REST API reference
Install one or more feature licenses
Installs one or more feature licenses to activate additional capabilities within your ONTAP environment.
HTTP method and endpoint
POST /cluster/licensing/licenses
Introduced in
ONTAP 9.6
Required properties
  • keys - Array containing a list of NLF or 28-character license keys.
  • system license add
return_records
boolean
query
False
  • Default value:
Request Body
Name Type Description
description
string
License description
entitlement
entitlement
keys
array[string]
licenses
array[licenses]
Installed licenses of the package.
name
string
Name of the license.
scope
string
Scope of the license.
state
string
Summary state of package based on all installed licenses.
Example request
  "description": "NFS License",
  "entitlement": {
    "action": "string",
    "risk": "string"
  "keys": [
    "AMEPOSOIKLKGEEEEDGNDEKSJDE"
  "licenses": [
      "capacity": {
        "maximum_size": 0,
        "used_size": 0
      "compliance": {
        "state": "compliant"
      "expiry_time": "2019-03-02 19:00:00 +0000",
      "host_id": "456-44-1234",
      "installed_license": "Core Bundle",
      "owner": "cluster1",
      "serial_number": "123456789",
      "start_time": "2019-02-02 19:00:00 +0000"
  "name": "NFS",
  "scope": "string",
Status: 201, Created
num_records
integer
Number of records
records
array[records]
  "num_records": 1,
  "records": [
      "entitlement": {
        "action": "string",
        "risk": "string"
      "keys": [
      "licenses": [
          "capacity": {
            "maximum_size": 0,
            "used_size": 0
          "compliance": {
      "name": "NFS",
      "scope": "string",
Headers
Name Description Type
Location
Useful for tracking the resource location
string
Status: Default
ONTAP Error Response Codes
Error Code Description
1115117
Generic licensing error
1115122
No cluster serial number found
1115124
No node serial number found
1115130
No license code was provided
1115131
Installation of the license failed
1115132
License already exists on system
1115134
Serial number does not belong to node
1115141
License data is invalid
1115142
License signature is invalid
1115143
Internal error applying the requested license
1115152
License does not apply to the platform
1115154
Unable to retrieve cluster ID
1115155
Invalid cluster ID found
1115159
License is not in an acceptable format
1115160
License has already expired
1115164
Minimum ONTAP version requirements not met
1115165
Minimum ONTAP version requirements are not met for license type enabled
1115166
Minimum ONTAP version requirements are not met for license protocol SEC-COMP-BNDL-ENBLD
1115179
FlexCache is not supported on this system
1115180
FlexCache is not supported on cloud systems
1115407
Capacity pool licenses cannot be installed directly
1115427
License is incompatible with capacity pools licensing mode
1115562
One or more errors occurred when installing a NLFv2 license
1115563
Package details and serial number of license contained within the NLFv2 failure
1115564
Package cannot be deleted individually as it is part of a bundle
1115565
NLFv2 install failed as the license serial number is already in use
1115616
Package details and serial number of license included in the install conflict
1115617
NLFv2 license install failed with summary of conflicting licenses
1115618
NLFv2 license install failed as a license with newer timestamp already exists
5375355
The cluster has more nodes than are supported by All SAN Array.
5375366
The cluster has one or more nodes that do not support All SAN Array.
66846818
Failed to interpret FlexCache license information
66846821
66846822
Invalid FlexCache capacity information provided
655294464
Failed to extract license contents
655294465
License key is invalid
655294466
Serial number is invalid
655294467
Version number is invalid
655294468
Expired license
655294469
655294470
License does not apply to the product
errors
array[error]
Example error
  "errors": [
      "arguments": [
          "code": "string",
          "message": "string"
      "code": "4",
      "target": "uuid"
string
entitlement
action
string
Entitlement action to be taken to mitigate the risk
risk
string
Entitlement risk of the package
capacity
maximum_size
integer
Licensed capacity size (in bytes) that can be used.
used_size
integer
Capacity that is currently used (in bytes).
compliance
state
string
Compliance state of the license.
licenses
active
boolean
A flag indicating whether the license is currently being enforced.
capacity
capacity
compliance
compliance
evaluation
boolean
A flag indicating whether the license is in evaluation mode.
expiry_time
string
Date and time when the license expires.
host_id
string
A string that associates the license with a node or cluster.
installed_license
string
Name of license that enabled the feature.
owner
string
Cluster, node or license manager that owns the license.
serial_number
string
Serial number of the license.
shutdown_imminent
boolean
A flag indicating whether the Cloud ONTAP system is going to shutdown as the Cloud platform license has already expired.
  • readOnly: 1
  • Introduced in: 9.11
  • x-nullable: true
start_time
string
Date and time when the license starts.
license_package
description
string
License description
entitlement
entitlement
keys
array[string]
licenses
array[licenses]
name
string
scope
string
state
string
records
description
string
License description
entitlement
entitlement
keys
array[string]
licenses
array[licenses]
name
string
scope
string
state
string
code
string
Argument code
message
string
Message argument
error
arguments
array[error_arguments]
Message arguments
code
string
Error code
message
string
Error message
target
string
