REST API reference
Creates a cluster-scoped or svm-scoped static route
  • svm-scoped routes
  • svmname or svmuuid - svm that route is applied to
  • cluster-scoped routes
  • there are no additional required fields for cluster-scoped routes # default property values if not specified in post, the following default property values are assigned:
  • destination - 0000/0 for ipv4 or ::/0 for ipv6
  • ipspacename
  • default for cluster-scoped routes
  • name of the svms ipspace for svm-scoped routes # related ontap commands
  • network route create
learn more
  • [doc /network/ip/routes](#docs-networking-network_ip_routes)
POST /network/ip/routes
Creates a cluster-scoped or SVM-scoped static route.
Required properties
  • gateway - IP address to route packets to.
  • SVM-scoped routes
    • svm.name or svm.uuid - SVM that route is applied to.
    • There are no additional required fields for cluster-scoped routes.
Default property values
If not specified in POST, the following default property values are assigned:
  • destination - 0.0.0.0/0 for IPv4 or ::/0 for IPv6.
  • ipspace.name
    • Default for cluster-scoped routes.
    • Name of the SVM's IPspace for SVM-scoped routes.
Request Body
Name Type Description
_links
_links
destination
ip_info
IP information
gateway
string
The IP address of the gateway router leading to the destination.
ipspace
ipspace
Applies to both SVM and cluster-scoped objects. Either the UUID or name may be supplied on input.
scope
string
Set to "svm" for interfaces owned by an SVM. Otherwise, set to "cluster".
svm
svm
uuid
string
The UUID that uniquely identifies the route.
Example request
      "href": "/api/resourcelink"
  "destination": {
    "address": "10.10.10.7",
    "family": "string",
    "netmask": "24"
  "gateway": "10.1.1.1",
  "ipspace": {
    "name": "exchange",
  "scope": "string",
  "svm": {
    "name": "svm1",
Status: 201, Created
_links
_links
error
error
num_records
integer
Number of records
records
array[network_route]
    "next": {
  "error": {
    "arguments": [
        "code": "string",
        "message": "string"
    "code": "4",
    "target": "uuid"
  "num_records": 1,
  "records": [
      "destination": {
        "family": "string",
        "netmask": "24"
      "ipspace": {
        "name": "exchange",
      "scope": "string",
      "svm": {
        "name": "svm1",
Status: Default
ONTAP Error Response Codes
Error Code Description
1966345
Duplicate route exists.
1967080
The destination.address is missing.
1967081
The specified SVM must exist in the specified IPspace.
1967082
The specified ipspace.uuid and ipspace.name refer to different IPspaces.
1967146
The specified svm.name is invalid.
2
The specified svm.uuid is invalid or wrong.
error
error
Example error
  "error": {
    "arguments": [
        "code": "string",
        "message": "string"
    "code": "4",
    "target": "uuid"
string
self
ip_info
IP information
address
string
IPv4 or IPv6 address
family
string
IPv4 or IPv6
netmask
string
Input as netmask length (16) or IPv4 mask (255.255.0.0). For IPv6, you must set the netmask length. The default value is 64. Output is always netmask length.
ipspace
_links
_links
name
string
IPspace name
uuid
string
IPspace UUID
svm
_links
_links
name
string
The name of the SVM.
uuid
string
network_route
_links
_links
destination
ip_info
IP information
gateway
string
ipspace
ipspace
scope
string
svm
svm
uuid
string
next
self
code
string
Argument code
message
string
Message argument
error
arguments
array[error_arguments]
Message arguments
code
string
Error code
message
string
Error message
target
string
Close
Try it out
Sign in with your NetApp Cloud Central credentials.
Try this API
Headers
Body
Code
