REST API reference
Retrieve an application Snapshot copy
Retrieves Snapshot copies of an application to access historical versions of application data. Use this when you need to examine or restore data from specific points in time.
HTTP method and endpoint
GET /application/applications/{application.uuid}/snapshots
Introduced in
ONTAP 9.6
Query examples
The following query returns all Snapshot copies from May 4, 2017 EST. For readability, the colon (:) is left in this example. For an actual call, they should be escaped as %3A.
GET /application/applications/{application.uuid}/snapshots?create_time=2017-05-04T00:00:00-05:00..2017-05-04T23:59:59-05:00
The following query returns all Snapshot copies that have been flagged as application consistent.
GET /application/applications/{application.uuid}/snapshots?consistency_type=application
application.uuid
string
path
True
Application UUID
uuid
string
query
False
Filter by UUID
name
string
query
False
Filter by name
consistency_type
string
query
False
Filter by consistency_type
components.name
string
query
False
Filter by components.name
components.uuid
string
query
False
Filter by components.uuid
comment
string
query
False
Filter by comment
create_time
string
query
False
Filter by create_time
is_partial
string
query
False
Filter by is_partial
fields
array[string]
query
False
Specify the fields to return.
max_records
integer
query
False
return_timeout
integer
query
False
  • Default value: 15
  • Max value: 120
  • Min value: 0
return_records
boolean
query
False
  • Default value: 1
order_by
array[string]
query
False
Status: 200, Ok
Name Type Description
_links
_links
num_records
integer
Number of records
records
array[application_snapshot]
    "next": {
      "href": "/api/resourcelink"
  "num_records": 1,
  "records": [
      "application": {
        "name": "string",
        "uuid": "string"
      "comment": "string",
      "components": [
          "name": "string",
          "uuid": "string"
      "consistency_type": "string",
      "create_time": "string",
      "name": "string",
      "svm": {
        "name": "string",
        "uuid": "string"
      "uuid": "string"
Status: Default, Error
error
returned_error
Example error
  "error": {
    "arguments": [
        "code": "string",
        "message": "string"
    "code": "4",
    "target": "uuid"
string
next
self
self
application
_links
_links
name
string
Application name
uuid
string
The application UUID. Valid in URL.
components
_links
_links
name
string
Component name
uuid
string
Component UUID
svm
name
string
SVM name
uuid
string
SVM UUID
_links
_links
application
application
comment
string
Comment. Valid in POST.
components
array[components]
consistency_type
string
Consistency type. This is for categorization purposes only. A Snapshot copy should not be set to 'application consistent' unless the host application is quiesced for the Snapshot copy. Valid in POST.
create_time
string
Creation time
is_partial
boolean
A partial Snapshot copy means that not all volumes in an application component were included in the Snapshot copy.
name
string
The Snapshot copy name. Valid in POST.
svm
svm
uuid
string
The Snapshot copy UUID. Valid in URL.
code
string
Argument code
message
string
Message argument
returned_error
arguments
array[error_arguments]
Message arguments
code
string
Error code
message
string
Error message
target
string
