Create an S3 policy configuration
POST /protocols/s3/services/{svm.uuid}/policies
Introduced In: 9.8
Creates the S3 policy configuration.
Important notes
Each SVM can have one or more s3 policy configurations.
Required properties
svm.uuid- Existing SVM in which to create the s3 policy configuration. -
name- Policy name that is to be created.
Recommended optional properties
comment- Short description about the S3 policy. -
statements.effect- Indicates whether to allow or deny access. -
statements.actions- List of actions that can be allowed or denied access. Example: GetObject, PutObject, DeleteObject, ListBucket and ListMyBuckets. -
statements.resources- Buckets or objects that can be allowed or denied access. -
statements.sid- Statement identifier providing additional information about the statement.
Related ONTAP commands
vserver object-store-server policy create -
vserver object-store-server policy add-statement
return_records |
boolean |
query |
False |
svm.uuid |
string |
path |
True |
UUID of the SVM to which this object belongs. |
Request Body
| Name | Type | Description |
comment |
string |
Can contain any additional information about the S3 policy. |
name |
string |
Specifies the name of the policy. A policy name length can range from 1 to 128 characters and can only contain the following combination of characters 0-9, A-Z, a-z, "_", "+", "=", ",", ".","@", and "-". |
read-only |
boolean |
Specifies whether or not the s3 policy is read only. This parameter should not be specified in the POST method. |
statements |
array[s3_policy_statement] |
Specifies the policy statements. |
svm |
Example request
"comment": "S3 policy.",
"name": "Policy1",
"statements": [
"actions": [
"effect": "allow",
"index": 0,
"resources": [
"bucket1",
"bucket1/*"
"sid": "FullAccessToBucket1"
"svm": {
"name": "svm1",
Status: 201, Created
num_records |
integer |
Number of records |
records |
array[s3_policy] |
"records": [
"name": "Policy1",
"statements": [
"actions": [
"effect": "allow",
"index": 0,
"resources": [
"bucket1",
"bucket1/*"
"svm": {
"name": "svm1",
Status: Default
ONTAP Error Response Codes
| Error Code | Description | | ------- | -------- |
s3_policy_statement
Specifies information about a single access policy statement.
actions |
array[string] |
For each resource, S3 supports a set of operations. The resource operations allowed or denied are identified by an action list:
effect |
string |
Specifies whether access is allowed or denied. If access (to allow) is not granted explicitly to a resource, access is implicitly denied. Access can also be denied explicitly to a resource, in order to make sure that a user cannot access it, even if a different policy grants access. |
index |
integer |
Specifies a unique statement index used to identify a particular statement. This parameter should not be specified in the POST method. A statement index is automatically generated and is retrieved using the GET method. |
resources |
array[string] |
sid |
string |
Specifies the statement identifier which contains additional information about the statement. |
href |
string |
_links
svm
name |
string |
The name of the SVM. |
uuid |
string |
s3_policy
An S3 policy is an object. It defines resource (bucket, folder or object) permissions. These policies get evaluated when an object store user user makes a request. Permissions in the policies determine whether the request is allowed or denied.
comment |
string |
name |
string |
read-only |
boolean |
statements |
svm |
collection_links
code |
string |
Argument code |
message |
string |
Message argument |
error
arguments |
array[error_arguments] |
Message arguments |
code |
string |
Error code |
message |
string |
Error message |
target |
string |
