Create a multi-admin-verify request
Creates a request to verify administrative actions involving multiple administrators. Use this to ensure necessary approvals are in place for sensitive operations.
HTTP method and endpoint
POST /security/multi-admin-verify/requests
Introduced in
ONTAP 9.11
Usage notes
Creates a multi-admin-verify request.
return_records |
boolean |
query |
False |
Request Body
| Name | Type | Description |
approve_expiry_time |
string |
approve_time |
string |
approved_users |
array[string] |
The users that have approved the request. |
comment |
string |
Optional user-provided comment that is sent to the approval-group email indicating why the request was made. |
create_time |
string |
execution_expiry_time |
string |
index |
integer |
Unique index that represents a request. |
operation |
string |
The command to execute. |
owner |
The owner of the request. This can identify the cluster or an SVM. |
pending_approvers |
integer |
The number of approvers remaining that are required to approve. |
permitted_users |
array[string] |
List of users that can execute the operation once approved. If not set, any authorized user can perform the operation. |
potential_approvers |
array[string] |
The users that are able to approve the request. |
query |
string |
Identifies the specific entry upon which the user wants to operate. |
required_approvers |
integer |
The number of required approvers, excluding the user that made the request. |
state |
string |
The state of the request. PATCH supports approved and vetoed. The state only changes after setting to approved once no more approvers are required. |
user_requested |
string |
The user that created the request. Automatically set by ONTAP.
user_vetoed |
string |
The user that vetoed the request. |
Example request
"approve_expiry_time": "string",
"approve_time": "string",
"approved_users": [
"string"
"comment": "string",
"create_time": "string",
"execute_on_approval": true,
"execution_expiry_time": "string",
"index": 0,
"operation": "string",
"owner": {
"name": "svm1",
"pending_approvers": 0,
"permitted_users": [
"string"
"potential_approvers": [
"string"
"query": "string",
"required_approvers": 0,
"state": "string",
"user_requested": "string",
"user_vetoed": "string"
Status: 201, Created
num_records |
integer |
Number of records |
records |
array[multi_admin_verify_request] |
"num_records": 1,
"records": [
"approved_users": [
"string"
"index": 0,
"owner": {
"name": "svm1",
"string"
"string"
"query": "string",
"state": "string",
Headers
| Name | Description | Type |
Location |
Useful for tracking the resource location |
string |
Status: Default
ONTAP Error Response Codes
| Error Code | Description |
262148 |
The specified command is not recognized. |
262279 |
Invalid field set. |
262304 |
Too many requests. Delete one before creating another. |
262305 |
Can't approve non-pending request. |
262306 |
Can't veto an expired request. |
262308 |
The specified command is not supported by this feature. |
262309 |
The feature must be enabled first. |
262311 |
Value must be greater than zero. |
262312 |
Number of required approvers must be less than the total number of unique approvers in the approval-groups. |
262313 |
Number of unique approvers in the approval-groups must be greater than the number of required approvers. |
262326 |
Failed to parse query. |
262327 |
Failed to crate the request. |
262328 |
There is no matching rule for this request. |
262330 |
Cannot approve/veto a request multiple times. |
262334 |
The parameter specified in the command is not supported. |
262337 |
Cannot approve/veto the user's own request. |
href |
string |
_links
owner
name |
string |
uuid |
string |
string |
approve_time |
string |
approved_users |
array[string] |
comment |
string |
create_time |
string |
string |
index |
integer |
operation |
string |
owner |
pending_approvers |
integer |
permitted_users |
array[string] |
array[string] |
query |
string |
integer |
state |
string |
user_requested |
string |
user_vetoed |
string |
code |
string |
Argument code |
message |
string |
Message argument |
returned_error
arguments |
array[error_arguments] |
Message arguments |
code |
string |
Error code |
message |
string |
Error message |
target |
string |
