Retrieve an application snapshot
GET /application/applications/{application.uuid}/snapshots
Introduced In: 9.6
Retrieves snapshots of an application.
Query examples
The following query returns all snapshots from May 4, 2017 EST. For readability, the colon (:
) is left in this example. For an actual call, they should be escaped as %3A
GET /application/applications/{application.uuid}/snapshots?create_time=2017-05-04T00:00:00-05:00..2017-05-04T23:59:59-05:00
The following query returns all snapshots that have been flagged as application consistent.
GET /application/applications/{application.uuid}/snapshots?consistency_type=application
Name | Type | In | Required | Description |
application.uuid |
string |
path |
True |
Application UUID |
uuid |
string |
query |
False |
Filter by UUID |
name |
string |
query |
False |
Filter by name |
consistency_type |
string |
query |
False |
Filter by consistency_type |
components.name |
string |
query |
False |
Filter by components.name |
components.uuid |
string |
query |
False |
Filter by components.uuid |
comment |
string |
query |
False |
Filter by comment |
create_time |
string |
query |
False |
Filter by create_time |
is_partial |
string |
query |
False |
Filter by is_partial |
fields |
array[string] |
query |
False |
max_records |
integer |
query |
False |
return_timeout |
integer |
query |
False |
return_records |
boolean |
query |
False |
order_by |
array[string] |
query |
False |
Status: 200, Ok
Name | Type | Description |
_links |
num_records |
integer |
Number of records |
records |
array[application_snapshot] |
"next": {
"href": "/api/resourcelink"
"num_records": 1,
"records": [
"application": {
"name": "string",
"uuid": "string"
"comment": "string",
"components": [
"name": "string",
"uuid": "string"
"consistency_type": "string",
"create_time": "string",
"name": "string",
"svm": {
"name": "string",
"uuid": "string"
"uuid": "string"
Status: Default, Error
error |
Example error
"error": {
"arguments": [
"code": "string",
"message": "string"
"code": "4",
"target": "uuid"
href |
string |
_links
next |
self |
_links
self |
application
_links |
name |
string |
Application name |
uuid |
string |
The application UUID. Valid in URL. |
components
_links |
name |
string |
Component name |
uuid |
string |
Component UUID |
svm
name |
string |
SVM name |
uuid |
string |
SVM UUID |
_links |
application |
comment |
string |
Comment. Valid in POST. |
components |
array[components] |
consistency_type |
string |
Consistency type. This is for categorization purposes only. A snapshot should not be set to 'application consistent' unless the host application is quiesced for the snapshot. Valid in POST. |
create_time |
string |
Creation time |
is_partial |
boolean |
A partial snapshot means that not all volumes in an application component were included in the snapshot. |
name |
string |
The snapshot name. Valid in POST. |
svm |
uuid |
string |
The snapshot UUID. Valid in URL. |
code |
string |
Argument code |
message |
string |
Message argument |
returned_error
arguments |
array[error_arguments] |
Message arguments |
code |
string |
Error code |
message |
string |
Error message |
target |
string |
