REST API reference
Update an initiator
Updates an initiator within an initiator group, allowing direct modification of initiators owned by the group itself. This is useful when you need to manage initiators specific to a particular group without affecting nested groups.
HTTP method and endpoint
PATCH /protocols/san/igroups/{igroup.uuid}/initiators/{name}
Introduced in
ONTAP 9.9
Usage notes
Updates an initiator of an initiator group. This API only supports modification of initiators owned directly by the initiator group. Initiators of nested initiator groups must be modified on the initiator group that directly owns the initiator.
  • lun igroup initiator modify
igroup.uuid
string
path
True
The unique identifier of the initiator group.
name
string
path
True
The initiator name.
Request Body
Name Type Description
comment
string
A comment available for use by the administrator. Valid in POST and PATCH.
connectivity_tracking
Overview of the initiator's connections to ONTAP.
  • readOnly: 1
  • Introduced in: 9.11
igroup
igroup
The initiator group in which the initiator is found.
Note that this does not mean that the initiator cannot also be found in other initiator groups.
records
array[records]
An array of initiators specified to add multiple initiators to an initiator group in a single API call. Not allowed when the name property is used.
Example request
  "comment": "string",
  "connectivity_tracking": {
    "alerts": [
        "summary": {
          "arguments": [
              "code": "string",
              "message": "string"
          "code": "4",
          "target": "uuid"
    "connection_state": "string",
    "connections": [
        "logins": [
            "interface": {
              "fc": {
                "name": "fc_lif1",
                "uuid": "3a09ab42-4da1-32cf-9d35-3385a6101a0b",
                "wwpn": "20:00:00:50:56:b4:13:a8"
              "ip": {
                "name": "lif1",
            "last_seen_time": "2021-03-14 05:19:00 +0000"
        "node": {
          "name": "node1",
  "igroup": {
    "name": "igroup1",
  "records": [
      "comment": "string"
Status: 200, Ok
Status: Default
ONTAP Error Response Codes
Error Code Description
5374034
An initiator is not a member of the initiator group.
5374744
The cluster is currently running in a mixed version and the initiators cannot be modified until the effective cluster version reaches 9.9.1.
5374852
The initiator group does not exist.
5374918
A subset of the provided list of initiators were modified before a failure occurred.
string
code
string
Argument code
message
string
Message argument
summary
A user friendly message describing the connection state.
arguments
array[error_arguments]
Message arguments
code
string
Error code
message
string
Error message
target
string
alerts
summary
summary
fc
An FC interface.
name
string
The name of the FC interface.
uuid
string
The unique identifier of the FC interface.
wwpn
string
The WWPN of the FC interface.
ip
IP information
ip
ip
ip
IP information
name
string
The name of the interface. If only the name is provided, the SVM scope must be provided by the object this object is embedded in.
uuid
string
The UUID that uniquely identifies the interface.
interface
fc
fc
An FC interface.
ip
ip
logins
connected
boolean
True if the initiator is currently logged in to this connection's interface.
interface
interface
last_seen_time
string
The last time this initiator logged in. Logins not seen for 48 hours are cleared and not reported.
node
name
string
uuid
string
connections
logins
array[logins]
node
node
alerts
array[alerts]
connection_state
string
Connection state.
connections
array[connections]
igroup
name
string
The name of the initiator group.
uuid
string
records
comment
string
igroup_initiator
comment
string
  • readOnly: 1
igroup
igroup
records
array[records]
error
arguments
Message arguments
code
string
Error code
message
string
Error message
target
string
