Create an S3 policy configuration
Creates an S3 policy configuration to define access permissions for S3 operations within a storage virtual machine (SVM). This is useful for managing and controlling access to your S3 resources.
HTTP method and endpoint
POST /protocols/s3/services/{svm.uuid}/policies
Introduced in
ONTAP 9.8
Important notes
Each SVM can have one or more s3 policy configurations.
Required properties
svm.uuid- Existing SVM in which to create the s3 policy configuration. -
name- Policy name that is to be created.
Recommended optional properties
comment- Short description about the S3 policy. -
statements.effect- Indicates whether to allow or deny access. -
statements.actions- List of actions that can be allowed or denied access. Example: GetObject, PutObject, DeleteObject, ListBucket, ListMyBuckets, ListBucketMultipartUploads, ListMultipartUploadParts, CreateBucket, DeleteBucket, GetObjectTagging, PutObjectTagging, DeleteObjectTagging, GetBucketVersioning, PutBucketVersioning. -
statements.resources- Buckets or objects that can be allowed or denied access. -
statements.sid- Statement identifier providing additional information about the statement.
Related ONTAP commands
vserver object-store-server policy create -
vserver object-store-server policy add-statement
return_records |
boolean |
query |
False |
svm.uuid |
string |
path |
True |
UUID of the SVM to which this object belongs. |
Request Body
| Name | Type | Description |
comment |
string |
Can contain any additional information about the S3 policy. |
name |
string |
Specifies the name of the policy. A policy name length can range from 1 to 128 characters and can only contain the following combination of characters 0-9, A-Z, a-z, "_", "+", "=", ",", ".","@", and "-". It cannot be specified in a PATCH method. |
read-only |
boolean |
Specifies whether or not the s3 policy is read only. This parameter should not be specified in the POST method. |
statements |
array[s3_policy_statement] |
Specifies the policy statements. |
svm |
Example request
"comment": "S3 policy.",
"name": "Policy1",
"statements": [
"actions": [
"effect": "allow",
"index": 0,
"resources": [
"bucket1",
"bucket1/*"
"sid": "FullAccessToBucket1"
"svm": {
"name": "svm1",
Status: 201, Created
num_records |
integer |
Number of records |
records |
array[s3_policy] |
"num_records": 1,
"records": [
"name": "Policy1",
"statements": [
"actions": [
"effect": "allow",
"index": 0,
"resources": [
"bucket1",
"bucket1/*"
"svm": {
"name": "svm1",
Headers
| Name | Description | Type |
Location |
Useful for tracking the resource location |
string |
Status: Default
ONTAP Error Response Codes
| Error Code | Description |
92405906 |
The specified action name is invalid. |
92405947 |
Creating an object store server policy or statement requires an effective cluster version of 9.8 or later. |
92405948 |
Policy name is not valid. Policy names must have between 1 and 128 characters. |
92405949 |
Policy name contains invalid characters. Valid characters: 0-9, A-Z, a-z, "_", "+", "=", ",", ".", "@", and "-". |
92405950 |
Policy name already exists for SVM. |
92405954 |
Policy name is reserved for read-only policies. Cannot be used for custom policy creation. |
92405963 |
Failed to create policy statements for policy. Reason: "{reason of failure}". Resolve all issues and retry the operation. |
92405863 |
Failed to create s3 policy statements. Reason: "{reason of failure}". Valid ways to specify a resource are "__", " |
|Name |Type |Description
|actions |array[string] a|For each resource, S3 supports a set of operations. The resource operations allowed or denied are identified by an action list:
GetObject - retrieves objects from a bucket.
PutObject - puts objects in a bucket.
DeleteObject - deletes objects from a bucket.
ListBucket - lists the objects in a bucket.
GetBucketAcl - retrieves the access control list (ACL) of a bucket.
GetObjectAcl - retrieves the access control list (ACL) of an object.
ListAllMyBuckets - lists all of the buckets in a server.
ListBucketMultipartUploads - lists the multipart uploads in progress for a bucket.
ListMultipartUploadParts - lists the parts in a multipart upload.
CreateBucket - creates a new bucket.
DeleteBucket - deletes an existing bucket.
GetObjectTagging - retrieves the tag set of an object.
PutObjecttagging - sets the tag set for an object.
DeleteObjectTagging - deletes the tag set of an object.
GetBucketLocation - retrieves the location of a bucket.
GetBucketVersioning - retrieves the versioning configuration of a bucket.
PutBucketVersioning - modifies the versioning configuration of a bucket.
ListBucketVersions - lists the object versions in a bucket.
PutBucketPolicy - puts bucket policy on the bucket specified.
GetBucketPolicy - retrieves the bucket policy of a bucket.
DeleteBucketPolicy - deletes the policy created for a bucket. The wildcard character "*" can be used to form a regular expression for specifying actions.
|effect |string a|Specifies whether access is allowed or denied. If access (to allow) is not granted explicitly to a resource, access is implicitly denied. Access can also be denied explicitly to a resource, in order to make sure that a user cannot access it, even if a different policy grants access.
|index |integer a|Specifies a unique statement index used to identify a particular statement. This parameter should not be specified in the POST method. A statement index is automatically generated. It is not retrieved in the GET method.
|resources |array[string] a|
|sid |string a|Specifies the statement identifier which contains additional information about the statement.
[#href] [.api-collapsible-fifth-title] href [cols=3*,options=header] |
|href |string a|
[#_links] [.api-collapsible-fifth-title] _links [#svm] [.api-collapsible-fifth-title] svm SVM, applies only to SVM-scoped objects. [cols=3*,options=header] |
|name |string a|The name of the SVM. This field cannot be specified in a PATCH method.
|uuid |string a|The unique identifier of the SVM. This field cannot be specified in a PATCH method.
[#s3_policy] [.api-collapsible-fifth-title] s3_policy An S3 policy is an object. It defines resource (bucket, folder or object) permissions. These policies get evaluated when an object store user user makes a request. Permissions in the policies determine whether the request is allowed or denied. [cols=3*,options=header] |
|comment |string a|Can contain any additional information about the S3 policy.
|name |string a|Specifies the name of the policy. A policy name length can range from 1 to 128 characters and can only contain the following combination of characters 0-9, A-Z, a-z, "_", "+", "=", ",", ".","@", and "-". It cannot be specified in a PATCH method.
|read-only |boolean a|Specifies whether or not the s3 policy is read only. This parameter should not be specified in the POST method.
|statements |array[s3_policy_statement] a|Specifies the policy statements.
|svm |svm a|SVM, applies only to SVM-scoped objects.
[#collection_links] [.api-collapsible-fifth-title] collection_links [#error_arguments] [.api-collapsible-fifth-title] error_arguments [cols=3*,options=header] |
|code |string a|Argument code
|message |string a|Message argument
[#returned_error] [.api-collapsible-fifth-title] returned_error [cols=3*,options=header] |
|arguments |array[error_arguments] a|Message arguments
|code |string a|Error code
|message |string a|Error message
|target |string a|The target parameter that caused the error.
