REST API reference
Create a multi-admin-verify request
Creates a multi-admin-verify request to initiate a verification process involving multiple administrators. This can be useful for confirming changes that require collective approval.
HTTP method and endpoint
POST /security/multi-admin-verify/requests
Introduced in
ONTAP 9.11
return_records
boolean
query
False
  • Default value:
Request Body
Name Type Description
approve_expiry_time
string
approve_time
string
approved_users
array[string]
The users that have approved the request.
comment
string
Optional user-provided comment that is sent to the approval-group email indicating why the request was made.
create_time
string
execute_on_approval
boolean
Specifies that the operation is executed automatically on final approval.
execution_expiry_time
string
index
integer
Unique index that represents a request.
operation
string
The command to execute.
owner
owner
The owner of the request. This can identify the cluster or an SVM.
pending_approvers
integer
The number of approvers remaining that are required to approve.
permitted_users
array[string]
List of users that can execute the operation once approved. If not set, any authorized user can perform the operation.
potential_approvers
array[string]
The users that are able to approve the request.
query
string
Identifies the specific entry upon which the user wants to operate.
required_approvers
integer
The number of required approvers, excluding the user that made the request.
state
string
The state of the request. PATCH supports approved and vetoed. The state only changes after setting to approved once no more approvers are required.
user_requested
string
The user that created the request. Automatically set by ONTAP.
  • readOnly: 1
  • Introduced in: 9.11
  • x-nullable: true
user_vetoed
string
The user that vetoed the request.
Example request
  "approve_expiry_time": "string",
  "approve_time": "string",
  "approved_users": [
    "string"
  "comment": "string",
  "create_time": "string",
  "execution_expiry_time": "string",
  "index": 0,
  "operation": "string",
  "owner": {
    "name": "svm1",
  "pending_approvers": 0,
  "permitted_users": [
    "string"
  "potential_approvers": [
    "string"
  "query": "string",
  "required_approvers": 0,
  "state": "string",
  "user_requested": "string",
  "user_vetoed": "string"
Status: 201, Created
num_records
integer
Number of records
records
array[multi_admin_verify_request]
  "num_records": 1,
  "records": [
      "approved_users": [
        "string"
      "index": 0,
      "owner": {
        "name": "svm1",
        "string"
        "string"
      "query": "string",
      "state": "string",
Headers
Name Description Type
Location
Useful for tracking the resource location
string
Status: Default
ONTAP Error Response Codes
Error Code Description
262148
The specified command is not recognized.
262304
Too many requests. Delete one before creating another.
262305
Can't approve non-pending request.
262306
Can't veto an expired request.
262308
The specified command is not supported by this feature.
262309
The feature must be enabled first.
262311
Value must be greater than zero.
262312
Number of required approvers must be less than the total number of unique approvers in the approval-groups.
262313
Number of unique approvers in the approval-groups must be greater than the number of required approvers.
262326
Failed to parse query.
262327
Failed to crate the request.
262328
There is no matching rule for this request.
262330
Cannot approve/veto a request multiple times.
262334
The parameter specified in the command is not supported.
262337
Cannot approve/veto the user's own request.
string
owner
name
string
The name of the SVM.
uuid
string
approve_expiry_time
string
approve_time
string
approved_users
array[string]
comment
string
create_time
string
execute_on_approval
boolean
string
index
integer
operation
string
owner
owner
pending_approvers
integer
permitted_users
array[string]
potential_approvers
array[string]
query
string
required_approvers
integer
state
string
user_requested
string
  • readOnly: 1
  • x-nullable: true
user_vetoed
string
code
string
Argument code
message
string
Message argument
error
arguments
array[error_arguments]
Message arguments
code
string
Error code
message
string
Error message
target
string
