REST API reference
Updates the s3 bucket configuration of an svm
  • comment - any information related to the bucket
  • size - bucket size
  • policy - an access policy for resources (buckets and objects) that defines their permissions new policies are created after existing policies are deleted to retain any of the existing policy statements, you need to specify those statements again also, policy conditions can be specified as part of a bucket policy
  • qos_policy - a qos policy for buckets
  • audit_event_selector - audit policy for buckets none can be specified for both access and permission to remove an audit event selector
  • versioning-state - versioning state of the buckets
  • nas_path - nas path to which the bucket corresponds to # related ontap commands
  • vserver object-store-server bucket modify
  • vserver object-store-server bucket policy statement modify
  • vserver object-store-server bucket policy-statement-condition modify # learn more
  • [doc /protocols/s3/buckets](#docs-object-store-protocols_s3_buckets)
PATCH /protocols/s3/buckets/{svm.uuid}/{uuid}
Introduced In: 9.8
Updates the S3 bucket configuration of an SVM.
Important notes
  • The following fields can be modified for a bucket:
    • comment - Any information related to the bucket.
    • size - Bucket size.
    • policy - An access policy for resources (buckets and objects) that defines their permissions. New policies are created after existing policies are deleted. To retain any of the existing policy statements, you need to specify those statements again. Also, policy conditions can be specified as part of a bucket policy.
    • qos_policy - A QoS policy for buckets.
    • audit_event_selector - Audit policy for buckets. None can be specified for both access and permission to remove an audit event selector.
    • versioning-state - Versioning state of the buckets.
    • nas_path - NAS path to which the bucket corresponds to.
uuid
string
path
True
The unique identifier of the bucket.
return_timeout
integer
query
False
  • Default value: 0
  • Max value: 120
  • Min value: 0
svm.uuid
string
path
True
Request Body
Name Type Description
allowed
boolean
If this is set to true, an SVM administrator can manage the S3 service. If it is false, only the cluster administrator can manage the service.
Audit event selector allows you to specify access and permission types to audit.
comment
string
Can contain any additional information about the bucket being created or modified.
encryption
encryption
logical_used_size
integer
Specifies the bucket logical used size up to this point.
nas_path
string
Specifies the NAS path to which the nas bucket corresponds to.
policy
policy
A policy is an object associated with a bucket. It defines resource (bucket, folder, or object) permissions. These policies get evaluated when an S3 user makes a request by executing a specific command. The user must be part of the principal (user or group) specified in the policy. Permissions in the policies determine whether the request is allowed or denied.
protection_status
protection_status
Specifies attributes of bucket protection.
qos_policy
qos_policy
Specifes "qos_policy.max_throughput_iops" and/or "qos_policy.max_throughput_mbps" or "qos_policy.min_throughput_iops" and/or "qos_policy.min_throughput_mbps". Specifying "min_throughput_iops" or "min_throughput_mbps" is only supported on volumes hosted on a node that is flash optimized. A pre-created QoS policy can also be used by specifying "qos_policy.name" or "qos_policy.uuid" properties. Setting or assigning a QoS policy to a bucket is not supported if its containing volume or SVM already has a QoS policy attached.
role
string
Specifies the role of the bucket.
size
integer
Specifies the bucket size in bytes; ranges from 80MB to 64TB.
type
string
Specifies the bucket type. Valid values are "s3"and "nas".
uuid
string
Specifies the unique identifier of the bucket.
versioning_state
string
Specifies the versioning state of the bucket. Valid values are "disabled", "enabled" or "suspended". Note that the versioning state cannot be modified to 'disabled' from any other state.
volume
volume
Specifies the FlexGroup volume name and UUID where the bucket is hosted.
Example request
  "audit_event_selector": {
    "access": "string",
    "permission": "string"
  "comment": "S3 bucket.",
  "logical_used_size": 0,
  "nas_path": "/",
  "policy": {
    "statements": [
        "actions": [
          "GetObject",
          "PutObject",
          "DeleteObject",
          "ListBucket"
        "conditions": [
            "delimiters": [
            "max_keys": [
              1000
            "operator": "ip_address",
            "prefixes": [
              "pref"
            "source_ips": [
              "1.1.1.1",
              "1.2.2.0/24"
            "usernames": [
              "user1"
        "effect": "allow",
        "principals": [
          "user1",
          "group/grp1"
        "resources": [
          "bucket1",
          "bucket1/*"
        "sid": "FullAccessToUser1"
  "qos_policy": {
    "max_throughput_iops": 10000,
    "max_throughput_mbps": 500,
    "min_throughput_iops": 2000,
    "min_throughput_mbps": 500,
    "name": "performance",
  "role": "string",
  "size": 1677721600,
  "type": "s3",
  "uuid": "414b29a1-3b26-11e9-bd58-0050568ea055",
  "versioning_state": "enabled",
  "volume": {
    "name": "volume1",
Status: 202, Accepted
job
job_link
  "job": {
    "uuid": "string"
Status: Default
ONTAP Error Response Codes
Error code Message
92405778
"Failed to modify bucket "{bucket name}" for SVM "{svm.name}". Reason: {Reason for failure}. ";
92405846
"Failed to modify the object store volume. Reason: {Reason for failure}.";
92405811
"Failed to modify bucket "{bucket name}" for SVM "{svm.name}". Wait a few minutes and try the operation again.";
92405858
"Failed to "modify" the "bucket" because the operation is only supported on data SVMs.";
92405861
"The specified SVM UUID or bucket UUID does not exist.";
92405863
"An error occurs when creating an access policy. The reason for failure is detailed in the error message.";
92405864
"An error occurs when deleting an access policy. The reason for failure is detailed in the error message.";
92405891
The resources specified in the access policy are not valid. Valid ways to specify a resource are *, <bucket-name>, <bucket-name>/…​/…​. Valid characters for a resource are 0-9, A-Z, a-z, _, +, comma, ;, :, =, ., &, @,?, (, ), single quote, *, !, - and $.
92405894
"Statements, principals and resources list can have a maximum of 10 entries.";
92405897
The principals specified in the access policy are not in the correct format. User name must be in between 1 and 64 characters. Valid characters for a user name are 0-9, A-Z, a-z, _, +, =, comma, ., @, and - .
92405898
"The SID specified in the access policy is not valid. Valid characters for a SID are 0-9, A-Z and a-z.";
string
aggregates
name
string
uuid
string
access
string
Specifies read and write access types.
permission
string
Specifies allow and deny permission types.
encryption
enabled
boolean
Specifies whether encryption is enabled on the bucket. By default, encryption is disabled on a bucket.
abort_incomplete_multipart_upload
Specifies a way to perform abort_incomplete_multipart_upload action on filtered objects within a bucket.
after_initiation_days
integer
Number of days of initiation after which uploads can be aborted.
expiration
Specifies a way to perform expiration action on filtered objects within a bucket.
expired_object_delete_marker
boolean
Cleanup object delete markers.
object_age_days
integer
Number of days since creation after which objects can be deleted.
object_expiry_date
string
Specific date from when objects can expire.
non_current_version_expiration
Specifies a way to perform non_current_version_expiration action on filtered objects within a bucket.
new_non_current_versions
integer
Number of latest non-current versions to be retained.
non_current_days
integer
Number of days after which non-current versions can be deleted.
object_filter
Specifies a way to filter objects within a bucket.
prefix
string
A prefix that is matched against object-names within a bucket.
size_greater_than
integer
Size of the object greater than specified for which the corresponding lifecycle rule is to be applied.
size_less_than
integer
Size of the object smaller than specified for which the corresponding lifecycle rule is to be applied.
tags
array[string]
An array of key-value paired tags of the form or <tag=value>.
rules
Information about the lifecycle management rule of a bucket.
enabled
boolean
Specifies whether or not the associated rule is enabled.
expiration
expiration
lifecycle_management
Lifecycle management is implemented as an object associated with a bucket. It defines rules to be applied against objects within a bucket. These rules are applied in the background and can delete objects.
rules
array[rules]
Specifies an object store lifecycle management policy.
s3_bucket_policy_condition
Information about policy conditions based on various condition operators and condition keys.
delimiters
array[string]
An array of delimiters that are compared with the delimiter value specified at the time of execution of an S3-based command, using the condition operator specified.
max_keys
array[integer]
An array of maximum keys that are allowed or denied to be retrieved using an S3 list operation, based on the condition operator specified.
operator
string
Condition operator that is applied to the specified condition key.
prefixes
array[string]
An array of prefixes that are compared with the input prefix value specified at the time of execution of an S3-based command, using the condition operator specified.
source_ips
array[string]
An array of IP address ranges that are compared with the IP address of a source command at the time of execution of an S3-based command, using the condition operator specified.
usernames
array[string]
An array of usernames that a current user in the context is evaluated against using the condition operators.
s3_bucket_policy_statement
Specifies information about a single access permission.
actions
array[string]
conditions
array[s3_bucket_policy_condition]
Specifies bucket policy conditions.
effect
string
Specifies whether access is allowed or denied when a user requests the specific action. If access (to allow) is not granted explicitly to a resource, access is implicitly denied. Access can also be denied explicitly to a resource, in order to make sure that a user cannot access it, even if a different policy grants access.
principals
array[string]
resources
array[string]
sid
string
Specifies the statement identifier used to differentiate between statements.
policy
statements
array[s3_bucket_policy_statement]
Specifies bucket access policy statement.
destination
is_cloud
boolean
Specifies whether a bucket is protected within the Cloud.
is_external_cloud
boolean
Specifies whether a bucket is protected on external Cloud providers.
is_ontap
boolean
Specifies whether a bucket is protected within ONTAP.
  • Default value: 1
  • readOnly: 1
  • Introduced in: 9.10
  • x-nullable: true
protection_status
destination
destination
is_protected
boolean
Specifies whether a bucket is a source and if it is protected within ONTAP and/or an external cloud.
  • Default value: 1
  • readOnly: 1
  • x-nullable: true
qos_policy
max_throughput_iops
integer
Specifies the maximum throughput in IOPS, 0 means none. This is mutually exclusive with name and UUID during POST and PATCH.
max_throughput_mbps
integer
Specifies the maximum throughput in Megabytes per sec, 0 means none. This is mutually exclusive with name and UUID during POST and PATCH.
min_throughput_iops
integer
Specifies the minimum throughput in IOPS, 0 means none. Setting "min_throughput" is supported on AFF platforms only, unless FabricPool tiering policies are set. This is mutually exclusive with name and UUID during POST and PATCH.
min_throughput_mbps
integer
Specifies the minimum throughput in Megabytes per sec, 0 means none. This is mutually exclusive with name and UUID during POST and PATCH.
name
string
The QoS policy group name. This is mutually exclusive with UUID and other QoS attributes during POST and PATCH.
uuid
string
The QoS policy group UUID. This is mutually exclusive with name and other QoS attributes during POST and PATCH.
svm
name
string
The name of the SVM.
uuid
string
volume
name
string
The name of the volume.
uuid
string
  • example: 028baa66-41bd-11e9-81d5-00a0986138f7
  • Introduced in: 9.6
  • x-nullable: true
s3_bucket
A bucket is a container of objects. Each bucket defines an object namespace. S3 requests specify objects using a bucket-name and object-name pair. An object resides within a bucket.
allowed
boolean
comment
string
encryption
encryption
logical_used_size
integer
nas_path
string
policy
policy
protection_status
protection_status
qos_policy
qos_policy
role
string
size
integer
type
string
uuid
string
versioning_state
string
volume
volume
uuid
string
The UUID of the asynchronous job that is triggered by a POST, PATCH, or DELETE operation.
code
string
Argument code
message
string
Message argument
error
arguments
array[error_arguments]
Message arguments
code
string
Error code
message
string
Error message
target
string
Close
Try it out
Sign in with your NetApp Cloud Central credentials.
Try this API
Headers
Body
Code
