Update an initiator
Updates an initiator within an initiator group. Use this endpoint to modify initiators directly owned by the initiator group, while initiators of nested groups require changes at their respective owning group level.
HTTP method and endpoint
PATCH /protocols/san/igroups/{igroup.uuid}/initiators/{name}
Introduced in
ONTAP 9.9
Usage notes
Updates an initiator of an initiator group. This API only supports modification of initiators owned directly by the initiator group. Initiators of nested initiator groups must be modified on the initiator group that directly owns the initiator.
Related ONTAP commands
lun igroup initiator modify
Learn more
igroup.uuid |
string |
path |
True |
The unique identifier of the initiator group. |
name |
string |
path |
True |
The initiator name. |
Request Body
| Name | Type | Description |
comment |
string |
A comment available for use by the administrator. Valid in POST and PATCH. |
igroup |
The initiator group in which the initiator is found. Note that this does not mean that the initiator cannot also be found in other initiator groups. |
records |
array[records] |
An array of initiators specified to add multiple initiators to an initiator group in a single API call. Not allowed when the |
Example request
"comment": "string",
"igroup": {
"records": [
"comment": "string"
Status: 200, Ok
Status: Default
ONTAP Error Response Codes
| Error Code | Description |
5374034 |
An initiator is not a member of the initiator group. |
5374744 |
The cluster is currently running in a mixed version and the initiators cannot be modified until the effective cluster version reaches 9.9.1. |
5374852 |
The initiator group does not exist. |
5374918 |
A subset of the provided list of initiators were modified before a failure occurred. |
href |
string |
_links
igroup
uuid |
string |
records
comment |
string |
igroup_initiator
comment |
string |
igroup |
records |
array[records] |
code |
string |
Argument code |
message |
string |
Message argument |
error
arguments |
array[error_arguments] |
Message arguments |
code |
string |
Error code |
message |
string |
Error message |
target |
string |
