Install one or more feature licenses
Installs feature licenses to activate additional capabilities within your ONTAP system.
HTTP method and endpoint
POST /cluster/licensing/licenses
Introduced in
ONTAP 9.6
Usage notes
Installs one or more feature licenses.
Required properties
keys- Array containing a list of NLF or 28-character license keys.
Related ONTAP commands
system license add
return_records |
boolean |
query |
False |
Request Body
| Name | Type | Description |
description |
string |
License description |
entitlement |
keys |
array[string] |
licenses |
array[licenses] |
Installed licenses of the package. |
name |
string |
Name of the license. |
scope |
string |
Scope of the license. |
state |
string |
Summary state of package based on all installed licenses. |
Example request
"description": "NFS License",
"entitlement": {
"action": "string",
"risk": "string"
"keys": [
"AMEPOSOIKLKGEEEEDGNDEKSJDE"
"licenses": [
"capacity": {
"maximum_size": 0,
"used_size": 0
"compliance": {
"state": "compliant"
"expiry_time": "2019-03-02 14:00:00 -0500",
"host_id": "456-44-1234",
"installed_license": "Core Bundle",
"owner": "cluster1",
"serial_number": "123456789",
"start_time": "2019-02-02 14:00:00 -0500"
"name": "NFS",
"scope": "string",
Status: 201, Created
num_records |
integer |
Number of records |
records |
array[records] |
"num_records": 1,
"records": [
"entitlement": {
"action": "string",
"risk": "string"
"keys": [
"licenses": [
"capacity": {
"maximum_size": 0,
"used_size": 0
"compliance": {
"name": "NFS",
"scope": "string",
Headers
| Name | Description | Type |
Location |
Useful for tracking the resource location |
string |
Status: Default
ONTAP Error Response Codes
| Error Code | Description |
1115117 |
Generic licensing error |
1115122 |
No cluster serial number found |
1115124 |
No node serial number found |
1115130 |
No license code was provided |
1115131 |
Installation of the license failed |
1115132 |
License already exists on system |
1115134 |
Serial number does not belong to node |
1115141 |
License data is invalid |
1115142 |
License signature is invalid |
1115143 |
Internal error applying the requested license |
1115152 |
License does not apply to the platform |
1115154 |
Unable to retrieve cluster ID |
1115155 |
Invalid cluster ID found |
1115159 |
License is not in an acceptable format |
1115160 |
License has already expired |
1115164 |
Minimum ONTAP version requirements not met |
1115165 |
Minimum ONTAP version requirements are not met for license type enabled |
1115166 |
Minimum ONTAP version requirements are not met for license protocol SEC-COMP-BNDL-ENBLD |
1115179 |
FlexCache is not supported on this system |
1115180 |
FlexCache is not supported on cloud systems |
1115407 |
Capacity pool licenses cannot be installed directly |
1115427 |
License is incompatible with capacity pools licensing mode |
1115562 |
One or more errors occurred when installing a NLFv2 license |
1115563 |
Package details and serial number of license contained within the NLFv2 failure |
1115564 |
Package cannot be deleted individually as it is part of a bundle |
1115565 |
NLFv2 install failed as the license serial number is already in use |
1115616 |
Package details and serial number of license included in the install conflict |
1115617 |
NLFv2 license install failed with summary of conflicting licenses |
1115618 |
NLFv2 license install failed as a license with newer timestamp already exists |
5375355 |
The cluster has more nodes than are supported by All SAN Array. |
5375366 |
The cluster has one or more nodes that do not support All SAN Array. |
66846818 |
Failed to interpret FlexCache license information |
66846821 |
66846822 |
Invalid FlexCache capacity information provided |
655294464 |
Failed to extract license contents |
655294465 |
License key is invalid |
655294466 |
Serial number is invalid |
655294467 |
Version number is invalid |
655294468 |
Expired license |
655294469 |
655294470 |
License does not apply to the product |
errors |
array[returned_error] |
Example error
"errors": [
"arguments": [
"code": "string",
"message": "string"
"code": "4",
"target": "uuid"
href |
string |
_links
entitlement
action |
string |
Entitlement action to be taken to mitigate the risk |
risk |
string |
Entitlement risk of the package |
capacity
maximum_size |
integer |
Licensed capacity size (in bytes) that can be used. |
used_size |
integer |
Capacity that is currently used (in bytes). |
compliance
state |
string |
Compliance state of the license. |
licenses
active |
boolean |
A flag indicating whether the license is currently being enforced. |
capacity |
compliance |
evaluation |
boolean |
A flag indicating whether the license is in evaluation mode. |
expiry_time |
string |
Date and time when the license expires. |
host_id |
string |
A string that associates the license with a node or cluster. |
installed_license |
string |
Name of license that enabled the feature. |
owner |
string |
Cluster, node or license manager that owns the license. |
serial_number |
string |
Serial number of the license. |
shutdown_imminent |
boolean |
A flag indicating whether the Cloud ONTAP system is going to shutdown as the Cloud platform license has already expired.
start_time |
string |
Date and time when the license starts. |
license_package
description |
string |
entitlement |
keys |
array[string] |
licenses |
array[licenses] |
name |
string |
scope |
string |
state |
string |
records
description |
string |
entitlement |
keys |
array[string] |
licenses |
array[licenses] |
name |
string |
scope |
string |
state |
string |
code |
string |
Argument code |
message |
string |
Message argument |
returned_error
arguments |
array[error_arguments] |
Message arguments |
code |
string |
Error code |
message |
string |
Error message |
target |
string |
