Update properties for a qtree
Updates the properties of a specific qtree, modifying its configurations as needed. This operation typically supports tasks such as reorganizing data structures or adjusting security settings within the qtree.
HTTP method and endpoint
PATCH /storage/qtrees/{volume.uuid}/{id}
Introduced in
ONTAP 9.6
Usage notes
Updates properties for a specific qtree.
Related ONTAP commands
qtree modify -
qtree rename
volume.uuid |
string |
path |
True |
Volume UUID |
id |
string |
path |
True |
Qtree ID |
return_timeout |
integer |
query |
False |
Request Body
| Name | Type | Description |
_tags |
array[string] |
Tags are an optional way to track the uses of a resource. Tag values must be formatted as key:value strings. |
export_policy |
Export Policy |
filesystem_path |
string |
Path of the qtree directory. This path is relative to the volume root directory. |
group |
The user set as owner of the qtree. |
id |
integer |
The identifier for the qtree, unique within the qtree's volume. |
name |
string |
The name of the qtree. Required in POST; optional in PATCH. |
nas |
path |
string |
Client visible path to the qtree. This field is not available if the volume does not have a junction-path configured. Not valid in POST or PATCH. This field is to be deprecated and replaced with nas.path. |
qos_policy |
security_style |
string |
Security style. Valid in POST or PATCH. |
unix_permissions |
integer |
The UNIX permissions for the qtree. Valid in POST or PATCH. |
user |
Example request
"_tags": [
"team:csi",
"environment:test"
"export_policy": {
"id": 100,
"name": "default"
"filesystem_path": "/dir1/qtree1",
"group": {
"id": "20001",
"name": "unix_group1"
"id": 1,
"name": "string",
"nas": {
"path": "/volume3/qtree1"
"path": "/volume3/qtree1",
"qos_policy": {
"max_throughput_iops": 10000,
"max_throughput_mbps": 500,
"min_throughput_iops": 2000,
"min_throughput_mbps": 500,
"name": "performance",
"security_style": "string",
"unix_permissions": 493,
"user": {
"id": "10001",
"name": "unix_user1"
Status: 202, Accepted
job |
"job": {
"uuid": "string"
Status: Default
ONTAP Error Response Codes
| Error Code | Description |
262196 |
The request contains a field which cannot be set in this operation. |
262278 |
Required field is missing in the reqeust. |
917505 |
Vserver not found. |
917525 |
The specified volume does not exist in Vserver. |
918235 |
A volume with UUID was not found. |
5242887 |
Failed to modify qtree. |
5242897 |
This operation is not permitted on read-only volume. |
5242898 |
This operation is only permitted on a data Vserver. |
5242902 |
Missing inputs. |
5242915 |
Failed to assign qtree export policy to qtree. |
5242927 |
Unable to find qtree. |
5242945 |
5242951 |
Export policy supplied does not belong to the specified export policy ID. |
5242954 |
Failed to get the qtree from volume. |
5242955 |
The UUID of the volume is required. |
5242956 |
Failed to obtain a qtree with ID. |
5242957 |
Failed to delete the qtree. |
5242958 |
Failed to rename the qtree with ID in the volume and SVM. |
5242959 |
Successfully renamed qtree but the modify operation failed. |
5242965 |
Invalid qtree path. The volume name component of the qtree path, must be the same as the volume specified with the parameter. |
5242967 |
UNIX user or group ID must be 32-bit unsigned integer. |
5242971 |
Qtree was renamed. However, the path modification failed. |
5242972 |
Cannot rename qtree as that name already exists on a volume in the Vserver. |
5242973 |
Cannot rename qtree to name with path concurrently on volume in Vserver, unless non-root qtrees in enabled on the volume. |
5242974 |
Moved qtree. However, other properties were not modified. |
5242975 |
Renamed qtree and moved the qtree. However, other properties were not modified. |
6622064 |
Security-style ntfs is not supported on SnapMirror Business Continuity (SMBC) relationship volume. |
8454348 |
QoS on qtrees is not supported because not all nodes in the cluster can support it. |
9437324 |
The security style unified is not supported. |
23724050 |
Failed to resolve user or group name. |
href |
string |
_links
export_policy
Export Policy
id |
integer |
name |
string |
group
id |
string |
The numeric ID of the group that owns the qtree. Valid in POST or PATCH. |
name |
string |
Alphanumeric group name of group that owns the qtree. Valid in POST or PATCH. |
nas
path |
string |
Client visible path to the qtree. This field is not available if the volume does not have a junction-path configured. Not valid in POST or PATCH. |
qos_policy
max_throughput_iops |
integer |
Specifies the maximum throughput in IOPS, 0 means none. This is mutually exclusive with name and UUID during POST and PATCH. |
max_throughput_mbps |
integer |
Specifies the maximum throughput in Megabytes per sec, 0 means none. This is mutually exclusive with name and UUID during POST and PATCH. |
min_throughput_iops |
integer |
Specifies the minimum throughput in IOPS, 0 means none. Setting "min_throughput" is supported on AFF platforms only, unless FabricPool tiering policies are set. This is mutually exclusive with name and UUID during POST and PATCH. |
min_throughput_mbps |
integer |
Specifies the minimum throughput in Megabytes per sec, 0 means none. This is mutually exclusive with name and UUID during POST and PATCH. |
name |
string |
The QoS policy group name. This is mutually exclusive with UUID and other QoS attributes during POST and PATCH. |
uuid |
string |
The QoS policy group UUID. This is mutually exclusive with name and other QoS attributes during POST and PATCH. |
iops_raw
The number of I/O operations observed at the storage object. This should be used along with delta time to calculate the rate of I/O operations per unit of time.
other |
integer |
Performance metric for other I/O operations. Other I/O operations can be metadata operations, such as directory lookups and so on. |
read |
integer |
Performance metric for read I/O operations. |
total |
integer |
Performance metric aggregated over all types of I/O operations. |
write |
integer |
Peformance metric for write I/O operations. |
throughput_raw
Throughput bytes observed at the storage object. This should be used along with delta time to calculate the rate of throughput bytes per unit of time.
other |
integer |
read |
integer |
total |
integer |
write |
integer |
statistics
These are raw IOPS and throughput performance numbers. These numbers are aggregated across all nodes in the cluster and increase with the uptime of the cluster.
iops_raw |
The number of I/O operations observed at the storage object. This should be used along with delta time to calculate the rate of I/O operations per unit of time. |
status |
string |
Any errors associated with the sample. For example, if the aggregation of data over multiple nodes fails then any of the partial errors might be returned, "ok" on success, or "error" on any internal uncategorized failure. Whenever a sample collection is missed but done at a later time, it is back filled with the next closest collection and tagged with "backfilled_data". "inconsistent_delta_time" is encountered when the time between two collections is not the same for all nodes. Therefore, the aggregated value might be over or under inflated. "negative_delta" is returned when an expected monotonically increasing value has decreased in value. "inconsistent_old_data" is returned when one or more nodes does not have the latest data. |
throughput_raw |
Throughput bytes observed at the storage object. This should be used along with delta time to calculate the rate of throughput bytes per unit of time. |
timestamp |
string |
The timestamp of the performance data. |
svm
Required in POST
name |
string |
The name of the SVM. |
uuid |
string |
user
id |
string |
The numeric ID of the user who owns the qtree. Valid in POST or PATCH. |
name |
string |
Alphanumeric username of user who owns the qtree. Valid in POST or PATCH. |
volume
Required in POST
name |
string |
The name of the volume. |
uuid |
string |
qtree
A qtree is a directory at the top level of a volume to which a custom export policy (for fine-grained access control) and a quota rule can be applied, if required.
_tags |
array[string] |
export_policy |
Export Policy |
filesystem_path |
string |
group |
id |
integer |
name |
string |
nas |
path |
string |
qos_policy |
security_style |
string |
unix_permissions |
integer |
user |
job_link
uuid |
string |
code |
string |
Argument code |
message |
string |
Message argument |
error
arguments |
array[error_arguments] |
Message arguments |
code |
string |
Error code |
message |
string |
Error message |
target |
string |
