to get CIFS server information for SVM. |
4456652 |
CIFS server is down for SVM. |
4456851 |
An update is already in progress for specified SVM. Wait a few minutes, then try the command again. |
4456852 |
Failed to set forced update for specified SVM. Reason: Internal error. Starting normal update. |
| Name | Type | Description |
code |
string |
Argument code |
message |
string |
Message argument |
error
arguments |
array[error_arguments] |
Message arguments |
code |
string |
Error code |
message |
string |
Error message |
target |
string |
