Create an NVMe subsystem map
Creates an NVMe subsystem map to establish a connection between an NVMe namespace and a subsystem, enabling data access and management within a specific SVM.
HTTP method and endpoint
POST /protocols/nvme/subsystem-maps
Introduced in
ONTAP 9.6
Required properties
svm.uuidorsvm.name- Existing SVM in which to create the NVMe subsystem map. -
namespace.uuidornamespace.name- Existing NVMe namespace to map to the specified NVme subsystem. -
subsystem.uuidorsubsystem.name- Existing NVMe subsystem to map to the specified NVMe namespace.
Related ONTAP commands
vserver nvme subsystem map create
Learn more
return_records |
boolean |
query |
False |
Request Body
| Name | Type | Description |
anagrpid |
string |
The Asymmetric Namespace Access Group ID (ANAGRPID) of the NVMe namespace. The format for an ANAGRPID is 8 hexadecimal digits (zero-filled) followed by a lower case "h". There is an added computational cost to retrieving this property's value. It is not populated for either a collection GET or an instance GET unless it is explicitly requested using the |
namespace |
The NVMe namespace to which the NVMe subsystem is mapped. Required in POST by supplying either the UUID, name, or both. |
nsid |
string |
The NVMe namespace identifier. This is an identifier used by an NVMe controller to provide access to the NVMe namespace. The format for an NVMe namespace identifier is 8 hexadecimal digits (zero-filled) followed by a lower case "h". |
subsystem |
The NVMe subsystem to which the NVMe namespace is mapped. Required in POST by supplying either |
svm |
Example request
"anagrpid": "00103050h",
"namespace": {
"name": "/vol/vol1/namespace1",
"node": {
"name": "node1",
"nsid": "00000001h",
"subsystem": {
"name": "subsystem1",
"svm": {
"name": "svm1",
Status: 201, Created
num_records |
integer |
The number of records in the response. |
records |
array[nvme_subsystem_map] |
"num_records": 1,
"records": [
"namespace": {
"node": {
"name": "node1",
"subsystem": {
"svm": {
"name": "svm1",
Headers
| Name | Description | Type |
Location |
Useful for tracking the resource location |
string |
Status: Default
ONTAP Error Response Codes
| Error Code | Description |
72089790 |
The supplied NVMe namespace is already mapped to the supplied NVMe subsystem. |
72089793 |
An NVMe namespace in a Snapshot copy cannot be mapped. |
72089799 |
The NVMe namespace is the destination of an ongoing restore operation and is inaccessible for I/O and management. |
72089902 |
A node does not have an NVMe interface configured. |
72089903 |
Multiple nodes do not have an NVMe interface configured. |
72089904 |
The aggregate must be given back to its home node prior to mapping the NVMe namespace it contains. |
72090001 |
The NVMe subsystem specified by |
72090005 |
The specified |
72090006 |
The NVMe namespace specified by |
72090007 |
72090020 |
The specified |
72090021 |
href |
string |
_links
node
name |
string |
uuid |
string |
namespace
name |
string |
The fully qualified path name of the NVMe namespace composed from the volume name, qtree name, and file name of the NVMe namespace. Valid in POST. |
node |
uuid |
string |
The unique identifier of the NVMe namespace. Valid in POST. |
subsystem
The NVMe subsystem to which the NVMe namespace is mapped. Required in POST by supplying either subsystem.uuid, subsystem.name or both.
name |
string |
The name of the NVMe subsystem. |
uuid |
string |
The unique identifier of the NVMe subsystem. |
svm
name |
string |
The name of the SVM. |
uuid |
string |
nvme_subsystem_map
An NVMe subsystem map is an association of an NVMe namespace with an NVMe subsystem. When an NVMe namespace is mapped to an NVMe subsystem, the NVMe subsystem's hosts are granted access to the NVMe namespace. The relationship between an NVMe subsystem and an NVMe namespace is one subsystem to many namespaces.
anagrpid |
string |
namespace |
nsid |
string |
subsystem |
svm |
code |
string |
Argument code |
message |
string |
Message argument |
error
arguments |
array[error_arguments] |
Message arguments |
code |
string |
Error code |
message |
string |
Error message |
target |
string |
