REST API reference
Create a new user account
Creates a new user account to manage access and permissions within your ONTAP system. Use this endpoint to define account attributes such as role, authentication methods, and application access.
HTTP method and endpoint
POST /security/accounts
Introduced in
ONTAP 9.6
Required parameters
  • name - Account name to be created.
  • applications - Array of one or more application tuples (of application and authentication methods).
Optional parameters
  • owner.name or owner.uuid - Name or UUID of the SVM for an SVM-scoped user account. If not supplied, a cluster-scoped user account is created.
  • role - RBAC role for the user account. Defaulted to admin for cluster user account and to vsadmin for SVM-scoped account.
  • password - Password for the user account (if the authentication method is opted as password for one or more of applications).
  • second_authentication_method - Needed for MFA and only supported for ssh application. Defaults to none if not supplied.
  • comment - Comment for the user account (e.g purpose of this account).
  • locked - Locks the account after creation. Defaults to false if not supplied.
  • ldap_fastbind - Needed for LDAP Fastbind Authentication and only supported for applications SSH, ONTAPI, and HTTP with authentication method "nsswitch" only. Defaults to false if not supplied.
  • security login create
return_records
boolean
query
False
  • Default value:
Request Body
Name Type Description
_links
_links
applications
array[account_application]
comment
string
Optional comment for the user account.
ldap_fastbind
boolean
Optional property that specifies the mode of authentication is LDAP Fastbind.
locked
boolean
Locked status of the account.
name
string
User or group account name
owner
owner
Owner name and UUID that uniquely identifies the user account.
password
string
Password for the account. The password can contain a mix of lower and upper case alphabetic characters, digits, and special characters.
password_hash_algorithm
string
Optional property that specifies the password hash algorithm used to generate a hash of the user's password for password matching.
role
role
scope
string
Scope of the entity. Set to "cluster" for cluster owned objects and to "svm" for SVM owned objects.
Example request
  "applications": [
      "application": "string",
      "authentication_methods": [
        "string"
      "second_authentication_method": "string"
  "comment": "string",
  "name": "joe.smith",
  "owner": {
    "name": "svm1",
  "password": "string",
  "password_hash_algorithm": "sha512",
  "role": {
    "name": "admin"
  "scope": "string"
Status: 201, Created
Headers
Name Description Type
Location
Useful for tracking the resource location
string
Status: Default
ONTAP Error Response Codes
Error Code Description
1261215
The role was not found.
1263343
Cannot lock user with password not set or non-password authentication method.
5636099
User creation with a non-admin role is not supported for service-processor application.
5636121
The user account name is reserved for use by the system.
5636126
Cannot create a user with the username or role as AutoSupport because it is reserved by the system.
5636140
Creating a login with application console for a data Vserver is not supported.
5636141
Creating a login with application service-processor for a data Vserver is not supported.
5636154
The second-authentication-method parameter is supported for ssh application.
5636155
The second-authentication-method parameter can be specified only if the authentication-method password or public key nsswitch.
5636156
The same value cannot be specified for the second-authentication-method and the authentication-method.
5636164
If the value for either the authentication-method second-authentication-method is nsswitch or password, the other parameter must differ.
5636197
LDAP fastbind combination for application and authentication method is not supported.
5636198
LDAP fastbind authentication is supported only for nsswitch.
5636206
Non-domain user cannot have a backslash in the username.
5636207
If the value for either the authentication-method or second-authentication-method parameters is domain, the other parameter must be publickey or none.
5636212
TOTP is supported only when the primary authentication method is password or public key.
5636214
Configuring the user with TOTP as secondary authentication method requires an effective cluster version of 9.13.1 or later
7077897
Invalid character in username.
7077898
The username must contain both letters and numbers.
7077899
The username does not meet length requirements.
7077906
A role with that name has not been defined for the Vserver.
7077918
The password cannot contain the username.
7077919
The minimum length for new password does not meet the policy.
7077920
A new password must have both letters and numbers.
7077921
The minimum number of special characters required do not meet the policy.
7077929
7077940
The password exceeds the maximum supported length.
7077941
The defined password composition exceeds the maximum password length of 128 characters.
7078900
An admin password is not set. Set the password by including it in the request.
string
account_application
application
string
Applications
array[string]
string
An optional additional authentication method for multifactor authentication (MFA). This is only supported with SSH as the application. Time-based One-Time Passwords (TOTPs) are only supported with the authentication method password or public key. It is ignored for all other applications.
owner
_links
_links
name
string
The name of the SVM.
uuid
string
role
_links
_links
name
string
Role name
account
_links
_links
applications
comment
string
ldap_fastbind
boolean
locked
boolean
name
string
owner
owner
password
string
string
role
role
scope
string
code
string
Argument code
message
string
Message argument
error
arguments
array[error_arguments]
Message arguments
code
string
Error code
message
string
Error message
target
string
