REST API reference
Update the remote syslog or splunk server information
Updates the information for a remote syslog or Splunk server. This helps ensure that your logging configuration is current and accurate.
HTTP method and endpoint
PATCH /security/audit/destinations/{address}/{port}
Introduced in
ONTAP 9.6
Usage notes
Updates remote syslog/splunk server information.
address
string
path
True
IP address of remote syslog/splunk server.
port
integer
path
True
Port number of remote syslog/splunk server.
Request Body
Name Type Description
facility
string
This is the standard Syslog Facility value that is used when sending audit records to a remote server.
hostname_format_override
string
Syslog Hostname Format Override
ipspace
ipspace
message_format
string
Syslog message format to be used. legacy_netapp format (variation of RFC-3164) is default message format.
timestamp_format_override
string
Syslog Timestamp Format Override.
verify_server
boolean
This is only applicable when the protocol is tcp_encrypted. This controls whether the remote server's certificate is validated. Setting "verify_server" to "true" will enforce validation of remote server's certificate. Setting "verify_server" to "false" will not enforce validation of remote server's certificate.
Example request
  "facility": "string",
  "hostname_format_override": "string",
  "ipspace": {
    "name": "Default",
  "message_format": "string",
  "timestamp_format_override": "string"
Status: 200, Ok
facility
string
string
ipspace
ipspace
message_format
string
string
verify_server
boolean
  "ipspace": {
    "name": "Default",
Status: Default, Default
string
ipspace
name
string
IPspace name
uuid
string
IPspace UUID
security_audit_log_forward
facility
string
string
ipspace
ipspace
message_format
string
string
verify_server
boolean
code
string
Argument code
message
string
Message argument
returned_error
arguments
array[error_arguments]
Message arguments
code
string
Error code
message
string
Error message
target
string
