REST API reference
Update a QoS policy
Updates a QoS policy to change its configuration and optimize performance according to your needs.
HTTP method and endpoint
PATCH /storage/qos/policies/{uuid}
Introduced in
ONTAP 9.6
Usage notes
Update a specific QoS policy.
  • qos policy-group modify
  • qos adaptive-policy-group modify
uuid
string
path
True
  • Introduced in: 9.8
return_timeout
integer
query
False
  • Default value: 0
  • Max value: 120
  • Min value: 0
Request Body
Name Type Description
adaptive
adaptive
Adaptive QoS policy-groups define measurable service level objectives (SLOs) that adjust based on the storage object used space and the storage object allocated space.
fixed
fixed
QoS policy-groups define a fixed service level objective (SLO) for a storage object.
name
string
Name of the QoS policy.
object_count
integer
Number of objects attached to this policy.
svm
svm
uuid
string
Example request
  "fixed": {
    "capacity_shared": null
  "name": "extreme",
  "object_count": 0,
  "svm": {
    "name": "svm1",
Status: 202, Accepted
job
job_link
  "job": {
    "uuid": "string"
Status: Default
ONTAP Error Response Codes
Error Code Description
8454147
The maximum limit for QoS policies has been reached.
8454154
The name specified for creating conflicts with an existing QoS policy name.
8454260
Invalid value for maximum and minimum fields. Valid values for max_throughput_iops and max_throughput_mbps combination is for the ratio of max_throughput_mbps and max_throughput_iops to be within 1 to 4096.
8454273
Invalid value for an adaptive field. Value should be non-zero.
8454277
The name specified for creating an adaptive QoS policy conflicts with an existing fixed QoS policy name.
8454278
The name specified for creating a fixed QoS policy conflicts with an existing adaptive QoS policy name.
8454286
Modifications on these cluster scoped preset policies is prohibited.
8454327
The existing fixed QoS policy cannot be modified to an adaptive QoS policy.
8454328
The existing adaptive QoS policy cannot be modified to a fixed QoS policy.
string
adaptive
absolute_min_iops
integer
Specifies the absolute minimum IOPS that is used as an override when the expected_iops is less than this value. These floors are not guaranteed on non-AFF platforms or when FabricPool tiering policies are set.
expected_iops
integer
Expected IOPS. Specifies the minimum expected IOPS per TB allocated based on the storage object allocated size. These floors are not guaranteed on non-AFF platforms or when FabricPool tiering policies are set.
peak_iops
integer
Peak IOPS. Specifies the maximum possible IOPS per TB allocated based on the storage object allocated size or the storage object used size.
fixed
max_throughput_iops
integer
Maximum throughput defined by this policy. It is specified in terms of IOPS. 0 means no maximum throughput is enforced.
max_throughput_mbps
integer
Maximum throughput defined by this policy. It is specified in terms of Mbps. 0 means no maximum throughput is enforced.
min_throughput_iops
integer
Minimum throughput defined by this policy. It is specified in terms of IOPS. 0 means no minimum throughput is enforced. These floors are not guaranteed on non-AFF platforms or when FabricPool tiering policies are set.
min_throughput_mbps
integer
Minimum throughput defined by this policy. It is specified in terms of Mbps. 0 means no minimum throughput is enforced.
svm
name
string
The name of the SVM.
uuid
string
qos_policy
adaptive
adaptive
fixed
fixed
name
string
object_count
integer
svm
svm
uuid
string
uuid
string
The UUID of the asynchronous job that is triggered by a POST, PATCH, or DELETE operation.
code
string
Argument code
message
string
Message argument
error
arguments
array[error_arguments]
Message arguments
code
string
Error code
message
string
Error message
target
string
