Upload the bulk-import status of an SVM to a URI
Uploads the bulk-import status of a specified SVM to a designated URI. Use this endpoint to manage the status reporting of SVM bulk-import operations efficiently.
HTTP method and endpoint
PATCH /protocols/cifs/users-and-groups/bulk-import/{svm.uuid}
Introduced in
ONTAP 9.11
Usage notes
Upload the status of the bulk-import of the specified SVM to the specified URI.
Important notes
Only the status of the last bulk-import will be uploaded and not the status of the previous bulk-imports.
Required properties
status_uri.path - URI to which the status needs to be uploaded.
Optional properties
status_uri.username - Username of the specified URI.
status_uri.password - Password of the specified URI.
Related ONTAP commands
vserver cifs users-and-groups import get-status
return_timeout |
integer |
query |
False |
svm.uuid |
string |
path |
True |
UUID of the SVM to which this object belongs. |
Request Body
| Name | Type | Description |
status_uri |
svm |
Example request
"status_uri": {
"password": "string",
"path": "http://web.sample.com/web1/file1.7z",
"username": "user1"
"svm": {
"name": "svm1",
Status: 202, Accepted
job |
"job": {
"uuid": "string"
Status: Default, Error
href |
string |
_links
detailed_status
code |
string |
Code corresponding to the import status failure. |
message |
string |
Detailed description of the import status. |
import_uri
password |
string |
Password of the specified URI. |
path |
string |
URI from which to load the input file containing the CIFS local users and groups. The file must be encrypted using the 7zip utility. URI can be FTP or HTTP. |
username |
string |
Username of the specified URI. |
status_uri
password |
string |
path |
string |
username |
string |
svm
name |
string |
The name of the SVM. |
uuid |
string |
local_cifs_users_and_groups_import
status_uri |
svm |
job_link
uuid |
string |
code |
string |
Argument code |
message |
string |
Message argument |
error
arguments |
array[error_arguments] |
Message arguments |
code |
string |
Error code |
message |
string |
Error message |
target |
string |
