Create a cluster-scoped or SVM-scoped static route
Creates static routes that are scoped to either the cluster or a specific Storage Virtual Machine (SVM). Use this endpoint to define the gateway and destination for directing network traffic within your ONTAP environment.
HTTP method and endpoint
POST /network/ip/routes
Introduced in
ONTAP 9.6
Usage notes
Creates a Cluster-scoped or SVM-scoped static route.
Required properties
gateway- IP address to route packets to. -
SVM-scoped routes
svm.nameorsvm.uuid- SVM that route is applied to.
cluster-scoped routes
There are no additional required fields for Cluster-scoped routes.
Default property values
If not specified in POST, the following default property values are assigned:
destination- 0.0.0.0/0 for IPv4 or ::/0 for IPv6. -
ipspace.name-
Default for Cluster-scoped routes.
Name of the SVM's IPspace for SVM-scoped routes.
metric- 20.
Related ONTAP commands
network route create
return_records |
boolean |
query |
False |
Request Body
| Name | Type | Description |
destination |
IP information |
gateway |
string |
The IP address of the gateway router leading to the destination. |
interfaces |
array[interfaces] |
IP interfaces on the same subnet as the gateway. |
ipspace |
Applies to both SVM and cluster-scoped objects. Either the UUID or name may be supplied on input. |
metric |
integer |
Indicates a preference order between several routes to the same destination. With typical usage, the default metrics provided are adequate, there is no need to specify a metric in the route creation. |
svm |
Applies only to SVM-scoped objects. Either the UUID or name must be supplied. |
uuid |
string |
The UUID that uniquely identifies the route. |
Example request
"destination": {
"address": "10.10.10.7",
"netmask": "24"
"gateway": "10.1.1.1",
"interfaces": [
"name": "lif1",
"ipspace": {
"name": "exchange",
"svm": {
"name": "svm1",
Status: 201, Created
num_records |
integer |
Number of records |
records |
array[network_route] |
"num_records": 1,
"records": [
"destination": {
"netmask": "24"
"interfaces": [
"name": "lif1",
"ipspace": {
"name": "exchange",
"svm": {
"name": "svm1",
Headers
| Name | Description | Type |
Location |
Useful for tracking the resource location |
string |
Status: Default
ONTAP Error Response Codes
| Error Code | Description |
1966265 |
The destination and gateway must belong to the same IP address family. |
1966345 |
Duplicate route exists. |
1966505 |
The gateway address cannot be the same as a LIF address. A LIF is already configured with that IP address. |
1967080 |
The destination.address is missing. |
1967081 |
The specified SVM must exist in the specified IPspace. |
1967082 |
The specified ipspace.uuid and ipspace.name refer to different IPspaces. |
1967146 |
The specified svm.name is not valid. |
2621462 |
The specified SVM does not exist. |
2621574 |
This operation is not permitted on an SVM that is configured as the destination of a MetroCluster SVM relationship. |
2621706 |
The specified UUID and name refer to different SVMs. |
href |
string |
_links
ip_info
IP information
address |
string |
IPv4 or IPv6 address |
netmask |
string |
Input as netmask length (16) or IPv4 mask (255.255.0.0). For IPv6, the default value is 64 with a valid range of 1 to 127. Output is always netmask length. |
ip
IP information
interfaces
A network interface. Either UUID or name may be supplied on input.
ip |
IP information |
name |
string |
The name of the interface. If only the name is provided, the SVM scope must be provided by the object this object is embedded in. |
uuid |
string |
The UUID that uniquely identifies the interface. |
ipspace
name |
string |
IPspace name |
uuid |
string |
IPspace UUID |
svm
name |
string |
uuid |
string |
network_route
destination |
IP information |
gateway |
string |
interfaces |
array[interfaces] |
ipspace |
metric |
integer |
svm |
uuid |
string |
code |
string |
Argument code |
message |
string |
Message argument |
error
arguments |
array[error_arguments] |
Message arguments |
code |
string |
Error code |
message |
string |
Error message |
returned_error
arguments |
Message arguments |
code |
string |
Error code |
message |
string |
Error message |
target |
string |
