REST API reference
Create an application component Snapshot copy
Creates a Snapshot copy of an application component. This helps you manage application data at a more granular level, particularly for Maxdata template applications.
HTTP method and endpoint
POST /application/applications/{application.uuid}/components/{component.uuid}/snapshots
Introduced in
ONTAP 9.6
Usage notes
This endpoint is only supported for Maxdata template applications.
Required properties
  • name
  • consistency_type - Track whether this snapshot is application or crash consistent. Component Snapshot copies are essentially more granular application Snapshot copies. There is no difference beyond the scope of the operation.
application.uuid
string
path
True
Application UUID
component.uuid
string
path
True
Application Component UUID
return_timeout
integer
query
False
  • Default value: 0
  • Max value: 120
  • Min value: 0
return_records
boolean
query
False
  • Default value:
Request Body
Name Type Description
application
application
comment
string
Comment. Valid in POST
component
component
consistency_type
string
Consistency Type. This is for categorization only. A Snapshot copy should not be set to application consistent unless the host application is quiesced for the Snapshot copy. Valid in POST
create_time
string
Creation Time
is_partial
boolean
A partial Snapshot copy means that not all volumes in an application component were included in the Snapshot copy.
name
string
Snapshot copy name. Valid in POST
svm
svm
uuid
string
Snapshot copy UUID. Valid in URL
Example request
  "application": {
    "name": "string",
    "uuid": "string"
  "comment": "string",
  "component": {
    "name": "string",
    "uuid": "string"
  "consistency_type": "string",
  "create_time": "string",
  "name": "string",
  "svm": {
    "name": "string",
    "uuid": "string"
  "uuid": "string"
Status: 202, Accepted
job
job_link
  "job": {
    "uuid": "string"
Headers
Name Description Type
Location
Useful for tracking the resource location
string
Status: 201, Created
Status: Default, Error
string
application
name
string
Application Name
uuid
string
Application UUID. Valid in URL
component
name
string
Component Name
uuid
string
Component UUID
svm
name
string
SVM Name
uuid
string
SVM UUID
application_component_snapshot
application
application
comment
string
component
component
consistency_type
string
create_time
string
Creation Time
is_partial
boolean
name
string
svm
svm
uuid
string
uuid
string
The UUID of the asynchronous job that is triggered by a POST, PATCH, or DELETE operation.
code
string
Argument code
message
string
Message argument
returned_error
arguments
array[error_arguments]
Message arguments
code
string
Error code
message
string
Error message
target
string
