REST API reference
Update SVM properties
Updates the properties of an SVM, such as its name, language code, comment, and state, to manage its configuration and behavior effectively. Use this capability to tailor SVM settings to your operational requirements.
HTTP method and endpoint
PATCH /svm/svms/{uuid}
Introduced in
ONTAP 9.6
Usage notes
Updates one or more of the following properties of an individual SVM: SVM name, SVM default volume language code, SVM comment, and SVM state.
  • vserver modify
  • vserver rename
  • vserver start
  • vserver stop
  • security ssl modify
  • vserver add-protocols
  • vserver remove-protocols
  1. Stops an SVM and updates the "comment" field for an individual SVM
  PATCH "/api/svm/svms/f16f0935-5281-11e8-b94d-005056b46485" '{"state":"stopped", "comment":"This SVM is stopped."}'
  1. Starts an SVM and updates the "comment" field for an individual SVM
  PATCH "/api/svm/svms/f16f0935-5281-11e8-b94d-005056b46485" '{"state":"running", "comment":"This SVM is running."}'
  1. Updates the "language" field for an individual SVM
  PATCH "/api/svm/svms/f16f0935-5281-11e8-b94d-005056b46485" '{"language":"en.UTF-8"}'
  1. Updates the "name" field for an SVM or renames the SVM
  PATCH "/api/svm/svms/f16f0935-5281-11e8-b94d-005056b46485" '{"name":"svm_new"}'
  1. Updates the aggregates for an individual SVM
  PATCH "/api/svm/svms/f16f0935-5281-11e8-b94d-005056b46485" '{"aggregates":{"name":["aggr1","aggr2","aggr3"]}}'
  1. Updates the Snapshot copy policy for an individual SVM
  PATCH "/api/svm/svms/f16f0935-5281-11e8-b94d-005056b46485" '{"snapshot_policy":{"name":"custom1"}}'
  1. Updates the TLS certificate for an individual SVM
  PATCH "/api/svm/svms/f16f0935-5281-11e8-b94d-005056b46485" '{"certificate":{"uuid":"1cd8a442-86d1-11e0-ae1c-123478563412"}}'
  1. Updates the QoS policy for the SVM
  PATCH "/api/svm/svms/f16f0935-5281-11e8-b94d-005056b46485" '{"qos_policy_group":{"name":"qpolicy1"}}'
  1. Allows NFS protocol which was previously disallowed for the SVM
  PATCH "/api/svm/svms/f16f0935-5281-11e8-b94d-005056b46485" '{"nfs":{"allowed":"true"}}'
  1. Updates the max volume limit for the SVM
  PATCH "/api/svm/svms/f16f0935-5281-11e8-b94d-005056b46485" '{"max_volumes":"200"}'
  1. Updates whether file system analytics is enabled on all newly created volumes in the SVM.
  PATCH "/api/svm/svms/f16f0935-5281-11e8-b94d-005056b46485" '{"auto_enable_analytics":"true"}'
  1. Updates whether volume activity tracking is enabled on all newly created volumes in the SVM.
  PATCH "/api/svm/svms/f16f0935-5281-11e8-b94d-005056b46485" '{"auto_enable_activity_tracking":"true"}'
  1. Updates the QoS adaptive policy group template for the SVM.
  PATCH "/api/svm/svms/f16f0935-5281-11e8-b94d-005056b46485" '{"qos_adaptive_policy_group_template":{"name":"aqpolicy1"}}'
  1. Updates the maximum storage permitted on a single SVM.
  PATCH "/api/svm/svms/f16f0935-5281-11e8-b94d-005056b46485" '{"storage_limit":"40GB"}'
  1. Updates the percentage of storage capacity at which an alert message is sent.
  PATCH "/api/svm/svms/f16f0935-5281-11e8-b94d-005056b46485" '{"storage_limit":"400MB", "storage_limit_threshold_alert":"98"}'
Learn more
uuid
string
path
True
Filter by UUID
return_timeout
integer
query
False
  • Default value: 0
  • Max value: 120
  • Min value: 0
Request Body
Name Type Description
aggregates
array[aggregates]
List of allowed aggregates for SVM volumes. An administrator is allowed to create volumes on these aggregates.
aggregates_delegated
boolean
This property is true when the administrator has delegated the aggregates for the SVM volumes.
anti_ransomware_auto_switch_duration_without_new_file_extension
integer
One of the many conditions to be satisfied to automatically switch the anti-ransomware state of the volumes in this SVM from “learning” (dry-run) to “enabled” is that no new file-extensions are observed in the volume in recent time. This parameter optionally specifies the recent time duration (in days) to be considered during which no new file-extension should be observed in a given volume to automatically switch the anti-ransomware state from '`learning`" to “enabled”.
anti_ransomware_auto_switch_from_learning_to_enabled
boolean
This property specifies whether anti-ransomware state of the volumes in this SVM are automatically switched by the system from “learning” (dry-run) to “enabled” (active) state after sufficient learning.
anti_ransomware_auto_switch_minimum_file_count
integer
One of the many conditions to be satisfied to automatically switch the anti-ransomware state of the volumes in this SVM from “learning” (dry-run) to “enabled” is that the volume should have a minimum file count in “learning” state. This parameter optionally specifies the minimum number of newly created files in “learning” state in a given volume to automatically switch the anti-ransomware state from “learning” to “enabled”.
anti_ransomware_auto_switch_minimum_file_extension
integer
One of the many conditions to be satisfied to automatically switch the anti-ransomware state of the volumes in this SVM from “learning” (dry-run) to “enabled” is that the volume should have minimum number of file extensions in “learning” state. This parameter optionally specifies the minimum number of new file extensions in “learning” state in a given volume to automatically switch the anti-ransomware state from “learning” to “enabled”.
anti_ransomware_auto_switch_minimum_learning_period
integer
One of the many conditions to be satisfied to automatically switch the anti-ransomware state of the volumes in this SVM from “learning” (dry-run) to “enabled” is that the volume should be in “learning” state for sufficient time period. This parameter optionally specifies the minimum number of days a given volume should be in “learning” state to automatically switch the anti-ransomware state from “learning” to “enabled”.
anti_ransomware_default_volume_state
string
Specifies the default Anti-ransomware state of the volumes in the SVM. Default "anti_ransomware_default_volume_state" property is disabled for POST operation. If this value is "disabled", Anti-ransomware protection is disabled by default on the new volumes that are created in the SVM. If this value is "dry_run", Anti-ransomware protection is in learning mode by default on the new volumes that are created in the SVM. When the Anti-ransomware license is not present, this property is ignored and volumes will be created with the "disabled" state.
anti_ransomware_incoming_write_threshold
string
One of the many conditions to be satisfied to automatically switch the anti-ransomware state of the volumes in this SVM from “learning” (dry-run) to “enabled” is that the volume should have sufficient data ingested to do the learning. This parameter optionally specifies the minimum amount of data (in GB) to be written to a given volume during the learning period to automatically switch the anti-ransomware state from “learning” to “enabled”. The amount of data considered as ingested also includes the data that is deleted or overwritten after ingestion.
anti_ransomware_incoming_write_threshold_percent
string
One of the many conditions to be satisfied to automatically switch the anti-ransomware state of the volumes in this SVM from “learning” (dry-run) to “enabled” is that the volume should have sufficient data ingested to do the learning. This parameter optionally specifies the minimum amount of data (in percentage) to be written to a given volume during the learning period to automatically switch the anti-ransomware state from “learning” to “enabled”. The amount of data considered as ingested also includes the data that is deleted or overwritten after ingestion.
boolean
Specifies whether volume activity tracking is automatically enabled on volumes that are created in the SVM.
boolean
Specifies whether file system analytics is automatically enabled on volumes that are created in the SVM.
certificate
certificate
Support for this field will be removed in a future release. Please use /svm/svms/{svm.uuid}/web for this field. Certificate for incoming TLS connection requests.
cifs
cifs
comment
string
Comment
fc_interfaces
array[fc_interface_svm]
FC Interface for the SVM
fcp
fcp
ip_interfaces
array[ip_interface_svm]
IP interfaces for the SVM
is_space_enforcement_logical
boolean
Indicates whether logical space enforcement for the SVM is enabled.
is_space_reporting_logical
boolean
Indicates whether logical space reporting for the SVM is enabled.
iscsi
iscsi
language
string
Default volume language code. UTF-8 encoded languages are valid in POST or PATCH. Non UTF-8 language encodings are for backward compatibility and are not valid input for POST and PATCH requests.
max_volumes
string
This property is used by cluster administrator to specify the limit on maximum number of volumes allowed in the SVM. The value can be either the string "unlimited" or a number.
name
string
The name of the SVM.
ndmp
ndmp
nfs
nfs
nsswitch
nsswitch
Name service switch configuration
number_of_volumes_in_recovery_queue
integer
Number of volumes in the recovery queue.
nvme
nvme
This optionally specifies which QoS adaptive policy group to apply to the SVM as a template. This policy group will then be assigned to volumes created or rehosted into this SVM. This policy group defines measurable service level objectives (SLOs) and Service Level Agreements (SLAs) that adjust based on the volume allocated space or used space.
qos_policy
qos_policy
This optionally specifies which QoS policy group to apply to the Vserver. This policy group defines measurable service level objectives (SLOs) that apply to the storage objects with which the policy group is associated.
snapmirror
snapmirror
Specifies attributes for SVM DR protection.
snapshot_policy
snapshot_policy
This is a reference to the Snapshot copy policy.
state
string
SVM State
storage
storage
total_volume_size_in_recovery_queue
integer
Sum of the sizes of the volumes in the recovery queue.
uuid
string
Example request
  "aggregates": [
      "available_size": 10156560384,
      "name": "aggr1",
  "anti_ransomware_default_volume_state": "string",
  "anti_ransomware_incoming_write_threshold": "string",
  "anti_ransomware_incoming_write_threshold_percent": "string",
  "certificate": {
    "name": "cert1",
  "cifs": {
    "domain_workgroup": "string",
    "enabled": true
  "comment": "string",
  "fc_interfaces": [
  "fcp": {
    "enabled": true
  "ip_interfaces": [
      "services": [
        "data_nfs"
      "subnet": {
        "name": "subnet1",
  "iscsi": {
    "enabled": true
  "language": "c.utf_8",
  "max_volumes": "string",
  "name": "svm1",
  "nfs": {
    "enabled": true
  "nsswitch": {
    "group": [
      "string"
    "hosts": [
      "string"
    "namemap": [
      "string"
    "netgroup": [
      "string"
    "passwd": [
      "string"
  "number_of_volumes_in_recovery_queue": 0,
  "nvme": {
    "enabled": true
  "qos_adaptive_policy_group_template": {
    "max_throughput_iops": 10000,
    "max_throughput_mbps": 500,
    "min_throughput_iops": 2000,
    "min_throughput_mbps": 500,
    "name": "performance",
  "qos_policy": {
  "snapmirror": {
    "protected_volumes_count": 0
  "snapshot_policy": {
    "name": "default",
  "state": "running",
  "storage": {
    "allocated": 0,
    "available": 0,
    "used_percentage": 0
  "total_volume_size_in_recovery_queue": 0,
Status: 202, Accepted
job
job_link
  "job": {
    "uuid": "string"
Status: Default
ONTAP Error Response Codes
Error codes Description
13434880
Failed to modify SVM parameters.
13434881
Failed to rename SVM.
13434883
SVM parameters except name modified successfully.
13434885
Non-UTF8 language(s) not supported.
13434886
Invalid Snapshot copy policy.
13434902
Modification of NSSwitch parameters failed for the SVM.
13434906
Operation not supported for an SVM of type sync-destination.
12451843
Certificate does not exist.
13434908
Invalid SVM name. The name is already in use by another SVM, IPSpace or cluster.
13434916
SVM is in the process of being created. Wait a few minutes, and then try the command again.
13434915
Failed to unlock the SVM because SVM create or delete job is in progress. Wait a few minutes, and then try the command again.
13434911
Invalid SVM name. Maximum supported length is 41 if SVM is of type \"sync-source\", otherwise 47.
string
aggregates
available_size
integer
Space available, in bytes.
name
string
uuid
string
certificate
name
string
Certificate name
uuid
string
Certificate UUID
ad_domain
default_site
string
The default site used by LIFs that do not have a site membership.
cifs
allowed
boolean
If this is set to true, an SVM administrator can manage the CIFS service. If it is false, only the cluster administrator can manage the service.
domain_workgroup
string
The NetBIOS name of the domain or workgroup associated with the CIFS server.
dns
domains
array[string]
A list of DNS domains. Domain names have the following requirements:
  • The name must contain only the following characters: A through Z, a through z, 0 through 9, ".", "-" or "_".
  • The first character of each label, delimited by ".", must be one of the following characters: A through Z or a through z or 0 through 9.
  • The last character of each label, delimited by ".", must be one of the following characters: A through Z, a through z, or 0 through 9.
  • The top level domain must contain only the following characters: A through Z, a through z.
  • The system reserves the following names:"all", "local", and "localhost".
servers
array[string]
The list of IP addresses of the DNS servers. Addresses can be either IPv4 or IPv6 addresses.
node
The node on which the FC port is located.
name
string
The name of the node on which the FC port is located.
fc_port_reference
An FC port is the physical port of an FC adapter on a cluster node that can be connected to an FC network.
name
string
The name of the FC port.
node
node
uuid
string
The unique identifier of the FC port.
location
The location of the Fibre Channel interface is defined by the location of its port.
port
fc_port_reference
fc_interface_svm
uuid
string
The unique identifier of the Fibre Channel interface.
fcp
allowed
boolean
If this is set to true, an SVM administrator can manage the FCP service. If it is false, only the cluster administrator can manage the service.
ip
IP information
broadcast_domain
name
string
Name of the broadcast domain, scoped to its IPspace
uuid
string
Broadcast domain UUID
home_node
name
string
uuid
string
location
Home_node is optional.
broadcast_domain
broadcast_domain
home_node
home_node
ip_subnet_reference
A named subnet. Either UUID or name can be supplied on input.
name
string
The name of the subnet. If only the name is provided, the IPspace scope must be provided by the object this object is embedded in.
uuid
string
The UUID that uniquely identifies the subnet.
ip_interface_svm
Interface parameters. Name and home_node are optional.
ip
ip
IP information
services
array[string]
The services associated with the interface.
subnet
ip_subnet_reference
uuid
string
The UUID that uniquely identifies the interface.
ipspace
Either the UUID or name may be supplied on input.
name
string
IPspace name
uuid
string
IPspace UUID
iscsi
allowed
boolean
If this is set to true, an SVM administrator can manage the iSCSI service. If it is false, only the cluster administrator can manage the service.
ldap
ad_domain
string
This parameter specifies the name of the Active Directory domain used to discover LDAP servers for use by this client. This is mutually exclusive with servers during POST.
base_dn
string
Specifies the default base DN for all searches.
bind_dn
string
Specifies the user that binds to the LDAP servers. SVM API supports anonymous binding. For Simple and SASL LDAP binding, use the LDAP API endpoint.
enabled
boolean
Enable LDAP? Setting to true creates a configuration if not already created.
restrict_discovery_to_site
boolean
Specifies whether or not LDAP server discovery is restricted to site-scope.
servers
array[string]
ndmp
allowed
boolean
If this is set to true, an SVM administrator can manage the NDMP service. If it is false, only the cluster administrator can manage the service.
nfs
allowed
boolean
If this is set to true, an SVM administrator can manage the NFS service. If it is false, only the cluster administrator can manage the service.
nis
domain
string
The NIS domain to which this configuration belongs.
enabled
boolean
Enable NIS? Setting to true creates a configuration if not already created.
servers
array[string]
A list of hostnames or IP addresses of NIS servers used by the NIS domain configuration.
nsswitch
group
array[string]
Group sources
hosts
array[string]
Host sources
namemap
array[string]
NameMap sources
netgroup
array[string]
NetGroup sources
passwd
array[string]
Password sources
nvme
allowed
boolean
If this is set to true, an SVM administrator can manage the NVMe service. If it is false, only the cluster administrator can manage the service.
max_throughput_iops
integer
Specifies the maximum throughput in IOPS, 0 means none. This is mutually exclusive with name and UUID during POST and PATCH.
max_throughput_mbps
integer
Specifies the maximum throughput in Megabytes per sec, 0 means none. This is mutually exclusive with name and UUID during POST and PATCH.
min_throughput_iops
integer
Specifies the minimum throughput in IOPS, 0 means none. Setting "min_throughput" is supported on AFF platforms only, unless FabricPool tiering policies are set. This is mutually exclusive with name and UUID during POST and PATCH.
min_throughput_mbps
integer
Specifies the minimum throughput in Megabytes per sec, 0 means none. This is mutually exclusive with name and UUID during POST and PATCH.
name
string
The QoS policy group name. This is mutually exclusive with UUID and other QoS attributes during POST and PATCH.
uuid
string
The QoS policy group UUID. This is mutually exclusive with name and other QoS attributes during POST and PATCH.
qos_policy
max_throughput_iops
integer
max_throughput_mbps
integer
min_throughput_iops
integer
min_throughput_mbps
integer
name
string
uuid
string
ip_info
IP information
address
string
netmask
string
Input as netmask length (16) or IPv4 mask (255.255.0.0). For IPv6, the default value is 64 with a valid range of 1 to 127. Output is always netmask length.
network_route_for_svm
destination
ip_info
IP information
gateway
string
The IP address of the gateway router leading to the destination.
certificate
Specifies the certificate that will be used for creating HTTPS connections to the S3 server.
name
string
Certificate name
uuid
string
Certificate UUID
s3
certificate
certificate
default_unix_user
string
Specifies the default UNIX user for NAS Access.
default_win_user
string
Specifies the default Windows user for NAS Access.
enabled
boolean
Specifies whether or not to enable S3. Setting this value to true creates a service if one is not yet created.
is_http_enabled
boolean
Specifies whether HTTP is enabled on the S3 server. By default, HTTP is disabled on the S3 server.
is_https_enabled
boolean
Specifies whether HTTPS is enabled on the S3 server. By default, HTTPS is enabled on the S3 server.
name
string
Specifies the name of the S3 server. A server name length can range from 1 to 253 characters and can only contain the following combination of characters 0-9, A-Z, a-z, ".", and "-".
port
integer
Specifies the HTTP listener port for the S3 server. By default, HTTP is enabled on port 80.
secure_port
integer
Specifies the HTTPS listener port for the S3 server. By default, HTTPS is enabled on port 443.
snapmirror
is_protected
boolean
Specifies whether the SVM is a SnapMirror source SVM, using SnapMirror to protect its data.
integer
Specifies the number of SVM DR protected volumes in the SVM.
snapshot_policy
name
string
uuid
string
storage
allocated
integer
Total size of the volumes in SVM, in bytes.
available
integer
Currently available storage capacity in SVM, in bytes.
limit
integer
Maximum storage permitted on a single SVM, in bytes.
integer
Indicates at what percentage of storage capacity an alert message is sent. The default value is 90.
limit_threshold_exceeded
boolean
Indicates whether the total storage capacity exceeds the alert percentage.
used_percentage
integer
The percentage of storage capacity used.
svm
aggregates
array[aggregates]
boolean
integer
boolean
integer
integer
integer
string
string
string
boolean
boolean
certificate
certificate
cifs
cifs
comment
string
Comment
fc_interfaces
fcp
fcp
ip_interfaces
boolean
boolean
iscsi
iscsi
language
string
max_volumes
string
name
string
ndmp
ndmp
nfs
nfs
nsswitch
nsswitch
integer
nvme
nvme
qos_policy
qos_policy
snapmirror
snapmirror
snapshot_policy
snapshot_policy
state
string
SVM State
storage
storage
integer
uuid
string
uuid
string
The UUID of the asynchronous job that is triggered by a POST, PATCH, or DELETE operation.
code
string
Argument code
message
string
Message argument
error
arguments
array[error_arguments]
Message arguments
code
string
Error code
message
string
Error message
target
string
