Update a QoS policy
Updates a specific QoS policy to modify its parameters according to your storage performance requirements.
HTTP method and endpoint
PATCH /storage/qos/policies/{uuid}
Introduced in
ONTAP 9.6
Usage notes
Update a specific QoS policy.
Related ONTAP commands
qos policy-group modify -
qos adaptive-policy-group modify
uuid |
string |
path |
True |
return_timeout |
integer |
query |
False |
Request Body
| Name | Type | Description |
adaptive |
Adaptive QoS policy-groups define measurable service level objectives (SLOs) that adjust based on the storage object used space and the storage object allocated space. |
fixed |
QoS policy-groups define a fixed service level objective (SLO) for a storage object. |
name |
string |
Name of the QoS policy. |
object_count |
integer |
Number of objects attached to this policy. |
pgid |
integer |
Policy group ID of the QoS policy. |
policy_class |
string |
Class of the QoS policy. |
scope |
string |
Scope of the entity. Set to "cluster" for cluster owned objects and to "svm" for SVM owned objects. |
svm |
uuid |
string |
Example request
"adaptive": {
"block_size": "string",
"expected_iops_allocation": "string",
"peak_iops_allocation": "string"
"fixed": {
"capacity_shared": true
"name": "extreme",
"object_count": 0,
"pgid": 0,
"policy_class": "string",
"scope": "string",
"svm": {
"name": "svm1",
Status: 202, Accepted
job |
"job": {
"uuid": "string"
Status: Default
ONTAP Error Response Codes
| Error Code | Description |
8454147 |
The maximum limit for QoS policies has been reached. |
8454154 |
The name specified for creating conflicts with an existing QoS policy name. |
8454260 |
Invalid value for maximum and minimum fields. Valid values for max_throughput_iops and max_throughput_mbps combination is for the ratio of max_throughput_mbps and max_throughput_iops to be within 1 to 4096. |
8454273 |
Invalid value for an adaptive field. Value should be non-zero. |
8454277 |
The name specified for creating an adaptive QoS policy conflicts with an existing fixed QoS policy name. |
8454278 |
The name specified for creating a fixed QoS policy conflicts with an existing adaptive QoS policy name. |
8454286 |
Modifications on these cluster scoped preset policies is prohibited. |
8454327 |
The existing fixed QoS policy cannot be modified to an adaptive QoS policy. |
8454328 |
The existing adaptive QoS policy cannot be modified to a fixed QoS policy. |
href |
string |
_links
adaptive
absolute_min_iops |
integer |
Specifies the absolute minimum IOPS that is used as an override when the expected_iops is less than this value. These floors are not guaranteed on non-AFF platforms or when FabricPool tiering policies are set. |
block_size |
string |
Specifies the block size |
expected_iops |
integer |
Expected IOPS. Specifies the minimum expected IOPS per TB allocated based on the storage object allocated size. These floors are not guaranteed on non-AFF platforms or when FabricPool tiering policies are set. |
expected_iops_allocation |
string |
Specifies the size to be used to calculate expected IOPS per TB. The size options are either the storage object allocated space or the storage object used space. |
peak_iops |
integer |
Peak IOPS. Specifies the maximum possible IOPS per TB allocated based on the storage object allocated size or the storage object used size. |
peak_iops_allocation |
string |
Specifies the size to be used to calculate peak IOPS per TB. The size options are either the storage object allocated space or the storage object used space. |
fixed
max_throughput_iops |
integer |
Maximum throughput defined by this policy. It is specified in terms of IOPS. 0 means no maximum throughput is enforced. |
max_throughput_mbps |
integer |
Maximum throughput defined by this policy. It is specified in terms of Mbps. 0 means no maximum throughput is enforced. |
min_throughput_iops |
integer |
Minimum throughput defined by this policy. It is specified in terms of IOPS. 0 means no minimum throughput is enforced. These floors are not guaranteed on non-AFF platforms or when FabricPool tiering policies are set. |
min_throughput_mbps |
integer |
Minimum throughput defined by this policy. It is specified in terms of Mbps. 0 means no minimum throughput is enforced. |
svm
name |
string |
The name of the SVM. |
uuid |
string |
qos_policy
adaptive |
fixed |
name |
string |
object_count |
integer |
pgid |
integer |
policy_class |
string |
scope |
string |
svm |
uuid |
string |
job_link
uuid |
string |
code |
string |
Argument code |
message |
string |
Message argument |
error
arguments |
array[error_arguments] |
Message arguments |
code |
string |
Error code |
message |
string |
Error message |
target |
string |
