REST API reference
Create a background task to update the GPO settings for an SVM
Creates a background task to update the group policy settings for a specified SVM. This task assists in managing and maintaining CIFS services effectively within your storage environment.
HTTP method and endpoint
PATCH /protocols/cifs/group-policies/{svm.uuid}
Introduced in
ONTAP 9.12
Usage notes
Creates a background task to update the GPO settings for the specified SVM. Note: The group policy can be enabled or disabled using "group_policy_object_enabled" field in PATCH "/protocols/cifs/services/{svm.uuid}" API.
  • vserver cifs group-policy update
apply_updates
boolean
query
False
Indicates whether to apply updates or not.
  • Default value: 1
force_reapply_all_settings
boolean
query
False
Indicates whether or not a re-applying of all settings is enforced.
  • Default value:
svm.uuid
string
path
True
Status: 200, Ok
Status: Default
ONTAP Error Response Codes
Error Code Description
4456649
Unable to get Group Policy information for SVM.
4456650
Group Policy is disabled for SVM.
4456651
Unable to get CIFS server information for SVM.
4456652
CIFS server is down for SVM.
4456851
An update is already in progress for specified SVM. Wait a few minutes, then try the command again.
4456852
Failed to set forced update for specified SVM. Reason: Internal error. Starting normal update.
Name Type Description
code
string
Argument code
message
string
Message argument
returned_error
arguments
array[error_arguments]
Message arguments
code
string
Error code
message
string
Error message
target
string
