REST API reference
Update a share-level ACL on a CIFS share
Updates a share-level ACL on a CIFS share to modify access permissions as needed for your environment.
HTTP method and endpoint
PATCH /protocols/cifs/shares/{svm.uuid}/{share}/acls/{user_or_group}/{type}
Introduced in
ONTAP 9.6
  • vserver cifs share access-control modify
share
string
path
True
Share name
user_or_group
string
path
True
User or group name
type
string
path
True
User or group type
svm.uuid
string
path
True
Request Body
Name Type Description
_links
_links
permission
string
Specifies the access rights that a user or group has on the defined CIFS Share. The following values are allowed:
  • no_access - User does not have CIFS share access
  • read - User has only read access
  • change - User has change access
  • full_control - User has full_control access
share
string
CIFS share name
sid
string
Specifies the user or group secure identifier (SID).
svm
svm
Example request
  "permission": "string",
  "share": "string",
  "sid": "S-1-5-21-256008430-3394229847-3930036330-1001",
  "svm": {
    "name": "svm1",
Status: 200, Ok
Status: Default
ONTAP Error Response Codes
Error Code Description
655516
The share ACL does not exist for given user and share
string
svm
_links
_links
name
string
The name of the SVM.
uuid
string
cifs_share_acl
The permissions that users and groups have on a CIFS share.
_links
_links
permission
string
share
string
CIFS share name
sid
string
svm
svm
code
string
Argument code
message
string
Message argument
error
arguments
array[error_arguments]
Message arguments
code
string
Error code
message
string
Error message
target
string
