Create an application component Snapshot copy
Creates a Snapshot copy of an application component to capture its current state. Use this when working with Maxdata template applications to ensure precise backups.
HTTP method and endpoint
POST /application/applications/{application.uuid}/components/{component.uuid}/snapshots
Introduced in
ONTAP 9.6
Usage notes
This endpoint is only supported for Maxdata template applications.
Required properties
name
Recommended optional properties
consistency_type- Track whether this snapshot is application or crash consistent. Component Snapshot copies are essentially more granular application Snapshot copies. There is no difference beyond the scope of the operation.
Learn more
application.uuid |
string |
path |
True |
Application UUID |
component.uuid |
string |
path |
True |
Application Component UUID |
return_timeout |
integer |
query |
False |
return_records |
boolean |
query |
False |
Request Body
| Name | Type | Description |
_links |
application |
comment |
string |
Comment. Valid in POST |
component |
consistency_type |
string |
Consistency Type. This is for categorization only. A Snapshot copy should not be set to application consistent unless the host application is quiesced for the Snapshot copy. Valid in POST |
create_time |
string |
Creation Time |
is_partial |
boolean |
A partial Snapshot copy means that not all volumes in an application component were included in the Snapshot copy. |
name |
string |
Snapshot copy name. Valid in POST |
svm |
uuid |
string |
Snapshot copy UUID. Valid in URL |
Example request
"application": {
"name": "string",
"uuid": "string"
"comment": "string",
"component": {
"name": "string",
"uuid": "string"
"consistency_type": "string",
"create_time": "string",
"name": "string",
"svm": {
"name": "string",
"uuid": "string"
"uuid": "string"
Status: 202, Accepted
job |
"job": {
"uuid": "string"
Headers
| Name | Description | Type |
Location |
Useful for tracking the resource location |
string |
Status: Default, Error
href |
string |
_links
application
_links |
name |
string |
Application Name |
uuid |
string |
Application UUID. Valid in URL |
component
_links |
name |
string |
Component Name |
uuid |
string |
Component UUID |
svm
name |
string |
SVM Name |
uuid |
string |
SVM UUID |
application_component_snapshot
_links |
application |
comment |
string |
component |
consistency_type |
string |
create_time |
string |
Creation Time |
is_partial |
boolean |
name |
string |
svm |
uuid |
string |
job_link
uuid |
string |
code |
string |
Argument code |
message |
string |
Message argument |
error
arguments |
array[error_arguments] |
Message arguments |
code |
string |
Error code |
message |
string |
Error message |
target |
string |
