Create a new storage pool
Creates a new storage pool using available solid-state capacity attached to specified nodes. This is useful for managing cache capacity distribution among nodes within the same HA pair.
HTTP method and endpoint
POST /storage/pools
Introduced in
ONTAP 9.11
Usage notes
Creates a new storage pool using available solid state capacity attached to the nodes specified.
Required properties
The following properties are required in the POST body:
name- Name of the new storage pool. -
nodes[].nameornodes[].uuid- Nodes that can use cache capacity from the new storage pool. Only nodes in the same HA pair can be specified for a given storage pool. Spare cache capacity will be distributed evenly among the specified nodes. -
capacity.disk_count- Number of SSDs to be used to create the storage pool.
Related ONTAP commands
storage pool create
Example:
POST /api/storage/pools {"nodes": [{"name": "node1"}, {"name": "node2"}], "name": "storage_pool_1", "capacity": {"disk_count": "4"}}
disk_size |
integer |
query |
False |
If set, POST only selects SSDs within five percent of the specified size. |
simulate |
boolean |
query |
False |
When set to "true", the end point returns a simulated layout of the proposed new storage pool, without changing system state.
return_timeout |
integer |
query |
False |
return_records |
boolean |
query |
False |
Request Body
| Name | Type | Description |
capacity |
name |
string |
Storage pool name. |
nodes |
array[node_reference] |
Nodes that can use this storage pool for their aggregates. |
storage_type |
string |
Storage type for the disks used to create the storage pool. |
uuid |
string |
Storage pool UUID. |
Example request
"capacity": {
"disks": [
"disk": {
"name": "1.0.1"
"total_size": 0,
"usable_size": 0
"remaining": 0,
"spare_allocation_units": [
"available_size": 0,
"node": {
"name": "node1",
"size": 0,
"syncmirror_pool": "string"
"total": 0,
"used_allocation_units": [
"aggregate": {
"name": "aggr1",
"current_usage": 0,
"node": {
"name": "node1",
"name": "string",
"nodes": [
"name": "node1",
"storage_type": "string",
"uuid": "string"
Status: 202, Accepted
job |
"job": {
"uuid": "string"
Headers
| Name | Description | Type |
Location |
Useful for tracking the resource location |
string |
Status: 201, Created
Status: Default
ONTAP Error Response Codes
| Error Code | Description |
11206666 |
Storage pool is unhealthy. |
11208658 |
A storage pool already uses the specified name. |
11208660 |
Disk does not exist. |
11208661 |
Disk is not a spare disk. |
11208662 |
Disk is not an SSD. |
11208663 |
Disk is reserved for core dump. |
11208664 |
Could not determine checksum type of disk. |
11208666 |
Could not determine usable size of disk. |
11208668 |
Could not determine connectivity between controller and disk. |
11208670 |
Could not determine original owner of disk. |
11208671 |
Could not determine SyncMirror pool of disk. |
11208673 |
Could not determine HA mode of node. |
11208674 |
Could not determine HA partner of node. |
11208675 |
Disks specified in the disk list are not visible to node. |
11208678 |
The disk list contains disks from nodes which are not in HA pair. |
11208679 |
Storage pools are not supported on nodes. |
11208680 |
Internal error. Cannot determine configuration for node. |
11208681 |
Node is not online. |
11208682 |
Internal error. Sharing configuration mismatch. |
11208684 |
Unable to share disk. |
11208686 |
Disk cannot be shared. |
11208687 |
Unable to retrieve expected sharing configuration. |
11208688 |
Storage pool create job failed. |
11208690 |
Not all nodes sharing the storage pool view disk as a shared disk. |
11208691 |
Not enough matching spares available. |
11208692 |
A disk list or count is a required parameter for storage pool creation. |
11208693 |
Invalid number of disks specified. |
11208698 |
Internal error. Missing node name. |
11208699 |
Internal error. Missing partner name for node configured for HA. |
11208701 |
Node is a standalone node. Do not specify other nodes with a standalone node. |
11208703 |
Incorrect number of nodes specified. Specify one node or both nodes in an HA pair. |
11208704 |
Specified nodes are not part of HA relationship. Specify one node or both nodes in an HA pair. |
11208705 |
Disk is a data center SSD, which cannot be used in storage pools. |
11208706 |
Disk is a SSD-ZNS, which cannot be used in storage pools. |
11215756 |
Missing a required field for POST request. |
href |
string |
_links
disk
Reference to the constituent disk object.
name |
string |
storage_pool_disk
disk |
Reference to the constituent disk object. |
total_size |
integer |
Raw capacity of the disk, in bytes. |
usable_size |
integer |
Usable capacity of this disk, in bytes. |
node
Specifies what node can use this set of allocation units.
name |
string |
uuid |
string |
storage_pool_spare_allocation_unit
available_size |
integer |
The usable capacity of this set of allocation units. |
count |
integer |
The number of spare allocation units on this node. |
node |
Specifies what node can use this set of allocation units. |
size |
integer |
Size of each allocation unit. |
syncmirror_pool |
string |
The RAID SyncMirror Pool to which this allocation unit is assigned. |
aggregate
The aggregate that is using this cache capacity.
name |
string |
uuid |
string |
node
The node hosting the aggregate using this set of allocation units.
name |
string |
uuid |
string |
storage_pool_used_allocation_unit
aggregate |
The aggregate that is using this cache capacity. |
count |
integer |
The number of allocation units used by this aggregate. |
current_usage |
integer |
The amount of cache space used by this aggregate. |
node |
The node hosting the aggregate using this set of allocation units. |
capacity
disk_count |
integer |
The number of disks in the storage pool. |
disks |
array[storage_pool_disk] |
Properties of each disk used in the shared storage pool. |
remaining |
integer |
Remaining usable capacity in the flash pool, in bytes. |
spare_allocation_units |
Properties of spare allocation units. |
total |
integer |
Total size of the flash pool, in bytes. |
used_allocation_units |
Information about the storage pool allocation units participating in the cache tier of an aggregate. |
code |
string |
Argument code |
message |
string |
Message argument |
error
Indicates why the storage pool is unhealthy. This property is not returned for healthy storage pools.
arguments |
array[error_arguments] |
Message arguments |
code |
string |
Error code |
message |
string |
Error message |
target |
string |
health
Properties that outline shared storage pool health.
is_healthy |
boolean |
Indicates whether the storage pool is able to participate in provisioning operations. |
state |
string |
The state of the shared storage pool. |
node_reference
name |
string |
uuid |
string |
storage_pool
capacity |
name |
string |
nodes |
storage_type |
string |
uuid |
string |
job_link
uuid |
string |
error
arguments |
Message arguments |
code |
string |
Error code |
message |
string |
Error message |
target |
string |
