Create a cluster-scoped or SVM-scoped static route
POST /network/ip/routes
Creates a Cluster-scoped or SVM-scoped static route.
Required properties
gateway- IP address to route packets to. -
SVM-scoped routes
svm.nameorsvm.uuid- SVM that route is applied to.
cluster-scoped routes
There are no additional required fields for Cluster-scoped routes.
Default property values
If not specified in POST, the following default property values are assigned:
destination- 0.0.0.0/0 for IPv4 or ::/0 for IPv6. -
ipspace.name-
Default for Cluster-scoped routes.
Name of the SVM's IPspace for SVM-scoped routes.
Related ONTAP commands
network route create
Learn more
return_records |
boolean |
query |
False |
The default is false. If set to true, the records are returned. |
Request Body
| Name | Type | Description |
_links |
destination |
IP information |
gateway |
string |
The IP address of the gateway router leading to the destination. |
ipspace |
Applies to both SVM and cluster-scoped objects. Either the UUID or name may be supplied on input. |
scope |
string |
Set to "svm" for interfaces owned by an SVM. Otherwise, set to "cluster". |
svm |
uuid |
string |
The UUID that uniquely identifies the route. |
Example request
"href": "/api/resourcelink"
"destination": {
"address": "10.10.10.7",
"family": "string",
"netmask": "24"
"gateway": "10.1.1.1",
"ipspace": {
"name": "exchange",
"scope": "string",
"svm": {
"name": "svm1",
Status: 201, Created
_links |
error |
num_records |
integer |
Number of records |
records |
array[network_route] |
"next": {
"error": {
"arguments": [
"code": "string",
"message": "string"
"code": "4",
"target": "uuid"
"num_records": 1,
"records": [
"destination": {
"family": "string",
"netmask": "24"
"ipspace": {
"name": "exchange",
"scope": "string",
"svm": {
"name": "svm1",
Status: Default
ONTAP Error Response Codes
| Error Code | Description |
1966345 |
Duplicate route exists. |
1967080 |
The destination.address is missing. |
1967081 |
The specified SVM must exist in the specified IPspace. |
1967082 |
The specified ipspace.uuid and ipspace.name refer to different IPspaces. |
1967146 |
The specified svm.name is not valid. |
2 |
The specified svm.uuid is not valid. |
error |
Example error
"error": {
"arguments": [
"code": "string",
"message": "string"
"code": "4",
"target": "uuid"
href |
string |
_links
self |
ip_info
IP information
address |
string |
IPv4 or IPv6 address |
family |
string |
IPv4 or IPv6 |
netmask |
string |
Input as netmask length (16) or IPv4 mask (255.255.0.0). For IPv6, you must set the netmask length. The default value is 64. Output is always netmask length. |
ipspace
_links |
name |
string |
IPspace name |
uuid |
string |
IPspace UUID |
svm
_links |
name |
string |
The name of the SVM. |
uuid |
string |
network_route
_links |
destination |
IP information |
gateway |
string |
ipspace |
scope |
string |
svm |
uuid |
string |
_links
next |
self |
code |
string |
Argument code |
message |
string |
Message argument |
error
arguments |
array[error_arguments] |
Message arguments |
code |
string |
Error code |
message |
string |
Error message |
target |
string |
