REST API reference
Update the EMS role-based configuration for an access control role
Updates the EMS role-based configuration for an access control role to modify its event filters and access limitations.
HTTP method and endpoint
PATCH /support/ems/role-configs/{access_control_role.name}
Introduced in
ONTAP 9.13
Usage notes
Updates the EMS role-based configuration of the access control role.
  • event_filter - Identifies the event filter.
  • limit_access_to_global_configs - Indicates whether the access control role has limited access to global EMS configurations.
  • event role-config modify
string
path
True
Access control role name
Request Body
Name Type Description
event_filter
event_filter
Event filter that is assigned to the access control role.
boolean
Indicates whether the access control has limited access to global EMS configurations.
Example request
  "event_filter": {
    "name": "important-events"
Status: 200, Ok
Status: Default
ONTAP Error Response Codes
Error Code Description
983197
The event filter provided is the same as the currently assigned filter.
983198
The event filter provided does not exist.
string
access_control_role
Access control role that the event filter is assigned to.
name
string
Role name
event_filter
name
string
ems_role_config
event_filter
event_filter
boolean
code
string
Argument code
message
string
Message argument
returned_error
arguments
array[error_arguments]
Message arguments
code
string
Error code
message
string
Error message
target
string
