Updates the ems role-based configuration of the access control role
limit_access_to_global_configs- indicates whether the access control role has limited access to global ems configurations # related ontap commands -
event role-config modify
PATCH /support/ems/role-configs/{access_control_role.name}
Introduced In: 9.13
Updates the EMS role-based configuration of the access control role.
Recommended optional properties
event_filter- Identifies the event filter. -
limit_access_to_global_configs- Indicates whether the access control role has limited access to global EMS configurations.
Related ONTAP commands
access_control_role.name |
string |
path |
True |
Access control role name |
Request Body
| Name | Type | Description |
event_filter |
Event filter that is assigned to the access control role. |
limit_access_to_global_configs |
boolean |
Indicates whether the access control has limited access to global EMS configurations. |
Example request
"event_filter": {
"name": "important-events"
Status: 200, Ok
Status: Default
ONTAP Error Response Codes
| Error Code | Description |
983197 |
The event filter provided is the same as the currently assigned filter. |
983198 |
The event filter provided does not exist. |
href |
string |
_links
access_control_role
Access control role that the event filter is assigned to.
name |
string |
Role name |
event_filter
name |
string |
ems_role_config
event_filter |
boolean |
code |
string |
Argument code |
message |
string |
Message argument |
error
arguments |
array[error_arguments] |
Message arguments |
code |
string |
Error code |
message |
string |
Error message |
target |
string |
