REST API reference
Create an NVMe subsystem map
Creates an NVMe subsystem map, associating an NVMe namespace with a particular subsystem within an SVM. Use this when you need to configure NVMe mappings for enhanced storage management.
HTTP method and endpoint
POST /protocols/nvme/subsystem-maps
Introduced in
ONTAP 9.6
Required properties
  • svm.uuid or svm.name - Existing SVM in which to create the NVMe subsystem map.
  • namespace.uuid or namespace.name - Existing NVMe namespace to map to the specified NVme subsystem.
  • subsystem.uuid or subsystem.name - Existing NVMe subsystem to map to the specified NVMe namespace.
  • vserver nvme subsystem map add
return_records
boolean
query
False
  • Default value:
Request Body
Name Type Description
anagrpid
string
The Asymmetric Namespace Access Group ID (ANAGRPID) of the NVMe namespace.
The format for an ANAGRPID is 8 hexadecimal digits (zero-filled) followed by a lower case "h".
There is an added computational cost to retrieving this property's value. It is not populated for a GET request unless it is explicitly requested using the fields query parameter. See Requesting specific fields to learn more.
namespace
namespace
The NVMe namespace to which the NVMe subsystem is mapped. Required in POST by supplying either the UUID, name, or both.
nsid
string
The NVMe namespace identifier. This is an identifier used by an NVMe controller to provide access to the NVMe namespace.
The format for an NVMe namespace identifier is 8 hexadecimal digits (zero-filled) followed by a lower case "h".
subsystem
subsystem
The NVMe subsystem to which the NVMe namespace is mapped. Required in POST by supplying either subsystem.uuid, subsystem.name or both.
svm
svm
Example request
  "anagrpid": "00103050h",
  "namespace": {
    "name": "/vol/vol1/namespace1",
    "node": {
      "name": "node1",
  "nsid": "00000001h",
  "subsystem": {
    "name": "subsystem1",
  "svm": {
    "name": "svm1",
Status: 201, Created
num_records
integer
The number of records in the response.
records
array[nvme_subsystem_map]
  "num_records": 1,
  "records": [
      "namespace": {
        "node": {
          "name": "node1",
      "subsystem": {
      "svm": {
        "name": "svm1",
Headers
Name Description Type
Location
Useful for tracking the resource location
string
Status: Default
ONTAP Error Response Codes
Error Code Description
5374127
The specified namespace name is invalid.
5376461
5376462
The specified namespace name is too long.
72089731
The specified NVMe namespace does not exist.
72089790
The supplied NVMe namespace is already mapped to the supplied NVMe subsystem.
72089793
An NVMe namespace in a snapshot cannot be mapped.
72089799
The NVMe namespace is the destination of an ongoing restore operation and is inaccessible for I/O and management.
72089902
A node does not have an NVMe interface configured.
72089903
Multiple nodes do not have an NVMe interface configured.
72089904
The aggregate must be given back to its home node prior to mapping the NVMe namespace it contains.
72090001
The NVMe subsystem specified by subsystem.uuid was not found.
72090005
The specified namespace.uuid and namespace.name refer to different NVMe namespaces.
72090006
The NVMe namespace specified by namespace.uuid was not found.
72090007
The NVMe namespace specified by namespace.name was not found.
72090020
The specified subsystem.uuid and subsystem.name refer to different NVMe subsystems.
72090021
The NVMe subsystem specified by subsystem.name was not found.
72091102
The NVMe namespace is part of a SnapMirror active sync relationship that has a different SVM peering relationship than the subsystem.
string
node
name
string
uuid
string
namespace
name
string
The name of the NVMe namespace. Valid in POST. An NVMe namespace is located within a volume. Optionally, it can be located within a qtree in a volume.
NVMe namespace names are paths of the form "/vol/<volume>[/<qtree>]/<namespace>" where the qtree name is optional.
node
node
uuid
string
The unique identifier of the NVMe namespace. Valid in POST.
subsystem
name
string
The name of the NVMe subsystem.
uuid
string
The unique identifier of the NVMe subsystem.
svm
name
string
uuid
string
nvme_subsystem_map
An NVMe subsystem map is an association of an NVMe namespace with an NVMe subsystem. When an NVMe namespace is mapped to an NVMe subsystem, the NVMe subsystem's hosts are granted access to the NVMe namespace. The relationship between an NVMe subsystem and an NVMe namespace is one subsystem to many namespaces.
anagrpid
string
namespace
namespace
nsid
string
subsystem
subsystem
svm
svm
code
string
Argument code
message
string
Message argument
returned_error
arguments
array[error_arguments]
Message arguments
code
string
Error code
message
string
Error message
target
string
