Update SVM properties
Updates the properties of a specific SVM, such as its name, default volume language code, comment, and state. This enables you to configure the SVM according to your requirements, whether you need to modify its operational state or adjust its settings for better alignment with your storage environment.
HTTP method and endpoint
PATCH /svm/svms/{uuid}
Introduced in
ONTAP 9.6
Usage notes
Updates one or more of the following properties of an individual SVM: SVM name, SVM default volume language code, SVM comment, and SVM state.
Related ONTAP commands
vserver modify -
vserver rename -
vserver start -
vserver stop -
security ssl modify -
vserver add-protocols -
vserver remove-protocols
Stops an SVM and updates the "comment" field for an individual SVM
PATCH "/api/svm/svms/f16f0935-5281-11e8-b94d-005056b46485" '{"state":"stopped", "comment":"This SVM is stopped."}'
Starts an SVM and updates the "comment" field for an individual SVM
PATCH "/api/svm/svms/f16f0935-5281-11e8-b94d-005056b46485" '{"state":"running", "comment":"This SVM is running."}'
Updates the "language" field for an individual SVM
PATCH "/api/svm/svms/f16f0935-5281-11e8-b94d-005056b46485" '{"language":"en.UTF-8"}'
Updates the "name" field for an SVM or renames the SVM
PATCH "/api/svm/svms/f16f0935-5281-11e8-b94d-005056b46485" '{"name":"svm_new"}'
Updates the aggregates for an individual SVM
PATCH "/api/svm/svms/f16f0935-5281-11e8-b94d-005056b46485" '{"aggregates":["{"name":aggr1"},{"name":"aggr2"},{"name":"aggr3"}]}'
Updates the snapshot policy for an individual SVM
PATCH "/api/svm/svms/f16f0935-5281-11e8-b94d-005056b46485" '{"snapshot_policy":{"name":"custom1"}}'
Updates the TLS certificate for an individual SVM
PATCH "/api/svm/svms/f16f0935-5281-11e8-b94d-005056b46485" '{"certificate":{"uuid":"1cd8a442-86d1-11e0-ae1c-123478563412"}}'
Updates the QoS policy for the SVM
PATCH "/api/svm/svms/f16f0935-5281-11e8-b94d-005056b46485" '{"qos_policy_group":{"name":"qpolicy1"}}'
Allows NFS protocol which was previously disallowed for the SVM
PATCH "/api/svm/svms/f16f0935-5281-11e8-b94d-005056b46485" '{"nfs":{"allowed":"true"}}'
Updates the max volume limit for the SVM
PATCH "/api/svm/svms/f16f0935-5281-11e8-b94d-005056b46485" '{"max_volumes":"200"}'
Updates whether file system analytics is enabled on all newly created volumes in the SVM.
PATCH "/api/svm/svms/f16f0935-5281-11e8-b94d-005056b46485" '{"auto_enable_analytics":"true"}'
Updates whether volume activity tracking is enabled on all newly created volumes in the SVM.
PATCH "/api/svm/svms/f16f0935-5281-11e8-b94d-005056b46485" '{"auto_enable_activity_tracking":"true"}'
Updates the QoS adaptive policy group template for the SVM.
PATCH "/api/svm/svms/f16f0935-5281-11e8-b94d-005056b46485" '{"qos_adaptive_policy_group_template":{"name":"aqpolicy1"}}'
Updates the maximum storage permitted on a single SVM.
PATCH "/api/svm/svms/f16f0935-5281-11e8-b94d-005056b46485" '{"storage":{"limit":"40GB"}}'
Updates the percentage of storage capacity at which an alert message is sent.
PATCH "/api/svm/svms/f16f0935-5281-11e8-b94d-005056b46485" '{"storage":{"limit":"400MB", "limit_threshold_alert":"98"}}'
Updates the QoS policy group template for the SVM.
PATCH "/api/svm/svms/f16f0935-5281-11e8-b94d-005056b46485" '{"qos_policy_group_template":{"name":"policy1"}}'
Learn more
uuid |
string |
path |
True |
Filter by UUID |
return_timeout |
integer |
query |
False |
Request Body
| Name | Type | Description |
aggregates |
array[aggregates] |
List of allowed aggregates for SVM volumes. An administrator is allowed to create volumes on these aggregates. |
aggregates_delegated |
boolean |
This property is true when the administrator has delegated the aggregates for the SVM volumes. |
anti_ransomware |
Anti-ransomware related information for the SVM. |
anti_ransomware_auto_switch_duration_without_new_file_extension |
integer |
One of the many conditions to be satisfied to automatically switch the anti-ransomware state of the volumes in this SVM from “learning” (dry-run) to “enabled” is that no new file-extensions are observed in the volume in recent time. This parameter optionally specifies the recent time duration (in days) to be considered during which no new file-extension should be observed in a given volume to automatically switch the anti-ransomware state from '`learning`" to “enabled”. |
anti_ransomware_auto_switch_from_learning_to_enabled |
boolean |
This property specifies whether anti-ransomware state of the volumes in this SVM are automatically switched by the system from “learning” (dry-run) to “enabled” (active) state after sufficient learning. |
anti_ransomware_auto_switch_minimum_file_count |
integer |
One of the many conditions to be satisfied to automatically switch the anti-ransomware state of the volumes in this SVM from “learning” (dry-run) to “enabled” is that the volume should have a minimum file count in “learning” state. This parameter optionally specifies the minimum number of newly created files in “learning” state in a given volume to automatically switch the anti-ransomware state from “learning” to “enabled”. |
anti_ransomware_auto_switch_minimum_file_extension |
integer |
One of the many conditions to be satisfied to automatically switch the anti-ransomware state of the volumes in this SVM from “learning” (dry-run) to “enabled” is that the volume should have minimum number of file extensions in “learning” state. This parameter optionally specifies the minimum number of new file extensions in “learning” state in a given volume to automatically switch the anti-ransomware state from “learning” to “enabled”. |
anti_ransomware_auto_switch_minimum_incoming_data |
string |
One of the many conditions to be satisfied to automatically switch the anti-ransomware state of the volumes in this SVM from “learning” (dry-run) to “enabled” is that the volume should have sufficient data ingested to do the learning. This parameter optionally specifies the minimum amount of data (in GB) to be written to a given volume during the learning period to automatically switch the anti-ransomware state from “learning” to “enabled”. The amount of data considered as ingested also includes the data that is deleted or overwritten after ingestion. |
anti_ransomware_auto_switch_minimum_learning_period |
integer |
One of the many conditions to be satisfied to automatically switch the anti-ransomware state of the volumes in this SVM from “learning” (dry-run) to “enabled” is that the volume should be in “learning” state for sufficient time period. This parameter optionally specifies the minimum number of days a given volume should be in “learning” state to automatically switch the anti-ransomware state from “learning” to “enabled”. |
anti_ransomware_default_volume_state |
string |
Specifies the default Anti-ransomware state of the volumes in the SVM. Default "anti_ransomware_default_volume_state" property is disabled for POST operation. If this value is "disabled", Anti-ransomware protection is disabled by default on the new volumes that are created in the SVM. If this value is "dry_run", Anti-ransomware protection is in learning mode by default on the new volumes that are created in the SVM. When the Anti-ransomware license is not present, this property is ignored and volumes will be created with the "disabled" state. |
anti_ransomware_incoming_write_threshold |
string |
One of the many conditions to be satisfied to automatically switch the anti-ransomware state of the volumes in this SVM from “learning” (dry-run) to “enabled” is that the volume should have sufficient data ingested to do the learning. This parameter optionally specifies the minimum amount of data (in GB) to be written to a given volume during the learning period to automatically switch the anti-ransomware state from “learning” to “enabled”. The amount of data considered as ingested also includes the data that is deleted or overwritten after ingestion. This field is no longer supported. |
anti_ransomware_incoming_write_threshold_percent |
string |
One of the many conditions to be satisfied to automatically switch the anti-ransomware state of the volumes in this SVM from “learning” (dry-run) to “enabled” is that the volume should have sufficient data ingested to do the learning. This parameter optionally specifies the minimum amount of data (in percentage) to be written to a given volume during the learning period to automatically switch the anti-ransomware state from “learning” to “enabled”. The amount of data considered as ingested also includes the data that is deleted or overwritten after ingestion. |
auto_enable_activity_tracking |
boolean |
Specifies whether volume activity tracking is automatically enabled on volumes that are created in the SVM. |
auto_enable_analytics |
boolean |
Specifies whether file system analytics is automatically enabled on volumes that are created in the SVM. |
certificate |
Support for this field will be removed in a future release. Please use /svm/svms/{svm.uuid}/web for this field. Certificate for incoming TLS connection requests. |
cifs |
comment |
string |
Comment |
fc_interfaces |
array[fc_interface_svm] |
FC Interface for the SVM |
fcp |
Platform Specifics
ip_interfaces |
array[ip_interface_svm] |
IP interfaces for the SVM |
is_space_enforcement_logical |
boolean |
Indicates whether logical space enforcement for the SVM is enabled. |
is_space_reporting_logical |
boolean |
Indicates whether logical space reporting for the SVM is enabled. |
iscsi |
Platform Specifics
language |
string |
Default volume language code. UTF-8 encoded languages are valid in POST or PATCH. Non UTF-8 language encodings are for backward compatibility and are not valid input for POST and PATCH requests. |
max_volumes |
string |
This property is used by cluster administrator to specify the limit on maximum number of volumes allowed in the SVM. The value can be either the string "unlimited" or a number. |
name |
string |
The name of the SVM. |
ndmp |
nfs |
nsswitch |
Name service switch configuration |
number_of_volumes_in_recovery_queue |
integer |
Number of volumes in the recovery queue. |
nvme |
Platform Specifics
qos_adaptive_policy_group_template |
This optionally specifies which QoS adaptive policy group to apply to the SVM as a template. This policy group will then be assigned to volumes created or rehosted into this SVM. This policy group defines measurable service level objectives (SLOs) and Service Level Agreements (SLAs) that adjust based on the volume allocated space or used space. |
qos_policy |
This optionally specifies which QoS policy group to apply to the Vserver. This policy group defines measurable service level objectives (SLOs) that apply to the storage objects with which the policy group is associated. |
qos_policy_group_template |
This optionally specifies which QoS non-shared policy group to apply to the SVM as a template. This policy group is then assigned to volumes created or rehosted into this SVM. This policy group defines measurable service level objectives (SLOs) and Service Level Agreements (SLAs). |
snapmirror |
Specifies attributes for SVM DR protection. |
snapshot_policy |
This is a reference to the snapshot policy. |
state |
string |
SVM State |
storage |
total_volume_size_in_recovery_queue |
integer |
Sum of the sizes of the volumes in the recovery queue. |
uuid |
string |
Example request
"aggregates": [
"available_size": 10156560384,
"name": "aggr1",
"snaplock_type": "string",
"state": "string",
"type": "string",
"anti_ransomware_auto_switch_minimum_incoming_data": "string",
"anti_ransomware_default_volume_state": "string",
"anti_ransomware_incoming_write_threshold": "string",
"anti_ransomware_incoming_write_threshold_percent": "string",
"certificate": {
"name": "string",
"cifs": {
"auth-style": "domain",
"domain_workgroup": "string",
"enabled": true,
"workgroup": "workgrp1"
"comment": "string",
"fc_interfaces": [
"fcp": {
"enabled": true
"ip_interfaces": [
"services": [
"data_nfs"
"subnet": {
"name": "subnet1",
"iscsi": {
"enabled": true
"language": "c.utf_8",
"max_volumes": "string",
"name": "svm1",
"nfs": {
"enabled": true
"nsswitch": {
"group": [
"string"
"hosts": [
"string"
"namemap": [
"string"
"netgroup": [
"string"
"passwd": [
"string"
"number_of_volumes_in_recovery_queue": 0,
"nvme": {
"enabled": true
"qos_adaptive_policy_group_template": {
"max_throughput_iops": 10000,
"max_throughput_mbps": 500,
"min_throughput_iops": 2000,
"min_throughput_mbps": 500,
"name": "performance",
"qos_policy": {
"qos_policy_group_template": {
"snapmirror": {
"protected_consistency_group_count": 0,
"protected_volumes_count": 0
"snapshot_policy": {
"name": "default",
"state": "running",
"storage": {
"allocated": 0,
"available": 0,
"used_percentage": 0
"total_volume_size_in_recovery_queue": 0,
Status: 202, Accepted
Status: Default
ONTAP Error Response Codes
| Error codes | Description |
13434880 |
Failed to modify SVM parameters. |
13434881 |
Failed to rename SVM. |
13434883 |
SVM parameters except name modified successfully. |
13434885 |
Non-UTF8 language(s) not supported. |
13434886 |
Invalid snapshot policy. |
13434902 |
Modification of NSSwitch parameters failed for the SVM. |
13434906 |
Operation not supported for an SVM of type sync-destination. |
12451843 |
Certificate does not exist. |
13434908 |
Invalid SVM name. The name is already in use by another SVM, IPSpace or cluster. |
13434916 |
SVM is in the process of being created. Wait a few minutes, and then try the command again. |
13434915 |
Failed to unlock the SVM because SVM create or delete job is in progress. Wait a few minutes, and then try the command again. |
13434911 |
Invalid SVM name. Maximum supported length is 41 if SVM is of type \"sync-source\", otherwise 47. |
262179 |
Unexpected argument "storage_limit". |
13434935 |
FCP, iSCSI and NVMe cannot be disabled or disallowed on this platform. |
23724038 |
Invalid source for the provided ns-switch database. |
href |
string |
_links
aggregates
available_size |
integer |
Space available, in bytes. |
name |
string |
snaplock_type |
string |
SnapLock type. |
state |
string |
Aggregate state. |
type |
string |
Type of aggregate. |
uuid |
string |
event_log
is_enabled_on_new_file_extension_seen |
boolean |
Specifies whether to send an EMS when a new file extension is discovered. |
is_enabled_on_snapshot_copy_creation |
boolean |
Specifies whether to send an EMS when a snapshot is created. |
arw_vserver
event_log |
certificate
name |
string |
Certificate name |
uuid |
string |
Certificate UUID |
ad_domain
default_site |
string |
The default site used by LIFs that do not have a site membership. |
cifs
allowed |
boolean |
If this is set to true, an SVM administrator can manage the CIFS service. If it is false, only the cluster administrator can manage the service. |
auth-style |
string |
Authentication type. |
domain_workgroup |
string |
The NetBIOS name of the domain or workgroup associated with the CIFS server. |
workgroup |
string |
The workgroup name. |
dns
domains |
array[string] |
A list of DNS domains. Domain names have the following requirements:
servers |
array[string] |
The list of IP addresses of the DNS servers. Addresses can be either IPv4 or IPv6 addresses. |
node
The node on which the FC port is located.
name |
string |
The name of the node on which the FC port is located. |
fc_port_reference
An FC port is the physical port of an FC adapter on a cluster node that can be connected to an FC network.
name |
string |
The name of the FC port. |
node |
The node on which the FC port is located. |
uuid |
string |
The unique identifier of the FC port. |
location
The location of the Fibre Channel interface is defined by the location of its port.
port |
An FC port is the physical port of an FC adapter on a cluster node that can be connected to an FC network. |
fc_interface_svm
uuid |
string |
The unique identifier of the Fibre Channel interface. |
fcp
=== Platform Specifics
Unified ONTAP: Available for GET, POST and PATCH.
allowed |
boolean |
If this is set to true, an SVM administrator can manage the FCP service. If it is false, only the cluster administrator can manage the service. |
ip
IP information
broadcast_domain
Broadcast domain UUID along with a readable name.
name |
string |
Name of the broadcast domain, scoped to its IPspace |
uuid |
string |
Broadcast domain UUID |
home_node
name |
string |
uuid |
string |
port_svm
name |
string |
uuid |
string |
location
Home_node is optional.
broadcast_domain |
Broadcast domain UUID along with a readable name. |
home_node |
home_port |
ip_subnet_reference
A named subnet. Either UUID or name can be supplied on input.
name |
string |
The name of the subnet. If only the name is provided, the IPspace scope must be provided by the object this object is embedded in. |
uuid |
string |
The UUID that uniquely identifies the subnet. |
ip_interface_svm
Interface parameters. Name and home_node are optional.
ip |
IP information |
services |
array[string] |
The services associated with the interface. |
subnet |
A named subnet. Either UUID or name can be supplied on input. |
uuid |
string |
The UUID that uniquely identifies the interface. |
ipspace
Either the UUID or name may be supplied on input.
name |
string |
IPspace name |
uuid |
string |
IPspace UUID |
iscsi
allowed |
boolean |
If this is set to true, an SVM administrator can manage the iSCSI service. If it is false, only the cluster administrator can manage the service. |
ldap
ad_domain |
string |
This parameter specifies the name of the Active Directory domain
used to discover LDAP servers for use by this client.
This is mutually exclusive with |
base_dn |
string |
Specifies the default base DN for all searches. |
bind_dn |
string |
Specifies the user that binds to the LDAP servers. SVM API supports anonymous binding. For Simple and SASL LDAP binding, use the LDAP API endpoint. |
enabled |
boolean |
Enable LDAP? Setting to true creates a configuration if not already created. |
restrict_discovery_to_site |
boolean |
Specifies whether or not LDAP server discovery is restricted to site-scope. |
servers |
array[string] |
ndmp
allowed |
boolean |
If this is set to true, an SVM administrator can manage the NDMP service. If it is false, only the cluster administrator can manage the service. |
nfs
allowed |
boolean |
If this is set to true, an SVM administrator can manage the NFS service. If it is false, only the cluster administrator can manage the service. |
nis
domain |
string |
The NIS domain to which this configuration belongs. |
enabled |
boolean |
Enable NIS? Setting to true creates a configuration if not already created. |
servers |
array[string] |
A list of hostnames or IP addresses of NIS servers used by the NIS domain configuration. |
nsswitch
group |
array[string] |
Group sources |
hosts |
array[string] |
Host sources |
namemap |
array[string] |
NameMap sources |
netgroup |
array[string] |
NetGroup sources |
passwd |
array[string] |
Password sources |
nvme
allowed |
boolean |
If this is set to true, an SVM administrator can manage the NVMe service. If it is false, only the cluster administrator can manage the service. |
max_throughput_iops |
integer |
Specifies the maximum throughput in IOPS, 0 means none. This is mutually exclusive with name and UUID during POST and PATCH. |
max_throughput_mbps |
integer |
Specifies the maximum throughput in Megabytes per sec, 0 means none. This is mutually exclusive with name and UUID during POST and PATCH. |
min_throughput_iops |
integer |
Specifies the minimum throughput in IOPS, 0 means none. Setting "min_throughput" is supported on AFF platforms only, unless FabricPool tiering policies are set. This is mutually exclusive with name and UUID during POST and PATCH. |
min_throughput_mbps |
integer |
Specifies the minimum throughput in Megabytes per sec, 0 means none. This is mutually exclusive with name and UUID during POST and PATCH. |
name |
string |
The QoS policy group name. This is mutually exclusive with UUID and other QoS attributes during POST and PATCH. |
uuid |
string |
The QoS policy group UUID. This is mutually exclusive with name and other QoS attributes during POST and PATCH. |
qos_policy
integer |
integer |
integer |
integer |
name |
string |
uuid |
string |
integer |
integer |
integer |
integer |
name |
string |
uuid |
string |
ip_info
IP information
address |
string |
IPv4 or IPv6 address |
netmask |
string |
Input as netmask length (16) or IPv4 mask (255.255.0.0). For IPv6, the default value is 64 with a valid range of 1 to 127. Output is always the netmask length. |
network_route_for_svm
destination |
IP information |
gateway |
string |
The IP address of the gateway router leading to the destination. |
certificate
Specifies the certificate that will be used for creating HTTPS connections to the S3 server.
name |
string |
Certificate name |
uuid |
string |
Certificate UUID |
s3
allowed |
boolean |
If this is set to true, an SVM administrator can manage the S3 service. If it is false, only the cluster administrator can manage the service. |
certificate |
Specifies the certificate that will be used for creating HTTPS connections to the S3 server. |
default_unix_user |
string |
Specifies the default UNIX user for NAS Access. |
default_win_user |
string |
Specifies the default Windows user for NAS Access. |
enabled |
boolean |
Specifies whether or not to enable S3. Setting this value to true creates a service if one is not yet created. |
is_http_enabled |
boolean |
Specifies whether HTTP is enabled on the S3 server. By default, HTTP is disabled on the S3 server. |
is_https_enabled |
boolean |
Specifies whether HTTPS is enabled on the S3 server. By default, HTTPS is enabled on the S3 server. |
name |
string |
Specifies the name of the S3 server. A server name length can range from 1 to 253 characters and can only contain the following combination of characters 0-9, A-Z, a-z, ".", and "-". |
port |
integer |
Specifies the HTTP listener port for the S3 server. By default, HTTP is enabled on port 80. |
secure_port |
integer |
Specifies the HTTPS listener port for the S3 server. By default, HTTPS is enabled on port 443. |
snapmirror
is_protected |
boolean |
Specifies whether the SVM is a SnapMirror source SVM, using SnapMirror to protect its data. |
protected_consistency_group_count |
integer |
Specifies the number of SVM DR protected consistency groups in the SVM. |
protected_volumes_count |
integer |
Specifies the number of SVM DR protected volumes in the SVM. |
snapshot_policy
name |
string |
uuid |
string |
storage
allocated |
integer |
Total size of the volumes in SVM, in bytes. |
available |
integer |
Currently available storage capacity in SVM, in bytes. |
limit |
integer |
Maximum storage permitted on a single SVM, in bytes. |
limit_threshold_alert |
integer |
Indicates at what percentage of storage capacity an alert message is sent. The default value is 90. |
limit_threshold_exceeded |
boolean |
Indicates whether the total storage capacity exceeds the alert percentage. |
used_percentage |
integer |
The percentage of storage capacity used. |
svm
aggregates |
array[aggregates] |
boolean |
anti_ransomware |
integer |
boolean |
integer |
integer |
string |
integer |
string |
string |
string |
boolean |
boolean |
certificate |
cifs |
comment |
string |
Comment |
fc_interfaces |
fcp |
Platform Specifics
ip_interfaces |
boolean |
boolean |
iscsi |
Platform Specifics
language |
string |
max_volumes |
string |
name |
string |
ndmp |
nfs |
nsswitch |
integer |
nvme |
Platform Specifics
qos_policy |
snapmirror |
snapshot_policy |
state |
string |
SVM State |
storage |
integer |
uuid |
string |
job_link
uuid |
string |
code |
string |
Argument code |
message |
string |
Message argument |
returned_error
arguments |
array[error_arguments] |
Message arguments |
code |
string |
Error code |
message |
string |
Error message |
target |
string |
