REST API reference
Update properties for a qtree
Updates the properties of a specific qtree to modify its configuration according to your requirements. Use this operation to adjust attributes such as security style or export policy for a qtree.
HTTP method and endpoint
PATCH /storage/qtrees/{volume.uuid}/{id}
Introduced in
ONTAP 9.6
Usage notes
Updates properties for a specific qtree.
  • qtree modify
  • qtree rename
volume.uuid
string
path
True
Volume UUID
id
string
path
True
Qtree ID
return_timeout
integer
query
False
  • Default value: 0
  • Max value: 120
  • Min value: 0
Request Body
Name Type Description
_tags
array[string]
Tags are an optional way to track the uses of a resource. Tag values must be formatted as key:value strings.
export_policy
export_policy
Export Policy
group
group
The user set as owner of the qtree.
id
integer
The identifier for the qtree, unique within the qtree's volume.
name
string
The name of the qtree. Required in POST; optional in PATCH.
nas
nas
path
string
Client visible path to the qtree. This field is not available if the volume does not have a junction-path configured. Not valid in POST or PATCH. This field is to be deprecated and replaced with nas.path.
qos_policy
qos_policy
When "min_throughput_iops", "min_throughput_mbps", "max_throughput_iops" or "max_throughput_mbps" attributes are specified, the storage object is assigned to an auto-generated QoS policy group. If the attributes are later modified, the auto-generated QoS policy-group attributes are modified. Attributes can be removed by specifying "0" and policy group by specifying "none". Upon deletion of the storage object or if the attributes are removed, then the QoS policy-group is also removed.
security_style
string
Security style. Valid in POST or PATCH.
unix_permissions
integer
The UNIX permissions for the qtree. Valid in POST or PATCH.
user
user
Example request
  "_tags": [
    "team:csi",
    "environment:test"
  "export_policy": {
    "id": 100,
    "name": "default"
  "group": {
    "id": "20001",
    "name": "unix_group1"
  "id": 1,
  "name": "string",
  "nas": {
    "path": "/volume3/qtree1"
  "path": "/volume3/qtree1",
  "qos_policy": {
    "max_throughput_iops": 10000,
    "max_throughput_mbps": 500,
    "min_throughput_iops": 2000,
    "min_throughput_mbps": 500,
    "name": "performance",
  "security_style": "string",
  "unix_permissions": 493,
  "user": {
    "id": "10001",
    "name": "unix_user1"
Status: 200, Ok
job
job_link
  "job": {
    "uuid": "string"
Status: 202, Accepted
Status: Default
ONTAP Error Response Codes
Error Code Description
262196
The request contains a field which cannot be set in this operation.
262278
Required field is missing in the reqeust.
917505
Vserver not found.
917525
The specified volume does not exist in Vserver.
918235
A volume with UUID was not found.
5242887
Failed to modify qtree.
5242897
This operation is not permitted on read-only volume.
5242898
This operation is only permitted on a data Vserver.
5242902
Missing inputs.
5242915
Failed to assign qtree export policy to qtree.
5242927
Unable to find qtree.
5242945
5242951
Export policy supplied does not belong to the specified export policy ID.
5242954
Failed to get the qtree from volume.
5242955
The UUID of the volume is required.
5242956
Failed to obtain a qtree with ID.
5242957
Failed to delete the qtree.
5242958
Failed to rename the qtree with ID in the volume and SVM.
5242959
Successfully renamed qtree but the modify operation failed.
5242965
Invalid qtree path. The volume name component of the qtree path, must be the same as the volume specified with the parameter.
5242967
UNIX user or group ID must be 32-bit unsigned integer.
5242971
Qtree was renamed. However, the path modification failed.
5242972
Cannot rename qtree as that name already exists on a volume in the Vserver.
5242973
Cannot rename qtree to name with path concurrently on volume in Vserver, unless non-root qtrees in enabled on the volume.
5242974
Moved qtree. However, other properties were not modified.
5242975
Renamed qtree and moved the qtree. However, other properties were not modified.
6622064
Security-style NTFS is not supported on a SnapMirror active sync relationship volume.
8454348
QoS on qtrees is not supported because not all nodes in the cluster can support it.
9437324
The security style unified is not supported.
23724050
Failed to resolve user or group name.
string
export_policy
Export Policy
id
integer
name
string
group
id
string
The numeric ID of the group that owns the qtree. Valid in POST or PATCH.
name
string
Alphanumeric group name of group that owns the qtree. Valid in POST or PATCH.
nas
path
string
qos_policy
max_throughput_iops
integer
Specifies the maximum throughput in IOPS, 0 means none. This is mutually exclusive with name and UUID during POST and PATCH.
max_throughput_mbps
integer
Specifies the maximum throughput in Megabytes per sec, 0 means none. This is mutually exclusive with name and UUID during POST and PATCH.
min_throughput_iops
integer
Specifies the minimum throughput in IOPS, 0 means none. Setting "min_throughput" is supported on AFF platforms only, unless FabricPool tiering policies are set. This is mutually exclusive with name and UUID during POST and PATCH.
min_throughput_mbps
integer
Specifies the minimum throughput in Megabytes per sec, 0 means none. This is mutually exclusive with name and UUID during POST and PATCH.
name
string
The QoS policy group name. This is mutually exclusive with UUID and other QoS attributes during POST and PATCH.
uuid
string
The QoS policy group UUID. This is mutually exclusive with name and other QoS attributes during POST and PATCH.
iops_raw
The number of I/O operations observed at the storage object. This should be used along with delta time to calculate the rate of I/O operations per unit of time.
other
integer
Performance metric for other I/O operations. Other I/O operations can be metadata operations, such as directory lookups and so on.
read
integer
Performance metric for read I/O operations.
total
integer
Performance metric aggregated over all types of I/O operations.
write
integer
Peformance metric for write I/O operations.
throughput_raw
Throughput bytes observed at the storage object. This should be used along with delta time to calculate the rate of throughput bytes per unit of time.
other
integer
read
integer
total
integer
write
integer
statistics
These are raw IOPS and throughput performance numbers. These numbers are aggregated across all nodes in the cluster and increase with the uptime of the cluster.
iops_raw
iops_raw
status
string
Any errors associated with the sample. For example, if the aggregation of data over multiple nodes fails then any of the partial errors might be returned, "ok" on success, or "error" on any internal uncategorized failure. Whenever a sample collection is missed but done at a later time, it is back filled with the next closest collection and tagged with "backfilled_data". "inconsistent_delta_time" is encountered when the time between two collections is not the same for all nodes. Therefore, the aggregated value might be over or under inflated. "negative_delta" is returned when an expected monotonically increasing value has decreased in value. "inconsistent_old_data" is returned when one or more nodes does not have the latest data.
throughput_raw
throughput_raw
timestamp
string
The timestamp of the performance data.
svm
Required in POST
name
string
uuid
string
user
id
string
The numeric ID of the user who owns the qtree. Valid in POST or PATCH.
name
string
Alphanumeric username of user who owns the qtree. Valid in POST or PATCH.
volume
Required in POST
name
string
The name of the volume. This field cannot be specified in a POST or PATCH method.
uuid
string
  • example: 028baa66-41bd-11e9-81d5-00a0986138f7
  • Introduced in: 9.6
  • x-nullable: true
qtree
A qtree is a directory at the top level of a volume to which a custom export policy (for fine-grained access control) and a quota rule can be applied, if required.
_tags
array[string]
export_policy
export_policy
Export Policy
group
group
id
integer
name
string
nas
nas
path
string
qos_policy
qos_policy
security_style
string
unix_permissions
integer
user
user
uuid
string
The UUID of the asynchronous job that is triggered by a POST, PATCH, or DELETE operation.
code
string
Argument code
message
string
Message argument
returned_error
arguments
array[error_arguments]
Message arguments
code
string
Error code
message
string
Error message
target
string
