Retrieve an application Snapshot copy
Retrieves Snapshot copies of an application to examine or manage the stored state of that application over time. This is useful for tasks such as data recovery or auditing changes.
HTTP method and endpoint
GET /application/applications/{application.uuid}/snapshots
Introduced in
ONTAP 9.6
Query examples
The following query returns all Snapshot copies from May 4, 2017 EST. For readability, the colon (:) is left in this example. For an actual call, they should be escaped as %3A.
GET /application/applications/{application.uuid}/snapshots?create_time=2017-05-04T00:00:00-05:00..2017-05-04T23:59:59-05:00
The following query returns all Snapshot copies that have been flagged as application consistent.
GET /application/applications/{application.uuid}/snapshots?consistency_type=application
application.uuid |
string |
path |
True |
Application UUID |
uuid |
string |
query |
False |
Filter by UUID |
name |
string |
query |
False |
Filter by name |
consistency_type |
string |
query |
False |
Filter by consistency_type |
components.name |
string |
query |
False |
Filter by components.name |
components.uuid |
string |
query |
False |
Filter by components.uuid |
comment |
string |
query |
False |
Filter by comment |
create_time |
string |
query |
False |
Filter by create_time |
is_partial |
string |
query |
False |
Filter by is_partial |
fields |
array[string] |
query |
False |
max_records |
integer |
query |
False |
return_timeout |
integer |
query |
False |
return_records |
boolean |
query |
False |
order_by |
array[string] |
query |
False |
Status: 200, Ok
| Name | Type | Description |
_links |
num_records |
integer |
Number of records |
records |
array[application_snapshot] |
"next": {
"href": "/api/resourcelink"
"records": [
"application": {
"name": "string",
"uuid": "string"
"comment": "string",
"components": [
"name": "string",
"uuid": "string"
"consistency_type": "string",
"create_time": "string",
"name": "string",
"svm": {
"name": "string",
"uuid": "string"
"uuid": "string"
Status: Default, Error
error |
Example error
"error": {
"arguments": [
"code": "string",
"message": "string"
"code": "4",
"target": "uuid"
href |
string |
_links
next |
self |
_links
self |
application
_links |
name |
string |
Application name |
uuid |
string |
The application UUID. Valid in URL. |
components
_links |
name |
string |
Component name |
uuid |
string |
Component UUID |
svm
name |
string |
SVM name |
uuid |
string |
SVM UUID |
_links |
application |
comment |
string |
Comment. Valid in POST. |
components |
array[components] |
consistency_type |
string |
Consistency type. This is for categorization purposes only. A Snapshot copy should not be set to 'application consistent' unless the host application is quiesced for the Snapshot copy. Valid in POST. |
create_time |
string |
Creation time |
is_partial |
boolean |
A partial Snapshot copy means that not all volumes in an application component were included in the Snapshot copy. |
name |
string |
The Snapshot copy name. Valid in POST. |
svm |
uuid |
string |
The Snapshot copy UUID. Valid in URL. |
code |
string |
Argument code |
message |
string |
Message argument |
error
arguments |
array[error_arguments] |
Message arguments |
code |
string |
Error code |
message |
string |
Error message |
target |
string |
