REST API reference
Update login messages configuration
Updates the login message configuration to modify the messages displayed during user login. This can be useful for customizing user interaction or providing important information to users as they access the system.
HTTP method and endpoint
PATCH /security/login/messages/{uuid}
Introduced in
ONTAP 9.6
Usage notes
Updates the login messages configuration. There are no required fields. An empty body makes no modifications.
uuid
string
path
True
Login messages configuration UUID
Request Body
Name Type Description
banner
string
The login banner text. This message is displayed during SSH and console device login just before the password prompt displays. When configured, a cluster-level login banner is used for every incoming connection. Each data SVM can override the cluster-level banner to instead display when you log into the SVM. To restore the default setting for a data SVM, set the banner to an empty string. New lines are supplied as either LF or CRLF but are always returned as LF. Optional in the PATCH body.
message
string
The message of the day (MOTD). This message appears just before the clustershell prompt after a successful login. When configured, the cluster message displays first. If you log in as a data SVM administrator, the SVM message is then printed. The cluster-level MOTD can be disabled for a given data SVM using the "show_cluster_message" property. New lines are supplied as either LF or CRLF but are always returned as LF. Optional in the PATCH body.
scope
string
Set to "svm" for interfaces owned by an SVM. Otherwise, set to "cluster".
boolean
Specifies whether to show a cluster-level message before the SVM message when logging in as an SVM administrator. This setting can only be modified by the cluster administrator. Optional in the PATCH body.
svm
svm
uuid
string
The unique identifier (ID) of the login messages configuration.
Example request
  "banner": "string",
  "message": "string",
  "scope": "string",
  "svm": {
    "name": "svm1",
  "uuid": "string"
Status: 200, Ok
Status: Default
ONTAP Error Response codes
Error codes Description
10225636
Only a cluster administrator can modify the show_cluster_message property.
string
svm
name
string
The name of the SVM.
uuid
string
login_messages
The login banner and message of the day (MOTD) configuration.
banner
string
message
string
scope
string
boolean
svm
svm
uuid
string
code
string
Argument code
message
string
Message argument
error
arguments
array[error_arguments]
Message arguments
code
string
Error code
message
string
Error message
target
string
