REST API reference
Update a TOTP profile for a user account
Updates a TOTP profile for a user account, modifying the account's two-factor authentication settings. This is useful when you need to change or reset authentication details for enhanced security.
HTTP method and endpoint
PATCH /security/login/totps/{owner.uuid}/{account.name}
Introduced in
ONTAP 9.13
Usage notes
Updates a TOTP user account.
  • security login totp modify
owner.uuid
string
path
True
Account owner UUID
account.name
string
path
True
User account name
Request Body
Name Type Description
comment
string
Optional comment for the TOTP profile.
enabled
boolean
Status of the TOTP profile.
scope
string
Scope of the entity. Set to "cluster" for cluster owned objects and to "svm" for SVM owned objects.
sha_fingerprint
string
SHA fingerprint for the TOTP secret key.
Example request
  "comment": "string",
  "enabled": "",
  "scope": "string",
  "sha_fingerprint": "string"
Status: 200, Ok
Status: Default
ONTAP Error Response Codes
Error Code Description
144834564
Only users with the admin role are allowed to modify the TOTP status.
144834565
Invalid option for the field -enabled
144834566
TOTP is not configured for the user
string
account_reference
_links
_links
name
string
User account
owner
Owner name and UUID that uniquely identifies the TOTP profile.
name
string
The name of the SVM.
uuid
string
totp
TOTP profile for the user account used to access SSH.
comment
string
enabled
boolean
scope
string
sha_fingerprint
string
code
string
Argument code
message
string
Message argument
error
arguments
array[error_arguments]
Message arguments
code
string
Error code
message
string
Error message
target
string
