REST API reference
Update a share-level ACL on a CIFS share
Updates a share-level ACL on a CIFS share to modify access permissions as needed for your environment.
HTTP method and endpoint
PATCH /protocols/cifs/shares/{svm.uuid}/{share}/acls/{user_or_group}/{type}
Introduced in
ONTAP 9.6
  • vserver cifs share access-control modify
share
string
path
True
Share name
user_or_group
string
path
True
User or group name
type
string
path
True
User or group type
svm.uuid
string
path
True
Request Body
Name Type Description
permission
string
Specifies the access rights that a user or group has on the defined CIFS Share. The following values are allowed:
  • no_access - User does not have CIFS share access
  • read - User has only read access
  • change - User has change access
  • full_control - User has full_control access
share
string
CIFS share name
sid
string
Specifies the user or group secure identifier (SID).
svm
svm
unix_id
integer
Specifies the UNIX user or group identifier (UID/GID).
Example request
  "permission": "string",
  "share": "string",
  "sid": "S-1-5-21-256008430-3394229847-3930036330-1001",
  "svm": {
    "name": "svm1",
  "unix_id": 100
Status: 200, Ok
Status: Default
ONTAP Error Response Codes
Error Code Description
655516
The share ACL does not exist for given user and share
string
svm
name
string
uuid
string
cifs_share_acl
The permissions that users and groups have on a CIFS share.
permission
string
share
string
CIFS share name
sid
string
svm
svm
unix_id
integer
code
string
Argument code
message
string
Message argument
returned_error
arguments
array[error_arguments]
Message arguments
code
string
Error code
message
string
Error message
target
string
