Update the remote syslog or splunk server information
Updates the information for a remote syslog or Splunk server. This helps ensure that your logging configuration is current and accurate.
HTTP method and endpoint
PATCH /security/audit/destinations/{address}/{port}
Introduced in
ONTAP 9.6
Usage notes
Updates remote syslog/splunk server information.
address |
string |
path |
True |
IP address of remote syslog/splunk server. |
port |
integer |
path |
True |
Port number of remote syslog/splunk server. |
Request Body
| Name | Type | Description |
facility |
string |
This is the standard Syslog Facility value that is used when sending audit records to a remote server. |
hostname_format_override |
string |
Syslog Hostname Format Override |
message_format |
string |
Syslog message format to be used. legacy_netapp format (variation of RFC-3164) is default message format. |
timestamp_format_override |
string |
Syslog Timestamp Format Override. |
verify_server |
boolean |
This is only applicable when the protocol is tcp_encrypted. This controls whether the remote server's certificate is validated. Setting "verify_server" to "true" will enforce validation of remote server's certificate. Setting "verify_server" to "false" will not enforce validation of remote server's certificate. |
Example request
"facility": "string",
"hostname_format_override": "string",
"message_format": "string",
"timestamp_format_override": "string"
Status: 200, Ok
facility |
string |
string |
message_format |
string |
string |
verify_server |
boolean |
Status: Default, Default
href |
string |
_links
ipspace
name |
string |
IPspace name |
uuid |
string |
IPspace UUID |
security_audit_log_forward
facility |
string |
string |
message_format |
string |
string |
verify_server |
boolean |
code |
string |
Argument code |
message |
string |
Message argument |
error
arguments |
array[error_arguments] |
Message arguments |
code |
string |
Error code |
message |
string |
Error message |
target |
string |
