REST API reference
Upload the bulk-import status of an SVM to a URI
Uploads the status of the latest bulk-import operation for a specified SVM to a designated URI. Use this endpoint to verify the current import status and ensure it is correctly recorded at the specified location.
HTTP method and endpoint
PATCH /protocols/cifs/users-and-groups/bulk-import/{svm.uuid}
Introduced in
ONTAP 9.11
Usage notes
Upload the status of the bulk-import of the specified SVM to the specified URI.
Important notes
  • Only the status of the last bulk-import will be uploaded and not the status of the previous bulk-imports.
Required properties
  • status_uri.path - URI to which the status needs to be uploaded.
Optional properties
  • status_uri.username - Username of the specified URI.
  • status_uri.password - Password of the specified URI.
  • vserver cifs users-and-groups import get-status
return_timeout
integer
query
False
  • Default value: 0
  • Max value: 120
  • Min value: 0
svm.uuid
string
path
True
Request Body
Name Type Description
elements_ignored
integer
Number of elements ignored.
elements_imported
integer
Number of elements successfully imported.
state
string
Operation status.
status_uri
status_uri
svm
svm
Example request
  "elements_ignored": 0,
  "elements_imported": 0,
  "state": "string",
  "status_uri": {
    "password": "string",
    "path": "http://web.sample.com/web1/file1.7z",
    "username": "user1"
  "svm": {
    "name": "svm1",
Status: 200, Ok
job
job_link
  "job": {
    "uuid": "string"
Status: 202, Accepted
Status: Default, Error
string
detailed_status
code
string
Code corresponding to the import status failure.
message
string
Detailed description of the import status.
import_uri
password
string
path
string
URI from which to load the input file containing the CIFS local users and groups. The file must be encrypted using the 7zip utility. URI can be FTP or HTTP.
username
string
status_uri
password
string
path
string
username
string
svm
name
string
uuid
string
local_cifs_users_and_groups_import
elements_ignored
integer
elements_imported
integer
state
string
Operation status.
status_uri
status_uri
svm
svm
uuid
string
The UUID of the asynchronous job that is triggered by a POST, PATCH, or DELETE operation.
code
string
Argument code
message
string
Message argument
returned_error
arguments
array[error_arguments]
Message arguments
code
string
Error code
message
string
Error message
target
string
