REST API reference
Create a new user account
Creates a new user account for managing access control and authentication within your system. You typically use this endpoint when setting up new users with specific roles and permissions to ensure secure and organized account management.
HTTP method and endpoint
POST /security/accounts
Introduced in
ONTAP 9.6
Required parameters
  • name - Account name to be created.
  • applications - Array of one or more application tuples (of application and authentication methods).
Optional parameters
  • owner.name or owner.uuid - Name or UUID of the SVM for an SVM-scoped user account. If not supplied, a cluster-scoped user account is created.
  • role - RBAC role for the user account. Defaulted to admin for cluster user account and to vsadmin for SVM-scoped account.
  • password - Password for the user account (if the authentication method is opted as password for one or more of applications).
  • second_authentication_method - Needed for MFA and only supported for ssh and service_processor applications. Defaults to none if not supplied.
  • comment - Comment for the user account (e.g purpose of this account).
  • locked - Locks the account after creation. Defaults to false if not supplied.
  • is_ldap_fastbind - Needed for LDAP Fastbind Authentication and only supported for applications SSH, ONTAPI, and HTTP with authentication method "nsswitch" only. Defaults to false if not supplied.
  • is_ns_switch_group - Specifies whether the user is an LDAP or NIS group and is only supported for SSH, ONTAPI, and HTTP applications with the authentication method "nsswitch". Defaults to false if not supplied.
  • security login create
return_records
boolean
query
False
  • Default value:
Request Body
Name Type Description
applications
array[account_application]
comment
string
Optional comment for the user account.
locked
boolean
Locked status of the account.
name
string
User or group account name
owner
owner
Owner name and UUID that uniquely identifies the user account.
password
string
Password for the account. The password can contain a mix of lower and upper case alphabetic characters, digits, and special characters.
password_hash_algorithm
string
Password hash algorithm used to generate a hash of the user's password for password matching.To modify "password_hash_algorithm", use REST API "/api/security/authentication/password".
role
role
scope
string
Scope of the entity. Set to "cluster" for cluster owned objects and to "svm" for SVM owned objects.
Example request
  "applications": [
      "application": "string",
      "authentication_methods": [
        "string"
      "second_authentication_method": "string"
  "comment": "string",
  "name": "joe.smith",
  "owner": {
    "name": "svm1",
  "password": "string",
  "password_hash_algorithm": "sha512",
  "role": {
    "name": "admin"
  "scope": "string"
Status: 201, Created
Headers
Name Description Type
Location
Useful for tracking the resource location
string
Status: Default
ONTAP Error Response Codes
Error Code Description
1261215
The role was not found.
1261225
Invalid command directory name.
1263343
Cannot lock user with password not set or non-password authentication method.
2621475
This operation is not supported on a node SVM.
2621601
This operation is not supported on a system SVM.
2621706
The specified owner.uuid and owner.name refer to different SVMs.
5636099
User creation with a non-admin role is not supported for service-processor application.
5636121
The user account name is reserved for use by the system.
5636126
Cannot create a user with the username or role as AutoSupport because it is reserved by the system.
5636136
Specifying "is_ns_switch_group" as "true" is supported only for authentication method "nsswitch".
5636140
Creating a login with application console for a data SVM is not supported.
5636141
Creating a login with application service-processor for a data SVM is not supported.
5636154
The second authentication method parameter is supported for SSH and Service Processor (SP) applications only.
5636155
The second-authentication-method parameter can be specified only if the authentication-method password or public key nsswitch.
5636156
The same value cannot be specified for the second-authentication-method and the authentication-method.
5636164
If the value for either the authentication-method second-authentication-method is nsswitch or password, the other parameter must differ.
5636165
Second authentication method is not supported for NIS or LDAP group based accounts.
5636176
The application and authentication-method combination is invalid.
5636178
An invalid value is specified for field "application".
5636179
Creating an AMQP application login for a data SVM is not supported.
5636197
LDAP fastbind combination for application and authentication method is not supported.
5636198
LDAP fastbind authentication is supported only for nsswitch.
5636206
Non-domain user cannot have a backslash in the username.
5636207
If the value for either the authentication-method or second-authentication-method parameters is domain, the other parameter must be publickey or none.
5636212
TOTP is supported only when the primary authentication method is password or public key.
5636214
Configuring the user with TOTP as secondary authentication method requires an effective cluster version of 9.13.1 or later
5636223
Specifying "is_ns_switch_group" as "true" is supported only for SSH, ONTAPI and HTTP applications.
5636224
Configuring a Service Processor (SP) user with two-factor authentication requires an effective cluster version of 9.15.1 or later.
5636225
For a Service Processor (SP) user, the second factor of authentication must be one of publickey or none.
5636226
Internal error. Failed to check for ONTAP capability.
7077897
Invalid character in username.
7077898
The username must contain both letters and numbers.
7077899
The username does not meet length requirements.
7077906
A role with that name has not been defined for the Vserver.
7077918
The password cannot contain the username.
7077919
The minimum length for new password does not meet the policy.
7077920
A new password must have both letters and numbers.
7077921
The minimum number of special characters required do not meet the policy.
7077929
7077940
The password exceeds the maximum supported length.
7077941
The defined password composition exceeds the maximum password length of 128 characters.
7078900
An admin password is not set. Set the password by including it in the request.
string
account_application
application
string
Applications
array[string]
is_ldap_fastbind
boolean
Optional property that specifies the mode of authentication as LDAP Fastbind.
is_ns_switch_group
boolean
Optional property that specifies whether the user is an LDAP or NIS group.
string
An optional additional authentication method for multifactor authentication (MFA). This property is only supported for SSH (ssh) and Service Processor (service_processor) applications. It is ignored for all other applications. Time-based One-Time Passwords (TOTPs) are only supported with the authentication method password or public key. For the Service Processor (service_processor) application, none and publickey are the only supported enum values.
owner
name
string
uuid
string
role
name
string
Role name
account
applications
comment
string
locked
boolean
name
string
owner
owner
password
string
string
role
role
scope
string
code
string
Argument code
message
string
Message argument
returned_error
arguments
array[error_arguments]
Message arguments
code
string
Error code
message
string
Error message
target
string
