REST API reference
Create a cluster-scoped or SVM-scoped static route
Creates a static route scoped to a cluster or Storage Virtual Machine (SVM), directing network traffic through a specified gateway. Use this endpoint to define routing paths for efficient network management within your cluster or SVM environment.
HTTP method and endpoint
POST /network/ip/routes
Introduced in
ONTAP 9.6
Usage notes
Creates a Cluster-scoped or SVM-scoped static route.
Required properties
  • gateway - IP address to route packets to.
  • SVM-scoped routes
    • svm.name or svm.uuid - SVM that route is applied to.
  • cluster-scoped routes
    • There are no additional required fields for Cluster-scoped routes.
Default property values
If not specified in POST, the following default property values are assigned:
  • destination - 0.0.0.0/0 for IPv4 or ::/0 for IPv6.
  • ipspace.name
    • Default for Cluster-scoped routes.
    • Name of the SVM's IPspace for SVM-scoped routes.
  • metric - 20.
  • network route create
return_records
boolean
query
False
  • Default value:
Request Body
Name Type Description
destination
ip_info
IP information
gateway
string
The IP address of the gateway router leading to the destination.
interfaces
array[interfaces]
IP interfaces on the same subnet as the gateway.
ipspace
ipspace
Applies to both SVM and cluster-scoped objects. Either the UUID or name may be supplied on input.
metric
integer
Indicates a preference order between several routes to the same destination. With typical usage, the default metrics provided are adequate, there is no need to specify a metric in the route creation.
svm
svm
Applies only to SVM-scoped objects. Either the UUID or name must be supplied.
uuid
string
The UUID that uniquely identifies the route.
Example request
  "destination": {
    "address": "10.10.10.7",
    "netmask": "24"
  "gateway": "10.1.1.1",
  "interfaces": [
      "name": "lif1",
  "ipspace": {
    "name": "exchange",
  "svm": {
    "name": "svm1",
Status: 201, Created
num_records
integer
Number of records
records
array[network_route]
  "num_records": 1,
  "records": [
      "destination": {
        "netmask": "24"
      "interfaces": [
          "name": "lif1",
      "ipspace": {
        "name": "exchange",
      "svm": {
        "name": "svm1",
Headers
Name Description Type
Location
Useful for tracking the resource location
string
Status: Default
ONTAP Error Response Codes
Error Code Description
1966345
Duplicate route exists.
1967080
The destination.address is missing.
1967081
The specified SVM must exist in the specified IPspace.
1967082
The specified ipspace.uuid and ipspace.name refer to different IPspaces.
1967146
The specified svm.name is not valid.
2
The specified svm.uuid is not valid.
1966265
Destination and gateway must belong to the same IP address family.
string
ip_info
IP information
address
string
IPv4 or IPv6 address
netmask
string
Input as netmask length (16) or IPv4 mask (255.255.0.0). For IPv6, the default value is 64 with a valid range of 1 to 127. Output is always netmask length.
ip
IP information
interfaces
ip
ip
IP information
name
string
The name of the interface. If only the name is provided, the SVM scope must be provided by the object this object is embedded in.
uuid
string
The UUID that uniquely identifies the interface.
ipspace
name
string
IPspace name
uuid
string
IPspace UUID
svm
name
string
The name of the SVM.
uuid
string
network_route
destination
ip_info
IP information
gateway
string
interfaces
array[interfaces]
ipspace
ipspace
metric
integer
svm
svm
uuid
string
code
string
Argument code
message
string
Message argument
error
arguments
array[error_arguments]
Message arguments
code
string
Error code
message
string
Error message
target
string
