Create an S3 policy configuration
Creates an S3 policy configuration to manage access rules for S3 buckets and objects within an existing SVM. This helps you define what actions can be allowed or denied, providing control over data access in your storage environment.
HTTP method and endpoint
POST /protocols/s3/services/{svm.uuid}/policies
Introduced in
ONTAP 9.8
Important notes
Each SVM can have one or more s3 policy configurations.
Required properties
svm.uuid- Existing SVM in which to create the s3 policy configuration. -
name- Policy name that is to be created.
Recommended optional properties
comment- Short description about the S3 policy. -
statements.effect- Indicates whether to allow or deny access. -
statements.actions- List of actions that can be allowed or denied access. Example: GetObject, PutObject, DeleteObject, ListBucket, ListMyBuckets, ListBucketMultipartUploads, ListMultipartUploadParts, CreateBucket, DeleteBucket, GetObjectTagging, PutObjectTagging, DeleteObjectTagging, GetBucketVersioning, PutBucketVersioning. -
statements.resources- Buckets or objects that can be allowed or denied access. -
statements.sid- Statement identifier providing additional information about the statement.
Related ONTAP commands
vserver object-store-server policy create -
vserver object-store-server policy add-statement
return_records |
boolean |
query |
False |
svm.uuid |
string |
path |
True |
UUID of the SVM to which this object belongs. |
Request Body
| Name | Type | Description |
comment |
string |
Can contain any additional information about the S3 policy. |
name |
string |
Specifies the name of the policy. A policy name length can range from 1 to 128 characters and can only contain the following combination of characters 0-9, A-Z, a-z, "_", "+", "=", ",", ".","@", and "-". |
read-only |
boolean |
Specifies whether or not the s3 policy is read only. This parameter should not be specified in the POST method. |
statements |
array[s3_policy_statement] |
Specifies the policy statements. |
svm |
Example request
"comment": "S3 policy.",
"name": "Policy1",
"statements": [
"actions": [
"effect": "allow",
"index": 0,
"resources": [
"bucket1",
"bucket1/*"
"sid": "FullAccessToBucket1"
"svm": {
"name": "svm1",
Status: 201, Created
num_records |
integer |
Number of records |
records |
array[s3_policy] |
"num_records": 1,
"records": [
"name": "Policy1",
"statements": [
"actions": [
"effect": "allow",
"index": 0,
"resources": [
"bucket1",
"bucket1/*"
"svm": {
"name": "svm1",
Headers
| Name | Description | Type |
Location |
Useful for tracking the resource location |
string |
Status: Default
ONTAP Error Response Codes
| Error Code | Description |
92405906 |
The specified action name is invalid. |
92405947 |
Creating an object store server policy or statement requires an effective cluster version of 9.8 or later. |
92405948 |
Policy name is not valid. Policy names must have between 1 and 128 characters. |
92405949 |
Policy name contains invalid characters. Valid characters: 0-9, A-Z, a-z, "_", "+", "=", ",", ".", "@", and "-". |
92405950 |
Policy name already exists for SVM. |
92405954 |
Policy name is reserved for read-only policies. Cannot be used for custom policy creation. |
92405963 |
Failed to create policy statements for policy. Reason: "{reason of failure}". Resolve all issues and retry the operation. |
s3_policy_statement
Specifies information about a single access policy statement.
actions |
array[string] |
For each resource, S3 supports a set of operations. The resource operations allowed or denied are identified by an action list:
effect |
string |
Specifies whether access is allowed or denied. If access (to allow) is not granted explicitly to a resource, access is implicitly denied. Access can also be denied explicitly to a resource, in order to make sure that a user cannot access it, even if a different policy grants access. |
index |
integer |
Specifies a unique statement index used to identify a particular statement. This parameter should not be specified in the POST method. A statement index is automatically generated and is retrieved using the GET method. |
resources |
array[string] |
sid |
string |
Specifies the statement identifier which contains additional information about the statement. |
href |
string |
_links
svm
name |
string |
The name of the SVM. |
uuid |
string |
s3_policy
An S3 policy is an object. It defines resource (bucket, folder or object) permissions. These policies get evaluated when an object store user user makes a request. Permissions in the policies determine whether the request is allowed or denied.
comment |
string |
name |
string |
read-only |
boolean |
statements |
svm |
collection_links
code |
string |
Argument code |
message |
string |
Message argument |
error
arguments |
array[error_arguments] |
Message arguments |
code |
string |
Error code |
message |
string |
Error message |
target |
string |
